heapwalk failing on sis
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Apr 15 16:41:26 UTC 2014
Hi
Again.. failing for a while
*** BEGIN OF TEST HEAPWALK ***
start with a system state != SYSTEM_STATE_UP
testing the _Heap_Walk_check_control() function
test what happens if page size = 0
set page size to a not CPU-aligned value
set minimal block size to a not page aligned value
set allocation area of the first block to be non page-aligned
clear the previous used flag of the first block
mark last block as free
set invalid next block for last block
testing the _Heap_Walk_check_free_list() function
no free blocks
create a loop in the free list
../../../../../../../rtems/c/src/../../testsuites/libtests/heapwalk/init.c:
57 retval == expectet_retval
