[PATCH 2/2] score: SMP initialization changes
Fri Apr 11 15:15:14 UTC 2014
Add and use _CPU_SMP_Start_processor().  Add and use
_CPU_SMP_Finalize_initialization().  This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
 c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c |   41 +++++++++++++--------
 c/src/lib/libbsp/i386/shared/smp/smp-imps.c    |   18 +++++++---
 c/src/lib/libbsp/powerpc/qoriq/startup/smp.c   |   40 ++++++++++++--------
 c/src/lib/libbsp/shared/smp/smp_stub.c         |   11 +++++-
 c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c   |   46 ++++++++---------------
 cpukit/score/cpu/arm/rtems/score/cpu.h         |    6 +++-
 cpukit/score/cpu/i386/rtems/score/cpu.h        |    6 +++-
 cpukit/score/cpu/no_cpu/rtems/score/cpu.h      |   44 ++++++++++++++++++----
 cpukit/score/cpu/powerpc/rtems/score/cpu.h     |    6 +++-
 cpukit/score/cpu/sparc/rtems/score/cpu.h       |    6 +++-
 cpukit/score/include/rtems/score/smpimpl.h     |    3 +-
 cpukit/score/src/smp.c                         |   33 ++++++++++++++---
 12 files changed, 174 insertions(+), 86 deletions(-)
diff --git a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
index 17d6498..6f4af46 100644
--- a/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
+++ b/c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c
@@ -25,28 +25,39 @@ static void bsp_inter_processor_interrupt(void *arg)
   _SMP_Inter_processor_interrupt_handler();
-uint32_t _CPU_SMP_Initialize(uint32_t configured_cpu_count)
+uint32_t _CPU_SMP_Initialize(void)
-  rtems_status_code sc;
-  uint32_t max_cpu_count = arm_gic_irq_processor_count();
-  uint32_t used_cpu_count = configured_cpu_count < max_cpu_count ?
-    configured_cpu_count : max_cpu_count;
+  return arm_gic_irq_processor_count();
-  sc = rtems_interrupt_handler_install(
-    ARM_GIC_IRQ_SGI_0,
-    "IPI",
-    RTEMS_INTERRUPT_UNIQUE,
-    bsp_inter_processor_interrupt,
-    NULL
-  assert(sc == RTEMS_SUCCESSFUL);
+bool _CPU_SMP_Start_processor(uint32_t cpu_index)
+  (void) cpu_index;
+  /* Nothing to do */
+  return true;
+void _CPU_SMP_Finalize_initialization(uint32_t cpu_count)
+  if (cpu_count > 0) {
+    rtems_status_code sc;
-  return used_cpu_count;
+    sc = rtems_interrupt_handler_install(
+      ARM_GIC_IRQ_SGI_0,
+      "IPI",
+      RTEMS_INTERRUPT_UNIQUE,
+      bsp_inter_processor_interrupt,
+      NULL
+    assert(sc == RTEMS_SUCCESSFUL);
 void _CPU_SMP_Send_interrupt( uint32_t target_processor_index )
-  rtems_status_code sc = arm_gic_irq_generate_software_irq(
+  arm_gic_irq_generate_software_irq(
     ARM_GIC_IRQ_SGI_0,
     ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
     (uint8_t) (1U << target_processor_index)
diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
index 1e5faeb..19b23e2 100644
--- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
+++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
@@ -786,16 +786,24 @@ static void secondary_cpu_initialize(void)
   _SMP_Start_multitasking_on_secondary_processor();
-uint32_t _CPU_SMP_Initialize( uint32_t configured_cpu_count )
+uint32_t _CPU_SMP_Initialize( void )
-  int cores;
   /* XXX need to deal with finding too many cores */
-  cores = imps_probe();
+  return (uint32_t) imps_probe();
+bool _CPU_SMP_Start_processor( uint32_t cpu_index )
+  (void) cpu_index;
-  if ( cores > 1 )
+  return true;
+void _CPU_SMP_Finalize_initialization( uint32_t cpu_count )
+  if ( cpu_count > 1 )
     ipi_install_irq();
-  return cores;
diff --git a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
index 2ce0ba7..5b4c12a 100644
--- a/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
+++ b/c/src/lib/libbsp/powerpc/qoriq/startup/smp.c
@@ -141,26 +141,34 @@ static void bsp_inter_processor_interrupt(void *arg)
-  uint32_t cores = configured_cpu_count < CORE_COUNT ?
