[PATCH 3/8] libchip: Reduce tx interrupts
Thu Apr 10 22:00:15 UTC 2014
OK
On 4/10/2014 11:36 AM, Ralf Kirchner wrote:
>  c/src/libchip/network/dwmac-1000-dma.c |    2 +-
>  c/src/libchip/network/dwmac-core.c     |   23 +-
>  c/src/libchip/network/dwmac-core.h     |    8 +-
>  c/src/libchip/network/dwmac.c          |  451 +++++++++++++++++---------------
>  4 Dateien geändert, 262 Zeilen hinzugefügt(+), 222 Zeilen entfernt(-)
> diff --git a/c/src/libchip/network/dwmac-1000-dma.c b/c/src/libchip/network/dwmac-1000-dma.c
> index 32e5914..5ee4e7b 100644
> --- a/c/src/libchip/network/dwmac-1000-dma.c
> +++ b/c/src/libchip/network/dwmac-1000-dma.c
> @@ -147,7 +147,7 @@ static int dwmac1000_dma_init(
>      /* Mask interrupts by writing to CSR7 */
>      dwmac_core_enable_dma_irq_rx( self );
> -    dwmac_core_enable_dma_irq_tx( self );
> +    dwmac_core_enable_dma_irq_tx_default( self );
>      /* The base address of the RX/TX descriptor lists must be written into
>       * DMA CSR3 and CSR4, respectively. */
> diff --git a/c/src/libchip/network/dwmac-core.c b/c/src/libchip/network/dwmac-core.c
> index 1050751..973441a 100644
> --- a/c/src/libchip/network/dwmac-core.c
> +++ b/c/src/libchip/network/dwmac-core.c
> @@ -41,12 +41,17 @@
>  #define DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX \
>      DMAGRP_INTERRUPT_ENABLE_NIE \
> -    | DMAGRP_INTERRUPT_ENABLE_TIE \
>      | DMAGRP_INTERRUPT_ENABLE_FBE \
>      | DMAGRP_INTERRUPT_ENABLE_UNE \
>      | DMAGRP_INTERRUPT_ENABLE_AIE \
> +#define DWMAC_CORE_INTR_ENABLE_ALL_MASK_TX \
> +    DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX \
> +    | DMAGRP_INTERRUPT_ENABLE_TIE \
>  #define DWMAC_CORE_INTR_STATUS_DEFAULT_MASK_RX \
>      DMAGRP_STATUS_NIS \
> @@ -67,19 +72,29 @@ void dwmac_core_dma_restart_tx( dwmac_common_context *self )
>    self->dmagrp->transmit_poll_demand = 1;
> -void dwmac_core_enable_dma_irq_tx( dwmac_common_context *self )
> +void dwmac_core_enable_dma_irq_tx_default( dwmac_common_context *self )
>    self->dmagrp->interrupt_enable |= DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX;
> +void dwmac_core_enable_dma_irq_tx_transmitted( dwmac_common_context *self )
> +  self->dmagrp->interrupt_enable |= DMAGRP_INTERRUPT_ENABLE_TIE;
>  void dwmac_core_enable_dma_irq_rx( dwmac_common_context *self )
>    self->dmagrp->interrupt_enable |= DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_RX;
> -void dwmac_core_disable_dma_irq_tx( dwmac_common_context *self )
> +void dwmac_core_disable_dma_irq_tx_all( dwmac_common_context *self )
> +  self->dmagrp->interrupt_enable &= ~DWMAC_CORE_INTR_ENABLE_ALL_MASK_TX;
> +void dwmac_core_disable_dma_irq_tx_transmitted( dwmac_common_context *self )
> -  self->dmagrp->interrupt_enable &= ~DWMAC_CORE_INTR_ENABLE_DEFAULT_MASK_TX;
> +  self->dmagrp->interrupt_enable &= ~DMAGRP_INTERRUPT_ENABLE_TIE;
>  void dwmac_core_reset_dma_irq_status_tx( dwmac_common_context *self )
> diff --git a/c/src/libchip/network/dwmac-core.h b/c/src/libchip/network/dwmac-core.h
> index 3a35d00..0f3ba39 100644
> --- a/c/src/libchip/network/dwmac-core.h
> +++ b/c/src/libchip/network/dwmac-core.h
> @@ -55,9 +55,13 @@ void dwmac_core_dma_restart_tx( dwmac_common_context *self );
>  void dwmac_core_enable_dma_irq_rx( dwmac_common_context *self );
> -void dwmac_core_enable_dma_irq_tx( dwmac_common_context *self );
