[PATCH 3/3] score: Task get/set affinity
Wed Apr 9 06:09:17 UTC 2014
On 2014-04-08 17:09, Jennifer Averett wrote:
> I thought the consensus was that non-smp systems would not
> support affinity methods.
I don't remember a discussion about this.
I think it makes it easier for application developers if the don't have to
plaster their code with #ifdef RTEMS_SMP.  You should also be able to write
libraries that work with SMP and non-SMP configurations.  For this we have to
provide the same ABI.  This should be the long term goal.
I propose to add a new requirement:
The non-SMP and SMP RTEMS Classic API should be ABI compatible.
http://www.rtems.org/wiki/index.php?title=SMP#Requirements
On Linux you can use the thread affinity functions also on non-SMP systems.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
