[PATCH 1/2] rtems: Rename rtems_smp_get_processor_count()
Thu Apr 10 09:06:38 UTC 2014
Rename rtems_smp_get_processor_count() in rtems_get_processor_count().
Make rtems_get_processor_count() a function in uni-processor
configurations to enable ABI compatibility with SMP configurations.
 c/src/lib/libbsp/sparc/leon3/startup/bspreset.c |    2 +-
 cpukit/libmisc/cpuuse/cpuusagereset.c           |    2 +-
 cpukit/rtems/Makefile.am                        |    2 +
 cpukit/rtems/include/rtems/rtems/smp.h          |    6 +---
 cpukit/rtems/src/getprocessorcount.c            |   25 +++++++++++++++++++++++
 cpukit/sapi/src/profilingiterate.c              |    2 +-
 testsuites/smptests/smp01/init.c                |    6 ++--
 testsuites/smptests/smp02/init.c                |    4 +-
 testsuites/smptests/smp03/init.c                |   10 ++++----
 testsuites/smptests/smp05/init.c                |    4 +-
 testsuites/smptests/smp07/init.c                |    2 +-
 testsuites/smptests/smp08/init.c                |    2 +-
 testsuites/smptests/smp09/init.c                |    2 +-
 testsuites/smptests/smpaffinity01/init.c        |    2 +-
 testsuites/smptests/smpatomic01/init.c          |    2 +-
 testsuites/smptests/smpfatal01/init.c           |    2 +-
 testsuites/smptests/smpfatal02/init.c           |    2 +-
 testsuites/smptests/smpfatal03/init.c           |    2 +-
 testsuites/smptests/smpload01/init.c            |    6 ++--
 testsuites/smptests/smplock01/init.c            |    4 +-
 testsuites/smptests/smpmigration01/init.c       |    2 +-
 testsuites/smptests/smppsxaffinity01/init.c     |    2 +-
 testsuites/smptests/smppsxaffinity02/init.c     |    2 +-
 testsuites/smptests/smppsxsignal01/init.c       |    2 +-
 testsuites/smptests/smpscheduler01/init.c       |    2 +-
 testsuites/smptests/smpsignal01/init.c          |    2 +-
 testsuites/smptests/smpswitchextension01/init.c |    2 +-
 testsuites/smptests/smpthreadlife01/init.c      |    2 +-
 testsuites/tmtests/tmcontext01/init.c           |    2 +-
 29 files changed, 66 insertions(+), 41 deletions(-)
 create mode 100644 cpukit/rtems/src/getprocessorcount.c
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c b/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c
index e1430b2..c3c9e98 100644
--- a/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bspreset.c
@@ -32,7 +32,7 @@ void bsp_reset(void)
       uint32_t max_wait = 1234567;
-      uint32_t cpu_count = rtems_smp_get_processor_count();
+      uint32_t cpu_count = rtems_get_processor_count();
       uint32_t halt_mask = 0;
       uint32_t i;
diff --git a/cpukit/libmisc/cpuuse/cpuusagereset.c b/cpukit/libmisc/cpuuse/cpuusagereset.c
index b74414b..e77ac2c 100644
--- a/cpukit/libmisc/cpuuse/cpuusagereset.c
+++ b/cpukit/libmisc/cpuuse/cpuusagereset.c
@@ -45,7 +45,7 @@ void rtems_cpu_usage_reset( void )
     _TOD_Get_uptime( &CPU_usage_Uptime_at_last_reset );
-    processor_count = rtems_smp_get_processor_count();
+    processor_count = rtems_get_processor_count();
     for ( processor = 0 ; processor < processor_count ; ++processor ) {
       Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( processor );
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index 062b986..fc2a0e1 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -266,6 +266,8 @@ librtems_a_SOURCES += src/modes.c
 librtems_a_SOURCES += src/status.c
 librtems_a_SOURCES += src/statustext.c
+librtems_a_SOURCES += src/getprocessorcount.c
 if HAS_MP
 # We only build multiprocessing related files if HAS_MP was defined
 librtems_a_SOURCES += src/eventmp.c
diff --git a/cpukit/rtems/include/rtems/rtems/smp.h b/cpukit/rtems/include/rtems/rtems/smp.h
index d2904e4..b327514 100644
--- a/cpukit/rtems/include/rtems/rtems/smp.h
+++ b/cpukit/rtems/include/rtems/rtems/smp.h
@@ -40,8 +40,7 @@ extern "C" {
  * @brief Returns the count of processors in the system.