> +void dwmac_core_enable_dma_irq_tx_default( dwmac_common_context *self );
> -void dwmac_core_disable_dma_irq_tx( dwmac_common_context *self );
> +void dwmac_core_enable_dma_irq_tx_transmitted( dwmac_common_context *self );
> +void dwmac_core_disable_dma_irq_tx_all( dwmac_common_context *self );
> +void dwmac_core_disable_dma_irq_tx_transmitted( dwmac_common_context *self );
>  void dwmac_core_disable_dma_irq_rx( dwmac_common_context *self );
> diff --git a/c/src/libchip/network/dwmac.c b/c/src/libchip/network/dwmac.c
> index 10f6b75..eda1433 100644
> --- a/c/src/libchip/network/dwmac.c
> +++ b/c/src/libchip/network/dwmac.c
> @@ -262,9 +262,14 @@ static inline void dwmac_enable_irq_rx( dwmac_common_context *self )
> -static inline void dwmac_enable_irq_tx( dwmac_common_context *self )
> +static inline void dwmac_enable_irq_tx_default( dwmac_common_context *self )
> +static inline void dwmac_enable_irq_tx_transmitted( dwmac_common_context *self )
> +  dwmac_core_enable_dma_irq_tx_transmitted( self );
>  static inline void dwmac_disable_irq_rx( dwmac_common_context *self )
> @@ -272,16 +277,20 @@ static inline void dwmac_disable_irq_rx( dwmac_common_context *self )
>    dwmac_core_disable_dma_irq_rx( self );
> -static inline void dwmac_diable_irq_tx( dwmac_common_context *self )
> +static inline void dwmac_disable_irq_tx_all( dwmac_common_context *self )
> +  dwmac_core_disable_dma_irq_tx_all( self );
> +static inline void dwmac_disable_irq_tx_transmitted ( dwmac_common_context *self )
> -  dwmac_core_disable_dma_irq_tx( self );
> +  dwmac_core_disable_dma_irq_tx_transmitted( self );
>  static void dwmac_control_request_complete( const dwmac_common_context *self )
>    rtems_status_code sc = rtems_event_transient_send( self->task_id_control );
>    assert( sc == RTEMS_SUCCESSFUL );
> @@ -1342,263 +1351,275 @@ static void dwmac_task_tx( void *arg )
> -    /* Handle a status change of the ethernet PHY */
> -    if ( ( events & DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE ) != 0 ) {
> -      dwmac_common_phy_status_counts *counts     =
> -        &self->stats.phy_status_counts;
> -      dwmac_phy_event                 phy_events = 0;
> -      int                             eno;
> -      /* Get tripped PHY events */
> -      eno = CALLBACK->phy_events_get(
> -        self->arg,
> -        &phy_events
> -      if ( eno == 0 ) {
> -        /* Clear the PHY events */
> -        eno = CALLBACK->phy_event_clear( self->arg );
> -      if ( eno == 0 ) {
> -        if ( ( phy_events & PHY_EVENT_LINK_DOWN ) != 0 ) {
> -          ++counts->link_down;
> -        if ( ( phy_events & PHY_EVENT_LINK_UP ) != 0 ) {
> -          ++counts->link_up;
> +    while( events != 0 ) {
> +      /* Handle a status change of the ethernet PHY */
> +      if ( ( events & DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE ) != 0 ) {
> +        events &= ~DWMAC_COMMON_EVENT_TX_PHY_STATUS_CHANGE;
> +        dwmac_common_phy_status_counts *counts     =
> +          &self->stats.phy_status_counts;
> +        dwmac_phy_event                 phy_events = 0;
> +        int                             eno;
> +        /* Get tripped PHY events */
> +        eno = CALLBACK->phy_events_get(
> +          self->arg,
> +          &phy_events
> -          /* A link up events means that we have a new connection.
