[PATCH 4/4] rtems: Add task get/set scheduler
Wed Apr 9 11:28:50 UTC 2014
 cpukit/rtems/Makefile.am                         |    2 +
 cpukit/rtems/include/rtems/rtems/tasks.h         |   35 ++++++++++
 cpukit/rtems/src/taskgetscheduler.c              |   60 +++++++++++++++++
 cpukit/rtems/src/tasksetscheduler.c              |   58 ++++++++++++++++
 cpukit/score/include/rtems/score/schedulerimpl.h |   25 +++++++
 testsuites/sptests/spscheduler01/init.c          |   77 +++++++++++++++++++++-
 6 files changed, 256 insertions(+), 1 deletions(-)
 create mode 100644 cpukit/rtems/src/taskgetscheduler.c
 create mode 100644 cpukit/rtems/src/tasksetscheduler.c
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index c840f24..062b986 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -94,6 +94,7 @@ librtems_a_SOURCES += src/taskcreate.c
 librtems_a_SOURCES += src/taskdelete.c
 librtems_a_SOURCES += src/taskgetaffinity.c
 librtems_a_SOURCES += src/taskgetnote.c
+librtems_a_SOURCES += src/taskgetscheduler.c
 librtems_a_SOURCES += src/taskident.c
 librtems_a_SOURCES += src/taskinitusers.c
 librtems_a_SOURCES += src/taskissuspended.c
@@ -104,6 +105,7 @@ librtems_a_SOURCES += src/taskself.c
 librtems_a_SOURCES += src/tasksetaffinity.c
 librtems_a_SOURCES += src/tasksetnote.c
 librtems_a_SOURCES += src/tasksetpriority.c
+librtems_a_SOURCES += src/tasksetscheduler.c
 librtems_a_SOURCES += src/taskstart.c
 librtems_a_SOURCES += src/tasksuspend.c
 librtems_a_SOURCES += src/taskwakeafter.c
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 59c5c83..ca764e8 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -542,6 +542,41 @@ rtems_status_code rtems_task_set_affinity(
 #endif
+ * @brief Gets the scheduler of a task.
+ * @param[in] id Identifier of the task.  Use @ref RTEMS_SELF to select the
+ * executing task.
+ * @param[out] scheduler_id Identifier of the scheduler.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a scheduler_id parameter is @c NULL.
+ * @retval RTEMS_INVALID_ID Invalid task identifier.
+rtems_status_code rtems_task_get_scheduler(
+  rtems_id  id,
+  rtems_id *scheduler_id
+ * @brief Sets the scheduler of a task.
+ * executing task.
+ * @param[in] scheduler_id Identifier of the scheduler.
+ * @retval RTEMS_INVALID_ID Invalid task or scheduler identifier.
+ * @retval RTEMS_INCORRECT_STATE The task is in the wrong state to perform a
+ * scheduler change.
+ * @see rtems_scheduler_ident().
+rtems_status_code rtems_task_set_scheduler(
+  rtems_id id,
+  rtems_id scheduler_id
  *  @brief RTEMS Get Self Task Id
  *  This directive returns the ID of the currently executing task.
