nios2 - gdb 7.0 info does not build with makeinfo 5.0
Wed Apr 16 03:48:36 UTC 2014
On 16/04/2014 7:58 am, Joel Sherrill wrote:
> Is there a reason the NIOS2 is stuck at gdb 7.0?
Not that I know of. I have not tested it. If gdb-7.7 builds we should
switch. We should also switch binutils to the latest. I am currently
using them with the Altera gcc because the older ones failed to build on
FreeBSD 10. I seem to remember Sebastian saying something about NIOS
support being gcc-4.9 which is close. I have not used it.