> -           * Thus the autonegotiation paremeters must get updated */
> -          (void) dwmac_update_autonegotiation_params( self );
> +        if ( eno == 0 ) {
> +          /* Clear the PHY events */
> +          eno = CALLBACK->phy_event_clear( self->arg );
> -      assert( eno == 0 );
> +        if ( eno == 0 ) {
> +          if ( ( phy_events & PHY_EVENT_LINK_DOWN ) != 0 ) {
> +            ++counts->link_down;
> -    /* Stop the task */
> -    if ( ( events & DWMAC_COMMON_EVENT_TASK_STOP ) != 0 ) {
> -      dwmac_core_dma_stop_tx( self );
> -      dwmac_diable_irq_tx( self );
> +          if ( ( phy_events & PHY_EVENT_LINK_UP ) != 0 ) {
> +            ++counts->link_up;
> -      /* Release all tx mbufs at the risk of data loss */
> -      ( DESC_OPS->release_tx_bufs )( self );
> +            /* A link up events means that we have a new connection.
> +            * Thus the autonegotiation paremeters must get updated */
> +            (void) dwmac_update_autonegotiation_params( self );
> -      dwmac_control_request_complete( self );
> +        assert( eno == 0 );
> -      /* Return to events reception without re-enabling the interrupts
> -       * The task needs a re-initialization to to resume work */
> -      continue;
> +      /* Stop the task */
> +      if ( ( events & DWMAC_COMMON_EVENT_TASK_STOP ) != 0 ) {
> +        dwmac_core_dma_stop_tx( self );
> +        dwmac_disable_irq_tx_all( self );
> -    /* Ininitialize / Re-initialize transmission handling */
> -    if ( ( events & DWMAC_COMMON_EVENT_TASK_INIT ) != 0 ) {
> -      idx_transmit       = 0;
> -      idx_transmit_first = 0;
> -      idx_transmitted    = 0;
> -      idx_release        = 0;
> -      p_m                = NULL;
> -      is_first           = false;
> -      is_last            = false;
> -      size               = 0;
> -      ( DESC_OPS->init_tx_desc )( self );
> -      dwmac_core_dma_start_tx( self );
> -      dwmac_core_dma_restart_tx( self );
> +        /* Release all tx mbufs at the risk of data loss */
> +        ( DESC_OPS->release_tx_bufs )( self );
> -      /* Clear our interrupt statuses */
> -      dwmac_core_reset_dma_irq_status_tx( self );
> +        dwmac_control_request_complete( self );
> +        /* Return to events reception without re-enabling the interrupts
> +        * The task needs a re-initialization to to resume work */
> +        events = 0;
> +        continue;
> -    /* Try to bump up the dma threshold due to a failure */
> -    if ( ( events & DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD ) != 0 ) {
> -      if ( self->dma_threshold_control
> -           != DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD
> -           && self->dma_threshold_control <= 256 ) {
> -        self->dma_threshold_control += 64;
> -        ( DMA_OPS->dma_mode )(
> -          self,
> -          self->dma_threshold_control,
> -          DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD
> +      /* Ininitialize / Re-initialize transmission handling */
> +      if ( ( events & DWMAC_COMMON_EVENT_TASK_INIT ) != 0 ) {
> +        events &= ~DWMAC_COMMON_EVENT_TASK_INIT;
> +        idx_transmit       = 0;
> +        idx_transmit_first = 0;
> +        idx_transmitted    = 0;
> +        idx_release        = 0;
> +        p_m                = NULL;
> +        is_first           = false;
> +        is_last            = false;
> +        size               = 0;
> +        ( DESC_OPS->init_tx_desc )( self );
> +        dwmac_core_dma_start_tx( self );
> +        dwmac_core_dma_restart_tx( self );
> +        /* Clear our interrupt statuses */
> +        dwmac_core_reset_dma_irq_status_tx( self );
> +        dwmac_enable_irq_tx_default( self );