-    configured_cpu_count : CORE_COUNT;
+  return CORE_COUNT;
-    QORIQ_IRQ_IPI_0,
-    "IPI",
-    NULL
+  (void) cpu_index;
-  if (cores > 1) {
-    release_core_1();
+  release_core_1();
-  return cores;
+  return true;
+  if (cpu_count > 1) {
+      QORIQ_IRQ_IPI_0,
+      "IPI",
+      NULL
 void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
diff --git a/c/src/lib/libbsp/shared/smp/smp_stub.c b/c/src/lib/libbsp/shared/smp/smp_stub.c
index 8165363..3dc44b1 100644
--- a/c/src/lib/libbsp/shared/smp/smp_stub.c
+++ b/c/src/lib/libbsp/shared/smp/smp_stub.c
@@ -11,12 +11,21 @@
 #include <rtems/score/cpu.h>
   /* return the number of CPUs */
   return 1;
+  return true;
diff --git a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
index 2470e76..931fbf0 100644
--- a/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
+++ b/c/src/lib/libbsp/sparc/leon3/smp/smp_leon3.c
@@ -26,53 +26,39 @@ static rtems_isr bsp_inter_processor_interrupt(
-void leon3_secondary_cpu_initialize(uint32_t cpu)
+void leon3_secondary_cpu_initialize(uint32_t cpu_index)
   leon3_set_cache_control_register(0x80000F);
   /* Unmask IPI interrupts at Interrupt controller for this CPU */
-  LEON3_IrqCtrl_Regs->mask[cpu] |= 1 << LEON3_MP_IRQ;
+  LEON3_IrqCtrl_Regs->mask[cpu_index] |= 1U << LEON3_MP_IRQ;
-  uint32_t max_cpu_count;
-  uint32_t used_cpu_count;
-  uint32_t cpu;
-  max_cpu_count = leon3_get_cpu_count(LEON3_IrqCtrl_Regs);
-  used_cpu_count = configured_cpu_count < max_cpu_count ?
+  return leon3_get_cpu_count(LEON3_IrqCtrl_Regs);
   #if defined(RTEMS_DEBUG)
-    printk( "Found %d CPUs\n", max_cpu_count );
-    if ( max_cpu_count > configured_cpu_count ) {
-      printk(
-        "%d CPUs IS MORE THAN CONFIGURED -- ONLY USING %d\n",
-        max_cpu_count,
+    printk( "Waking CPU %d\n", cpu_index );
   #endif
-  if ( used_cpu_count > 1 ) {
-    LEON_Unmask_interrupt(LEON3_MP_IRQ);
-    set_vector(bsp_inter_processor_interrupt, LEON_TRAP_TYPE(LEON3_MP_IRQ), 1);
+  LEON3_IrqCtrl_Regs->mpstat = 1U << cpu_index;
-  for ( cpu = 1 ; cpu < used_cpu_count ; ++cpu ) {
-    #if defined(RTEMS_DEBUG)
-      printk( "Waking CPU %d\n", cpu );
-    #endif
+  return true;
-    LEON3_IrqCtrl_Regs->mpstat = 1 << cpu;
+  if ( cpu_count > 1 ) {
+    LEON_Unmask_interrupt(LEON3_MP_IRQ);
+    set_vector(bsp_inter_processor_interrupt, LEON_TRAP_TYPE(LEON3_MP_IRQ), 1);
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index dc2bbdd..ccf8c9a 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -467,7 +467,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
 void _CPU_Context_validate( uintptr_t pattern );
 #ifdef RTEMS_SMP
-  uint32_t _CPU_SMP_Initialize( uint32_t configured_cpu_count );
+  uint32_t _CPU_SMP_Initialize( void );
+  bool _CPU_SMP_Start_processor( uint32_t cpu_index );
+  void _CPU_SMP_Finalize_initialization( uint32_t cpu_count );
   static inline uint32_t _CPU_SMP_Get_current_processor( void )
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index 296ad8b..be22d9e 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -462,7 +462,11 @@ uint32_t   _CPU_ISR_Get_level( void );
    _CPU_Context_restore( (_the_context) );
 #if defined(RTEMS_SMP)
   uint32_t _CPU_SMP_Get_current_processor( void );
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index c864164..5241b5b 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -1467,19 +1467,47 @@ CPU_Counter_ticks _CPU_Counter_difference(
    * @brief Performs CPU specific SMP initialization in the context of the boot
    * processor.