- * On uni-processor configurations this is a compile time constant and defined
- * to be one.
+ * On uni-processor configurations a value of one will be returned.
  * On SMP configurations this returns the value of a global variable set during
  * system initialization to indicate the count of processors.  The processor
@@ -51,8 +50,7 @@ extern "C" {
  * @return The count of processors in the system.
-#define rtems_smp_get_processor_count() \
-  _SMP_Get_processor_count()
+uint32_t rtems_get_processor_count(void);
  * @brief Returns the index of the current processor.
diff --git a/cpukit/rtems/src/getprocessorcount.c b/cpukit/rtems/src/getprocessorcount.c
new file mode 100644
index 0000000..438eec6
--- /dev/null
+++ b/cpukit/rtems/src/getprocessorcount.c
@@ -0,0 +1,25 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/rtems/smp.h>
+#include <rtems/score/smp.h>
+  return _SMP_Get_processor_count();
diff --git a/cpukit/sapi/src/profilingiterate.c b/cpukit/sapi/src/profilingiterate.c
index bc98205..0fd96fa 100644
--- a/cpukit/sapi/src/profilingiterate.c
+++ b/cpukit/sapi/src/profilingiterate.c
@@ -30,7 +30,7 @@ static void per_cpu_stats_iterate(
 #ifdef RTEMS_PROFILING
-  uint32_t n = rtems_smp_get_processor_count();
+  uint32_t n = rtems_get_processor_count();
   uint32_t i;
   memset(data, 0, sizeof(*data));
diff --git a/testsuites/smptests/smp01/init.c b/testsuites/smptests/smp01/init.c
index 91a6e40..8439293 100644
--- a/testsuites/smptests/smp01/init.c
+++ b/testsuites/smptests/smp01/init.c
@@ -48,12 +48,12 @@ rtems_task Init(
   locked_print_initialize();
   /* Initialize the TaskRan array */
-  for ( i=0; i<rtems_smp_get_processor_count() ; i++ ) {
+  for ( i=0; i<rtems_get_processor_count() ; i++ ) {
     TaskRan[i] = false;
   /* Create and start tasks for each processor */
-  for ( i=0; i< rtems_smp_get_processor_count() ; i++ ) {
+  for ( i=0; i< rtems_get_processor_count() ; i++ ) {
     if ( i != cpu_self ) {
       ch = '0' + i;
@@ -78,7 +78,7 @@ rtems_task Init(
   /* Wait on the all tasks to run */
   while (1) {
     allDone = true;
       if ( i != cpu_self && TaskRan[i] == false)
         allDone = false;
diff --git a/testsuites/smptests/smp02/init.c b/testsuites/smptests/smp02/init.c
index c2cf5a3..05f6351 100644
--- a/testsuites/smptests/smp02/init.c
+++ b/testsuites/smptests/smp02/init.c
@@ -40,7 +40,7 @@ rtems_task Init(
-  if ( rtems_smp_get_processor_count() == 1 ) {
+  if ( rtems_get_processor_count() == 1 ) {
     success();
@@ -59,7 +59,7 @@ rtems_task Init(
   status = rtems_semaphore_obtain( Semaphore, RTEMS_WAIT, 0);
   directive_failed( status,"rtems_semaphore_obtain of SEM1\n");
-  for ( i=1; i < rtems_smp_get_processor_count(); i++ ){
+  for ( i=1; i < rtems_get_processor_count(); i++ ){
     /* Create and start tasks for each CPU */
     ch = '0' + i;
diff --git a/testsuites/smptests/smp03/init.c b/testsuites/smptests/smp03/init.c
index 0d0bb62..3acdfe9 100644
--- a/testsuites/smptests/smp03/init.c
+++ b/testsuites/smptests/smp03/init.c
@@ -57,13 +57,13 @@ rtems_task Init(
     success();
   TaskRan[0] = true;