> -    /* Handle one or more transmitted frames */
> -    if ( ( events & DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED ) != 0 ) {
> -      dwmac_common_tx_frame_counts *counts = &self->stats.frame_counts_tx;
> -      /* Next index to be transmitted */
> -      unsigned int idx_transmitted_next = dwmac_increment(
> -        idx_transmitted, INDEX_MAX );
> -      /* Free consumed fragments */
> -      while ( idx_release != idx_transmitted_next
> -              && ( DESC_OPS->am_i_tx_owner )( self, idx_release ) ) {
> -        /* Status handling per packet */
> -        if ( ( DESC_OPS->get_tx_ls )( self, idx_release ) ) {
> -          int status = ( DESC_OPS->tx_status )(
> -            self, idx_release
> +      /* Try to bump up the dma threshold due to a failure */
> +      if ( ( events & DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD ) != 0 ) {
> +        events &= ~DWMAC_COMMON_EVENT_TX_BUMP_UP_DMA_THRESHOLD;
> +        if ( self->dma_threshold_control
> +            != DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD
> +            && self->dma_threshold_control <= 256 ) {
> +          self->dma_threshold_control += 64;
> +          ( DMA_OPS->dma_mode )(
> +            self,
> +            self->dma_threshold_control,
> +            DWMAC_COMMON_DMA_MODE_STORE_AND_FORWARD
> -          if ( status == 0 ) {
> -            ++counts->packets_tranmitted_by_DMA;
> -          } else {
> -            ++counts->packet_errors;
> -        DWMAC_PRINT_DBG(
> -          "tx: release %u\n",
> -          idx_release
> +      /* Handle one or more transmitted frames */
> +      if ( ( events & DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED ) != 0 ) {
> +        events &= ~DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED;
> +        dwmac_common_tx_frame_counts *counts = &self->stats.frame_counts_tx;
> +        dwmac_disable_irq_tx_transmitted( self );
> +        /* Next index to be transmitted */
> +        unsigned int idx_transmitted_next = dwmac_increment(
> +          idx_transmitted, INDEX_MAX );
> +        /* Free consumed fragments */
> +        if( idx_release != idx_transmitted_next
> +            && ( DESC_OPS->am_i_tx_owner )( self, idx_release ) ) {
> +          while ( idx_release != idx_transmitted_next
> +            /* Status handling per packet */
> +            if ( ( DESC_OPS->get_tx_ls )( self, idx_release ) ) {
> +              int status = ( DESC_OPS->tx_status )(
> +                self, idx_release
> -        /* Release the DMA descriptor */
> -        ( DESC_OPS->release_tx_desc )( self, idx_release );
> +              if ( status == 0 ) {
> +                ++counts->packets_tranmitted_by_DMA;
> +              } else {
> +                ++counts->packet_errors;
> -        /* Release mbuf */
> -        m_free( self->mbuf_addr_tx[idx_release] );
> -        self->mbuf_addr_tx[idx_release] = NULL;
> +            DWMAC_PRINT_DBG(
> +              "tx: release %u\n",
> +              idx_release
> -        /* Next release index */
> -        idx_release = dwmac_increment(
> -          idx_release, INDEX_MAX );
> +            /* Release the DMA descriptor */
> +            ( DESC_OPS->release_tx_desc )( self, idx_release );
> -      /* Clear transmit interrupt status */
> -      self->dmagrp->status = DMAGRP_STATUS_TI;
> +            /* Release mbuf */
> +            m_free( self->mbuf_addr_tx[idx_release] );
> +            self->mbuf_addr_tx[idx_release] = NULL;
> -      if ( ( self->arpcom.ac_if.if_flags & IFF_OACTIVE ) != 0 ) {
> -        /* The last tranmission has been incomplete
> -         * (for example due to lack of DMA descriptors).
