spintrcricitical20 failure
Wed Apr 16 15:31:56 UTC 2014
On 4/16/2014 3:09 AM, Sebastian Huber wrote:
> On 2014-04-15 18:40, Joel Sherrill wrote:
>> Hi
>> This has been failing a while. Any ideas?
>> *** BEGIN OF TEST SPINTRCRITICAL 20 ***
>> Support - rtems_timer_create - creating timer 1
>> ../../../../../../../rtems/c/src/../../testsuites/sptests/spintrcritical20/init.c:
>> 139 ctx->thread_queue_was_null
> The spintrcritical* tests are timing dependent and sporadically fail.
Does it run anywhere for you?