-  for ( i=1; i<rtems_smp_get_processor_count() ; i++ ) {
+  for ( i=1; i<rtems_get_processor_count() ; i++ ) {
     TaskRan[i] = false;
@@ -71,7 +71,7 @@ rtems_task Init(
   PrintTaskInfo( "Init" );
   /* for each remaining cpu create and start a task */
     ch = '0' + i;
@@ -101,12 +101,12 @@ rtems_task Init(
     RTEMS_DEFAULT_ATTRIBUTES,
     &id
-  status = rtems_task_start(id,Test_task,rtems_smp_get_processor_count());
+  status = rtems_task_start(id,Test_task,rtems_get_processor_count());
   /* Wait on all tasks to run */
   while (1) {
     TestFinished = true;
-    for ( i=1; i < (rtems_smp_get_processor_count()+1) ; i++ ) {
+    for ( i=1; i < (rtems_get_processor_count()+1) ; i++ ) {
       if (TaskRan[i] == false)
         TestFinished = false;
diff --git a/testsuites/smptests/smp05/init.c b/testsuites/smptests/smp05/init.c
index 23669ec..cf7ea3a 100644
--- a/testsuites/smptests/smp05/init.c
+++ b/testsuites/smptests/smp05/init.c
@@ -44,11 +44,11 @@ rtems_task Init(
     success();
     ch = '1' + i;
     status = rtems_task_create(
diff --git a/testsuites/smptests/smp07/init.c b/testsuites/smptests/smp07/init.c
index 5f9c496..53993ce 100644
--- a/testsuites/smptests/smp07/init.c
+++ b/testsuites/smptests/smp07/init.c
@@ -93,7 +93,7 @@ rtems_task Init(
     success();
diff --git a/testsuites/smptests/smp08/init.c b/testsuites/smptests/smp08/init.c
index aee7c18..dc4c789 100644
--- a/testsuites/smptests/smp08/init.c
+++ b/testsuites/smptests/smp08/init.c
@@ -76,7 +76,7 @@ rtems_task Init(
   /* Show that the init task is running on this cpu */
   PrintTaskInfo( "Init", &time );
-  for ( i=1; i <= rtems_smp_get_processor_count() *3; i++ ) {
+  for ( i=1; i <= rtems_get_processor_count() *3; i++ ) {
     sprintf(ch, "%02" PRId32, i );
diff --git a/testsuites/smptests/smp09/init.c b/testsuites/smptests/smp09/init.c
index 7128198..09e9c09 100644
--- a/testsuites/smptests/smp09/init.c
+++ b/testsuites/smptests/smp09/init.c
@@ -45,7 +45,7 @@ rtems_task Init(
   for ( killtime=0; killtime<1000000; killtime++ )
-  for ( i=0; i<rtems_smp_get_processor_count() -1; i++ ) {
+  for ( i=0; i<rtems_get_processor_count() -1; i++ ) {
     ch = '1' + i;
diff --git a/testsuites/smptests/smpaffinity01/init.c b/testsuites/smptests/smpaffinity01/init.c
index cc5f321..06d5719 100644
--- a/testsuites/smptests/smpaffinity01/init.c
+++ b/testsuites/smptests/smpaffinity01/init.c
@@ -112,7 +112,7 @@ void Validate_affinity(void )
   directive_failed( sc, "Get Affinity of Init Task" );
   /* Get the number of processors that we are using. */
-  cpu_count = rtems_smp_get_processor_count();
+  cpu_count = rtems_get_processor_count();
   /* Fill the remaining cpus with med priority tasks */
   puts( "Init - Create Medium priority tasks");
diff --git a/testsuites/smptests/smpatomic01/init.c b/testsuites/smptests/smpatomic01/init.c
index e055ea4..283200b 100644
--- a/testsuites/smptests/smpatomic01/init.c
+++ b/testsuites/smptests/smpatomic01/init.c
@@ -446,7 +446,7 @@ static void test(void)
   test_static_and_dynamic_initialization();
-  ctx->worker_count = rtems_smp_get_processor_count();