> -         * Continue it now! */
> -        events |= DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME;
> +            /* Next release index */
> +            idx_release = dwmac_increment(
> +              idx_release, INDEX_MAX );
> +          if ( ( self->arpcom.ac_if.if_flags & IFF_OACTIVE ) != 0 ) {
> +            /* The last tranmission has been incomplete
> +            * (for example due to lack of DMA descriptors).
> +            * Continue it now! */
> +            events |= DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME;
> +        } else {
> +          /* Clear transmit interrupt status */
> +          self->dmagrp->status = DMAGRP_STATUS_TI;
> +          /* Get re-activated by the next interrupt */
> +          dwmac_enable_irq_tx_transmitted( self );
> -    /* There are one or more frames to be transmitted. */
> -    if ( ( events & DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME ) != 0 ) {
> +      /* There are one or more frames to be transmitted. */
> +      if ( ( events & DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME ) != 0 ) {
> +        events &= ~DWMAC_COMMON_EVENT_TX_TRANSMIT_FRAME;
> -      if ( p_m != NULL ) {
> -        /* This frame will get re-counted */
> -        --counts->frames_from_stack;
> +        if ( p_m != NULL ) {
> +          /* This frame will get re-counted */
> +          --counts->frames_from_stack;
> -      while ( true ) {
> -        unsigned int idx = dwmac_increment(
> -          idx_transmit, INDEX_MAX );
> +        while ( true ) {
> +          unsigned int idx = dwmac_increment(
> +            idx_transmit, INDEX_MAX );
> -        p_m = dwmac_next_fragment(
> -          &self->arpcom.ac_if,
> -          p_m,
> -          &is_first,
> -          &is_last,
> -          &size
> +          p_m = dwmac_next_fragment(
> +            &self->arpcom.ac_if,
> +            p_m,
> +            &is_first,
> +            &is_last,
> +            &size
> -        /* New fragment? */
> -          ++counts->frames_from_stack;
> +          /* New fragment? */
> +            ++counts->frames_from_stack;
> -          /* Queue full? */
> -          if ( idx == idx_release ) {
> -            DWMAC_PRINT_DBG( "tx: full queue: 0x%08x\n", p_m );
> +            /* Queue full? */
> +            if ( idx == idx_release ) {
> +              DWMAC_PRINT_DBG( "tx: full queue: 0x%08x\n", p_m );
> -            /* The queue is full, wait for transmitted interrupt */
> -            break;
> +              /* The queue is full, wait for transmitted interrupt */
> +              break;
> -          /* Set the transfer data */
> -          rtems_cache_flush_multiple_data_lines(
> -            mtod( p_m, const void * ),
> -            size
> +            /* Set the transfer data */
> +            rtems_cache_flush_multiple_data_lines(
> +              mtod( p_m, const void * ),
> +              size
> -          ( DESC_OPS->prepare_tx_desc )(
> -            self,
> -            idx_transmit,
> -            is_first,
> -            size,
> -          self->mbuf_addr_tx[idx_transmit] = p_m;
> +            ( DESC_OPS->prepare_tx_desc )(
> +              self,
> +              idx_transmit,
> +              is_first,
> +              size,
> +            self->mbuf_addr_tx[idx_transmit] = p_m;
> -          ++counts->frames_to_dma;
> -          counts->bytes_to_dma += size;
> -          DWMAC_PRINT_DBG(
> -            "tx: %02" PRIu32 ": %u %s%s\n",
> -            idx_transmit, size,
> -            ( is_first != false ) ? ( "F" ) : ( "" ),
> -            ( is_last != false ) ? ( "L" ) : ( "" )
> +            ++counts->frames_to_dma;
> +            counts->bytes_to_dma += size;
> +            DWMAC_PRINT_DBG(
