[rtems commit] rtems: Add task get/set scheduler
Joel Sherrill
Joel.Sherrill at OARcorp.com
Tue Apr 15 12:36:18 UTC 2014
You added to the API and added no documentation.
On Apr 15, 2014 4:13 AM, Sebastian Huber <sebh at rtems.org> wrote:
Module: rtems
Branch: master
Commit: 27270b0d6c1ec6ff7bca2ffc5a8c25b45d260165
Changeset: http://git.rtems.org/rtems/commit/?id=27270b0d6c1ec6ff7bca2ffc5a8c25b45d260165
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date: Wed Apr 9 10:09:39 2014 +0200
cpukit/rtems/Makefile.am | 2 +
cpukit/rtems/include/rtems/rtems/tasks.h | 35 ++++++++++
cpukit/rtems/src/taskgetscheduler.c | 60 +++++++++++++++++
cpukit/rtems/src/tasksetscheduler.c | 58 ++++++++++++++++
cpukit/score/include/rtems/score/schedulerimpl.h | 25 +++++++
testsuites/sptests/spscheduler01/init.c | 78 +++++++++++++++++++++-
6 files changed, 257 insertions(+), 1 deletions(-)
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index ff3e605..4b84fa1 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -94,6 +94,7 @@ librtems_a_SOURCES += src/taskcreate.c
librtems_a_SOURCES += src/taskdelete.c
librtems_a_SOURCES += src/taskgetaffinity.c
librtems_a_SOURCES += src/taskgetnote.c
+librtems_a_SOURCES += src/taskgetscheduler.c
librtems_a_SOURCES += src/taskident.c
librtems_a_SOURCES += src/taskinitusers.c
librtems_a_SOURCES += src/taskissuspended.c
@@ -104,6 +105,7 @@ librtems_a_SOURCES += src/taskself.c
librtems_a_SOURCES += src/tasksetaffinity.c
librtems_a_SOURCES += src/tasksetnote.c
librtems_a_SOURCES += src/tasksetpriority.c
+librtems_a_SOURCES += src/tasksetscheduler.c
librtems_a_SOURCES += src/taskstart.c
librtems_a_SOURCES += src/tasksuspend.c
librtems_a_SOURCES += src/taskwakeafter.c
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 21c0166..9101d9c 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -542,6 +542,41 @@ rtems_status_code rtems_task_set_affinity(
#endif
+ * @brief Gets the scheduler of a task.
+ * @param[in] id Identifier of the task. Use @ref RTEMS_SELF to select the
+ * executing task.
+ * @param[out] scheduler_id Identifier of the scheduler.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a scheduler_id parameter is @c NULL.
+ * @retval RTEMS_INVALID_ID Invalid task identifier.
+rtems_status_code rtems_task_get_scheduler(
+ rtems_id id,
+ rtems_id *scheduler_id
+ * @brief Sets the scheduler of a task.
+ * executing task.
+ * @param[in] scheduler_id Identifier of the scheduler.
+ * @retval RTEMS_INVALID_ID Invalid task or scheduler identifier.
+ * @retval RTEMS_INCORRECT_STATE The task is in the wrong state to perform a
+ * scheduler change.
+ * @see rtems_scheduler_ident().
+rtems_status_code rtems_task_set_scheduler(
+ rtems_id id,
+ rtems_id scheduler_id
* @brief RTEMS Get Self Task Id
* This directive returns the ID of the currently executing task.