+  ctx->worker_count = rtems_get_processor_count();
   sc = rtems_timer_create(
     rtems_build_name('S', 'T', 'O', 'P'),
diff --git a/testsuites/smptests/smpfatal01/init.c b/testsuites/smptests/smpfatal01/init.c
index 0ba627a..178148b 100644
--- a/testsuites/smptests/smpfatal01/init.c
+++ b/testsuites/smptests/smpfatal01/init.c
@@ -69,7 +69,7 @@ static rtems_status_code test_driver_init(
   uint32_t self = rtems_smp_get_current_processor();
   uint32_t cpu;
   rtems_test_begink();
diff --git a/testsuites/smptests/smpfatal02/init.c b/testsuites/smptests/smpfatal02/init.c
index c801a28..fb42e5d 100644
--- a/testsuites/smptests/smpfatal02/init.c
+++ b/testsuites/smptests/smpfatal02/init.c
@@ -77,7 +77,7 @@ static rtems_status_code test_driver_init(
   uint32_t cpu;
diff --git a/testsuites/smptests/smpfatal03/init.c b/testsuites/smptests/smpfatal03/init.c
index 714e7b9..13a9db5 100644
--- a/testsuites/smptests/smpfatal03/init.c
+++ b/testsuites/smptests/smpfatal03/init.c
@@ -68,7 +68,7 @@ static void wait_for_giant(void)
 static void Init(rtems_task_argument arg)
diff --git a/testsuites/smptests/smpload01/init.c b/testsuites/smptests/smpload01/init.c
index 56faac0..7f0169d 100644
--- a/testsuites/smptests/smpload01/init.c
+++ b/testsuites/smptests/smpload01/init.c
@@ -82,7 +82,7 @@ static void inherit_obtain_task(rtems_task_argument arg)
   test_context *ctx = &test_instance;
   rtems_status_code sc;
   SMP_barrier_State barrier_state = SMP_BARRIER_STATE_INITIALIZER;
   rtems_counter_ticks delay = (cpu_count - 1 - arg) * ctx->inherit_obtain_delay;
   while (true) {
@@ -352,7 +352,7 @@ static void test(void)
   sc = rtems_event_transient_receive(RTEMS_WAIT, RTEMS_NO_TIMEOUT);
   rtems_test_assert(sc == RTEMS_SUCCESSFUL);
-  for (i = 0; i < rtems_smp_get_processor_count(); ++i) {
+  for (i = 0; i < rtems_get_processor_count(); ++i) {
     sc = rtems_task_create(
       rtems_build_name('I', 'N', 'H', 'O'),
       INHERIT_OBTAIN_PRIO_BASE + i,
@@ -387,7 +387,7 @@ static void test(void)
     ctx->inherit_release_counter
     printf(
       "priority inheritance obtain count %2" PRIu32 ": %" PRIu64 "\n",
       i,
diff --git a/testsuites/smptests/smplock01/init.c b/testsuites/smptests/smplock01/init.c
index f0d9c92..85995e8 100644
--- a/testsuites/smptests/smplock01/init.c
+++ b/testsuites/smptests/smplock01/init.c
@@ -259,7 +259,7 @@ static void run_tests(
 static void task(rtems_task_argument arg)
   global_context *ctx = (global_context *) arg;
   uint32_t cpu_self = rtems_smp_get_current_processor();
   SMP_barrier_State bs = SMP_BARRIER_STATE_INITIALIZER;
@@ -273,7 +273,7 @@ static void task(rtems_task_argument arg)
   global_context *ctx = &context;
   uint32_t cpu;
   int test;
diff --git a/testsuites/smptests/smpmigration01/init.c b/testsuites/smptests/smpmigration01/init.c
index e492911..fe321c8 100644
--- a/testsuites/smptests/smpmigration01/init.c
+++ b/testsuites/smptests/smpmigration01/init.c
@@ -224,7 +224,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
-  if (rtems_smp_get_processor_count() >= 2) {
+  if (rtems_get_processor_count() >= 2) {
     test();
