Patch for Re: lm32 tools do not build on makeinfo 5.1
Wed Apr 16 03:41:57 UTC 2014
On 16/04/2014 6:25 am, Joel Sherrill wrote:
> Attached is a patch for this.
> Chris.. can you do the magic of putting it in the RSB for me?
> I will happily test it if you do that. I am swamped.
Sure. I am looking at a gdb-7.7 issue with the lm32 on MacOS. There is
some gdb code clang is not liking. This is a similar type of patch the
bfin and h8300 tripped ...
http://git.rtems.org/rtems-tools/tree/tools/4.11/gdb/gdb-sim-arange-inline.diff?id=f756b51af3b397bd755320600b993c3a52e6991f
It is a gdb PR. I assume the gdb project watches these like gcc does.