diff --git a/cpukit/rtems/src/taskgetscheduler.c b/cpukit/rtems/src/taskgetscheduler.c
new file mode 100644
index 0000000..7111093
--- /dev/null
+++ b/cpukit/rtems/src/taskgetscheduler.c
@@ -0,0 +1,60 @@
+ * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+#include <rtems/score/schedulerimpl.h>
+ rtems_id id,
+ rtems_status_code sc;
+ if ( scheduler_id != NULL ) {
+ Thread_Control *the_thread;
+ Objects_Locations location;
+ const Scheduler_Control *scheduler;
+ the_thread = _Thread_Get( id, &location );
+ switch ( location ) {
+ case OBJECTS_LOCAL:
+ scheduler = _Scheduler_Get( the_thread );
+ *scheduler_id = _Scheduler_Build_id(
+ _Scheduler_Get_index( scheduler )
+ _Objects_Put( &the_thread->Object );
+ sc = RTEMS_SUCCESSFUL;
+ break;
+#if defined(RTEMS_MULTIPROCESSING)
+ case OBJECTS_REMOTE:
+ _Thread_Dispatch();
+ sc = RTEMS_ILLEGAL_ON_REMOTE_OBJECT;
+ break;
+#endif
+ default:
+ sc = RTEMS_INVALID_ID;
+ break;
+ } else {
+ sc = RTEMS_INVALID_ADDRESS;
+ return sc;
diff --git a/cpukit/rtems/src/tasksetscheduler.c b/cpukit/rtems/src/tasksetscheduler.c
index 0000000..42c08bb
--- /dev/null
+++ b/cpukit/rtems/src/tasksetscheduler.c
@@ -0,0 +1,58 @@
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+#if HAVE_CONFIG_H
+#endif
+ rtems_id id,
+ if ( _Scheduler_Get_by_id( scheduler_id, &scheduler ) ) {
+ bool ok;
+ ok = _Scheduler_Set( scheduler, the_thread );
+ sc = ok ? RTEMS_SUCCESSFUL : RTEMS_INCORRECT_STATE;
+ break;
+ break;
+#endif
+ default:
+ break;
+ } else {
+ return sc;
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index 2b8782f..8b80db7 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -451,6 +451,24 @@ RTEMS_INLINE_ROUTINE const Scheduler_Control *_Scheduler_Get(
return &_Scheduler_Table[ 0 ];
+RTEMS_INLINE_ROUTINE bool _Scheduler_Set(
+ const Scheduler_Control *scheduler,
+ bool ok;
+ (void) scheduler;
+ if ( _States_Is_dormant( the_thread->current_state ) ) {
+ ok = true;
+ } else {
+ ok = false;
+ return ok;
RTEMS_INLINE_ROUTINE Objects_Id _Scheduler_Build_id( uint32_t scheduler_index )
return _Objects_Build_id(
@@ -474,6 +492,13 @@ RTEMS_INLINE_ROUTINE bool _Scheduler_Get_by_id(
return index < _Scheduler_Count;
+RTEMS_INLINE_ROUTINE uint32_t _Scheduler_Get_index(
+ return (uint32_t) (scheduler - &_Scheduler_Table[ 0 ]);
#ifdef __cplusplus
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index 655568d..6c19abc 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -102,6 +102,81 @@ static void test_task_get_set_affinity(void)
#endif /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
+static void task(rtems_task_argument arg)
+ (void) arg;
+ rtems_test_assert(0);
+static void test_task_get_set_scheduler(void)
+ rtems_id self_id = rtems_task_self();
+ rtems_name name = BLUE;
+ rtems_id scheduler_id;
+ rtems_id scheduler_by_name;
+ rtems_id task_id;
+ sc = rtems_scheduler_ident(name, &scheduler_by_name);
+ rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ sc = rtems_task_get_scheduler(RTEMS_SELF, NULL);
+ rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+ sc = rtems_task_get_scheduler(invalid_id, &scheduler_id);
+ rtems_test_assert(sc == RTEMS_INVALID_ID);
+ scheduler_id = 0;
+ sc = rtems_task_get_scheduler(RTEMS_SELF, &scheduler_id);
+ rtems_test_assert(scheduler_id == scheduler_by_name);
+ scheduler_id = 0;
+ sc = rtems_task_get_scheduler(self_id, &scheduler_id);
+ sc = rtems_task_set_scheduler(invalid_id, scheduler_id);
+ sc = rtems_task_set_scheduler(self_id, invalid_id);
+ sc = rtems_task_set_scheduler(self_id, scheduler_id);
+ rtems_test_assert(sc == RTEMS_INCORRECT_STATE);
+ sc = rtems_task_create(
+ rtems_build_name('T', 'A', 'S', 'K'),
+ 2,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &task_id
+ scheduler_id = 0;
+ sc = rtems_task_get_scheduler(task_id, &scheduler_id);
+ sc = rtems_task_set_scheduler(task_id, scheduler_id);
+ sc = rtems_task_start(task_id, task, 0);
+ sc = rtems_task_delete(task_id);
static void test_scheduler_ident(void)
@@ -184,6 +259,7 @@ static void Init(rtems_task_argument arg)
rtems_resource_snapshot_take(&snapshot);
test_task_get_set_affinity();
+ test_task_get_set_scheduler();
test_scheduler_ident();
test_scheduler_get_processors();
@@ -198,7 +274,7 @@ static void Init(rtems_task_argument arg)
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
rtems-vc mailing list
rtems-vc at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-vc
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140415/c2919f08/attachment.html>