diff --git a/testsuites/smptests/smppsxaffinity01/init.c b/testsuites/smptests/smppsxaffinity01/init.c
index 5485149..cb9e0b3 100644
--- a/testsuites/smptests/smppsxaffinity01/init.c
+++ b/testsuites/smptests/smppsxaffinity01/init.c
@@ -106,7 +106,7 @@ void Validate_attr(void )
   rtems_test_assert( priority != -1 );
-  cpus = rtems_smp_get_processor_count();
+  cpus = rtems_get_processor_count();
   puts(
     "Init - Validate pthread_attr_setaffinity_np and "
     "pthread_attr_getaffinity_np"
diff --git a/testsuites/smptests/smppsxaffinity02/init.c b/testsuites/smptests/smppsxaffinity02/init.c
index 7916e60..ad98da4 100644
--- a/testsuites/smptests/smppsxaffinity02/init.c
+++ b/testsuites/smptests/smppsxaffinity02/init.c
@@ -121,7 +121,7 @@ void Validate_affinity(void )
   rtems_test_assert( !sc );
diff --git a/testsuites/smptests/smppsxsignal01/init.c b/testsuites/smptests/smppsxsignal01/init.c
index 495af06..61eaec1 100644
--- a/testsuites/smptests/smppsxsignal01/init.c
+++ b/testsuites/smptests/smppsxsignal01/init.c
@@ -165,7 +165,7 @@ static void *POSIX_Init(void *arg)
   TEST_BEGIN();
     test();
diff --git a/testsuites/smptests/smpscheduler01/init.c b/testsuites/smptests/smpscheduler01/init.c
index a0d3760..10ac735 100644
--- a/testsuites/smptests/smpscheduler01/init.c
+++ b/testsuites/smptests/smpscheduler01/init.c
@@ -69,7 +69,7 @@ static void task(rtems_task_argument arg)
 static bool is_per_cpu_state_ok(void)
   bool ok = true;
   uint32_t i;
   for (i = 0; i < n; ++i) {
diff --git a/testsuites/smptests/smpsignal01/init.c b/testsuites/smptests/smpsignal01/init.c
index d5d31d5..1aaa700 100644
--- a/testsuites/smptests/smpsignal01/init.c
+++ b/testsuites/smptests/smpsignal01/init.c
@@ -166,7 +166,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test();
diff --git a/testsuites/smptests/smpswitchextension01/init.c b/testsuites/smptests/smpswitchextension01/init.c
index 017ff97..eda8a9c 100644
--- a/testsuites/smptests/smpswitchextension01/init.c
+++ b/testsuites/smptests/smpswitchextension01/init.c
@@ -225,7 +225,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
     test();
diff --git a/testsuites/smptests/smpthreadlife01/init.c b/testsuites/smptests/smpthreadlife01/init.c
index 8ff5ea1..38b054f 100644
--- a/testsuites/smptests/smpthreadlife01/init.c
+++ b/testsuites/smptests/smpthreadlife01/init.c
@@ -298,7 +298,7 @@ static void Init(rtems_task_argument arg)
   TEST_BEGIN();
-  if (rtems_smp_get_processor_count() >= CPU_COUNT) {
+  if (rtems_get_processor_count() >= CPU_COUNT) {
     test_restart();
     test_delete();
     test_set_life_protection();
diff --git a/testsuites/tmtests/tmcontext01/init.c b/testsuites/tmtests/tmcontext01/init.c
index 2f5ada4..c5162a29 100644
--- a/testsuites/tmtests/tmcontext01/init.c
+++ b/testsuites/tmtests/tmcontext01/init.c
@@ -214,7 +214,7 @@ static void Init(rtems_task_argument arg)
   test(false, load);
   test(true, load);
-  for (load = 1; load < rtems_smp_get_processor_count(); ++load) {
+  for (load = 1; load < rtems_get_processor_count(); ++load) {
     rtems_id id;
     volatile int *load_data = NULL;
1.7.7
