[PATCH 5/8] doc: rtems_scheduler_ident()
Wed Apr 16 14:15:47 UTC 2014
 doc/user/smp.t |   36 ++++++++++++++++++++++++++++++++++++
 1 files changed, 36 insertions(+), 0 deletions(-)
diff --git a/doc/user/smp.t b/doc/user/smp.t
index ced8fdf..ebeb3bb 100644
--- a/doc/user/smp.t
+++ b/doc/user/smp.t
@@ -296,6 +296,42 @@ thread dispatching disabled.
 None.
 @c
+ at c rtems_scheduler_ident
+ at c
+ at page
+ at subsection SCHEDULER_IDENT - Get ID of a scheduler
+ at subheading CALLING SEQUENCE:
+ at ifset is-C
+ at example
+rtems_status_code rtems_scheduler_ident(
+  rtems_name  name,
+  rtems_id   *id
+ at end example
+ at end ifset
+ at ifset is-Ada
+ at end ifset
+ at subheading DIRECTIVE STATUS CODES:
+ at code{@value{RPREFIX}SUCCESSFUL} - successful operation@*
+ at code{@value{RPREFIX}INVALID_ADDRESS} - @code{id} is NULL@*
+ at code{@value{RPREFIX}INVALID_NAME} - invalid scheduler name
+ at subheading DESCRIPTION:
+Identifies a scheduler by its name.  The scheduler name is determined by the
+scheduler configuration.  @xref{Configuring a System Configuring
+Clustered/Partitioned Schedulers}.
+ at subheading NOTES:
+None.
+ at c
 @c rtems_task_get_affinity
 @c
 @page
1.7.7
