[PATCH] sapi: Error case for CONFIGURE_UNLIMITED_OBJECTS
Wed Apr 16 03:55:41 UTC 2014
On 15/04/2014 9:33 pm, Sebastian Huber wrote:
>   cpukit/sapi/include/confdefs.h |    6 ++++++
>   1 files changed, 6 insertions(+), 0 deletions(-)
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index c8a9d0e..8b9b3e1 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -1583,6 +1583,12 @@ const rtems_libio_helper rtems_fs_init_helper =
>    * classic or posix objects that have not already been given resource limits.
>   #if defined(CONFIGURE_UNLIMITED_OBJECTS)
> +  #if !defined(CONFIGURE_UNIFIED_WORK_AREAS) && \
> +     !defined(CONFIGURE_EXECUTIVE_RAM_SIZE) && \
> +     !defined(CONFIGURE_MEMORY_OVERHEAD)
> +     #error "Using CONFIGURE_UNLIMITED_OBJECTS with a pre-calculated work space size makes no sense"
> +  #endif
>     #if !defined(CONFIGURE_UNLIMITED_ALLOCATION_SIZE)
>      * This macro specifies a default allocation size for when auto-extending
The use case is (was?) a fixed size or bounded pool of memory that can
be used in different ways depending on what is being run depending on
how the app is configured. I am not fussed either way what happens here
as the unified work areas is a nice feature.