> +              "tx: %02" PRIu32 ": %u %s%s\n",
> +              idx_transmit, size,
> +              ( is_first != false ) ? ( "F" ) : ( "" ),
> +              ( is_last != false ) ? ( "L" ) : ( "" )
> -          if ( is_first ) {
> -            idx_transmit_first = idx_transmit;
> -            is_first           = false;
> -          } else {
> -            /* To avoid race condition */
> -            ( DESC_OPS->release_tx_ownership )( self, idx_transmit );
> +            if ( is_first ) {
> +              idx_transmit_first = idx_transmit;
> +              is_first           = false;
> +            } else {
> +              /* To avoid race condition */
> +              ( DESC_OPS->release_tx_ownership )( self, idx_transmit );
> -          if ( is_last ) {
> -            /* Interrupt on completition only for the latest fragment */
> -            ( DESC_OPS->close_tx_desc )( self, idx_transmit );
> +            if ( is_last ) {
> +              /* Interrupt on completition only for the latest fragment */
> +              ( DESC_OPS->close_tx_desc )( self, idx_transmit );
> +              ( DESC_OPS->release_tx_ownership )( self, idx_transmit_first );
> +              idx_transmitted = idx_transmit;
> +              if ( ( self->dmagrp->status & DMAGRP_STATUS_TU ) != 0 ) {
> +                /* Re-enable the tranmit DMA */
> +                DWMAC_PRINT_DBG(
> +                  "tx DMA restart: %02u\n",
> -            ( DESC_OPS->release_tx_ownership )( self, idx_transmit_first );
> -            idx_transmitted = idx_transmit;
> +            /* Next transmit index */
> +            idx_transmit = idx;
> -            if ( ( self->dmagrp->status & DMAGRP_STATUS_TU ) != 0 ) {
> -              /* Re-enable the tranmit DMA */
> -              DWMAC_PRINT_DBG(
> -                "tx DMA restart: %02u\n",
> +            if ( is_last ) {
> +              ++counts->packets_to_dma;
> -          /* Next transmit index */
> -          idx_transmit = idx;
> -          if ( is_last ) {
> -            ++counts->packets_to_dma;
> +            /* Next fragment of the frame */
> +            p_m = p_m->m_next;
> +          } else {
> +            /* Nothing to transmit */
> +            break;
> -          /* Next fragment of the frame */
> -          p_m = p_m->m_next;
> +        /* No more packets and fragments? */
> +        if ( p_m == NULL ) {
> +          /* Interface is now inactive */
> +          self->arpcom.ac_if.if_flags &= ~IFF_OACTIVE;
>          } else {
> -          /* Nothing to transmit */
> -          break;
> +          /* There are more packets pending to be sent,
> +          * but we have run out of DMA descriptors.
> +          * We will continue sending once descriptors
> +          * have been freed due to a transmitted interupt */
> +          DWMAC_PRINT_DBG( "tx: transmission incomplete\n" );
> +          events |= DWMAC_COMMON_EVENT_TX_FRAME_TRANSMITTED;
> -      /* No more packets and fragments? */
> -      if ( p_m == NULL ) {
> -        /* Interface is now inactive */
> -        self->arpcom.ac_if.if_flags &= ~IFF_OACTIVE;
> -      } else {
> -        /* There are more packets pending to be sent,
> -         * but we have run out of DMA descriptors.
> -         * We will continue sending once descriptors
> -         * have been freed due to a transmitted interupt */
> -        DWMAC_PRINT_DBG( "tx: transmission incomplete\n" );
> +        /* TODO: Add handling */
> -      /* TODO: Add handling */
> +      DWMAC_PRINT_DBG( "tx: enable transmit interrupts\n" );
> -    DWMAC_PRINT_DBG( "tx: enable transmit interrupts\n" );
> -    /* Re-enable transmit interrupts */
> -    dwmac_enable_irq_tx( self );
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