-   * This function is invoked on the boot processor by RTEMS during
+   * This function is invoked on the boot processor during system
    * initialization.  All interrupt stacks are allocated at this point in case
-   * the CPU port allocates the interrupt stacks.
+   * the CPU port allocates the interrupt stacks.  This function is called
+   * before _CPU_SMP_Start_processor() or _CPU_SMP_Finalize_initialization() is
+   * used.
-   * The CPU port should start secondary processors now.
+   * @return The count of physically or virtually available processors.
+   * Depending on the configuration the application may use not all processors.
+   * @brief Starts a processor specified by its index.
+   * initialization.
+   * This function will be called after _CPU_SMP_Initialize().
+   * @param[in] cpu_index The processor index.
+   * @retval true Successful operation.
+   * @retval false Unable to start this processor.
+   * @brief Performs final steps of CPU specific SMP initialization in the
+   * context of the boot processor.
+   * initialization.
-   * @param[in] configured_cpu_count The count of processors requested by the
-   * application configuration.
+   * This function will be called after all processors requested by the
+   * application have been started.
-   * @return The count of processors available for the application in the system.
-   * This value is less than or equal to the configured count of processors.
+   * @param[in] cpu_count The minimum value of the count of processors
+   * requested by the application configuration and the count of physically or
+   * virtually available processors.
    * @brief Returns the index of the current processor.
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index a7cad2e..3130b35 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -1034,7 +1034,11 @@ void _CPU_Context_volatile_clobber( uintptr_t pattern );
 #ifdef RTEMS_SMP
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index ea092af..d3ebf3e 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -1161,7 +1161,11 @@ void _CPU_Context_restore(
 ) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
   #if defined(__leon__)
diff --git a/cpukit/score/include/rtems/score/smpimpl.h b/cpukit/score/include/rtems/score/smpimpl.h
index c32d4a2..962c7f2 100644
--- a/cpukit/score/include/rtems/score/smpimpl.h
+++ b/cpukit/score/include/rtems/score/smpimpl.h
@@ -48,7 +48,8 @@ extern "C" {
 typedef enum {
   SMP_FATAL_SHUTDOWN,
-  SMP_FATAL_SHUTDOWN_EARLY
+  SMP_FATAL_SHUTDOWN_EARLY,
+  SMP_FATAL_UNABLE_TO_START_PROCESSOR
 } SMP_Fatal_code;
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index bfb09dd..4b585ee 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -26,11 +26,13 @@
 void _SMP_Handler_initialize( void )
-  uint32_t max_cpus = rtems_configuration_get_maximum_processors();
-  uint32_t cpu;
+  uint32_t cpu_max = rtems_configuration_get_maximum_processors();
+  uint32_t cpu_self;
+  uint32_t cpu_count;
+  uint32_t cpu_index;
-  for ( cpu = 0 ; cpu < max_cpus; ++cpu ) {
-    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu );
+  for ( cpu_index = 0 ; cpu_index < cpu_max; ++cpu_index ) {
+    Per_CPU_Control *per_cpu = _Per_CPU_Get_by_index( cpu_index );
     _SMP_ticket_lock_Initialize( &per_cpu->Lock, "per-CPU" );
@@ -38,9 +40,28 @@ void _SMP_Handler_initialize( void )
    * Discover and initialize the secondary cores in an SMP system.
-  max_cpus = _CPU_SMP_Initialize( max_cpus );
-  _SMP_Processor_count = max_cpus;
+  cpu_count = _CPU_SMP_Initialize();
+  cpu_count = cpu_count < cpu_max ? cpu_count : cpu_max;
+  _SMP_Processor_count = cpu_count;
+  cpu_self = _SMP_Get_current_processor();
+  for ( cpu_index = 0 ; cpu_index < cpu_count; ++cpu_index ) {
+    if ( cpu_index != cpu_self ) {
+      bool ok = _CPU_SMP_Start_processor( cpu_index );
+      if ( !ok ) {
+        _Terminate(
+          RTEMS_FATAL_SOURCE_SMP,
+          false,
+  _CPU_SMP_Finalize_initialization( cpu_count );
 void _SMP_Request_start_multitasking( void )
1.7.7