diff --git a/cpukit/rtems/src/taskgetscheduler.c b/cpukit/rtems/src/taskgetscheduler.c
new file mode 100644
index 0000000..7111093
--- /dev/null
+++ b/cpukit/rtems/src/taskgetscheduler.c
@@ -0,0 +1,60 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+#include <rtems/score/schedulerimpl.h>
+  rtems_id  id,
+  rtems_status_code sc;
+  if ( scheduler_id != NULL ) {
+    Thread_Control          *the_thread;
+    Objects_Locations        location;
+    const Scheduler_Control *scheduler;
+    the_thread = _Thread_Get( id, &location );
+    switch ( location ) {
+      case OBJECTS_LOCAL:
+        scheduler = _Scheduler_Get( the_thread );
+        *scheduler_id = _Scheduler_Build_id(
+          _Scheduler_Get_index( scheduler )
+        _Objects_Put( &the_thread->Object );
+        sc = RTEMS_SUCCESSFUL;
+        break;
+#if defined(RTEMS_MULTIPROCESSING)
+      case OBJECTS_REMOTE:
+        _Thread_Dispatch();
+        sc = RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
+        break;
+#endif
+      default:
+        sc = RTEMS_INVALID_ID;
+        break;
+  } else {
+    sc = RTEMS_INVALID_ADDRESS;
+  return sc;
diff --git a/cpukit/rtems/src/tasksetscheduler.c b/cpukit/rtems/src/tasksetscheduler.c
index 0000000..42c08bb
--- /dev/null
+++ b/cpukit/rtems/src/tasksetscheduler.c
@@ -0,0 +1,58 @@
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#if HAVE_CONFIG_H
+#endif
+  rtems_id id,
+  if ( _Scheduler_Get_by_id( scheduler_id, &scheduler ) ) {
+    bool               ok;
+        ok = _Scheduler_Set( scheduler, the_thread );
+        sc = ok ? RTEMS_SUCCESSFUL : RTEMS_INCORRECT_STATE;
+        break;
+        break;
+#endif
+      default:
+        break;
+  } else {
+  return sc;
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 8a8e779..ded2773 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -441,6 +441,24 @@ RTEMS_INLINE_ROUTINE const Scheduler_Control *_Scheduler_Get(
   return &_Scheduler_Table[ 0 ];
+RTEMS_INLINE_ROUTINE bool _Scheduler_Set(
+  const Scheduler_Control *scheduler,
+  bool ok;
+  (void) scheduler;
+  if ( _States_Is_dormant( the_thread->current_state ) ) {
+    ok = true;
+  } else {
+    ok = false;
+  return ok;
 RTEMS_INLINE_ROUTINE Objects_Id _Scheduler_Build_id( uint32_t scheduler_index )
   return _Objects_Build_id(
@@ -464,6 +482,13 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Get_by_id(
   return index < _Scheduler_Count;
+RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_index(
+  return (uint32_t) (&_Scheduler_Table[ 0 ] - scheduler);
 #ifdef __cplusplus
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index ea50574..3b28697 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -98,6 +98,80 @@ static void test_task_get_set_affinity(void)
 #endif /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
+static void task(rtems_task_argument arg)
+  (void) arg;
+  rtems_test_assert(0);
+static void test_task_get_set_scheduler(void)
+  rtems_id self_id = rtems_task_self();
+  rtems_id scheduler_id;
+  rtems_id scheduler_id_by_index;
+  rtems_id task_id;
+  sc = rtems_scheduler_ident_by_index(0, &scheduler_id_by_index);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  sc = rtems_task_get_scheduler(RTEMS_SELF, NULL);
+  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+  sc = rtems_task_get_scheduler(invalid_id, &scheduler_id);
+  rtems_test_assert(sc == RTEMS_INVALID_ID);
+  scheduler_id = 0;
+  sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
+  rtems_test_assert(scheduler_id == scheduler_id_by_index);
+  scheduler_id = 0;
+  sc = rtems_task_get_scheduler(self_id, &scheduler_id);
+  sc = rtems_task_set_scheduler(invalid_id, scheduler_id);
+  sc = rtems_task_set_scheduler(self_id, invalid_id);
+  sc = rtems_task_set_scheduler(self_id, scheduler_id);
+  rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
+  sc = rtems_task_create(
+    rtems_build_name('T', 'A', 'S', 'K'),
+    2,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_DEFAULT_MODES,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &task_id
+  scheduler_id = 0;
+  sc = rtems_task_get_scheduler(task_id, &scheduler_id);
+  sc = rtems_task_set_scheduler(task_id, scheduler_id);
+  sc = rtems_task_start(task_id, task, 0);
+  sc = rtems_task_delete(task_id);
 static void test_scheduler_ident(void)
@@ -191,6 +265,7 @@ static void Init(rtems_task_argument arg)
   rtems_resource_snapshot_take(&snapshot);
   test_task_get_set_affinity();
+  test_task_get_set_scheduler();
   test_scheduler_ident();
   test_scheduler_get_processors();
@@ -205,7 +280,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 2
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
1.7.7
