spfatal26 on jmr3904
Thu Apr 17 06:18:59 UTC 2014
On 2014-04-17 01:20, Joel Sherrill wrote:
> Hi
> The jmr3904 simulator faults before the exception is generated.
> RTEMS can't catch the exception and generate a fatal error.
> Any thoughts?
> *** BEGIN OF TEST SPFATAL 26 ***
> Breakpoint 4, Init (arg=<optimized out>)
>      at
> ../../../../../../../rtems/c/src/../../testsuites/sptests/spfatal26/init.c:56
> 56      provoke_aligment_or_data_access_exception();
> (gdb) s
> provoke_aligment_or_data_access_exception ()
>      at
> ../../../../../../../rtems/c/src/../../testsuites/sptests/spfatal26/init.c:35
> 35      *(volatile uint64_t *) base;
> (gdb) si
> mips-core: 4 byte read to unmapped address 0x4 at 0x880002e8
> Program received signal SIGBUS, Bus error.
>      at
The simulator lacks support for this exception.  On SIS you get for example:
Memory exception at 80000000 (illegal address)
Breakpoint 2, _Terminate (the_source=RTEMS_FATAL_SOURCE_EXCEPTION,
is_internal=false, the_error=33773240) at
/home/sh/rtems-4.11/c/src/../../cpukit/score/src/interr.c:39
39        _ISR_Disable_without_giant( level );
(gdb) where
#0  _Terminate (the_source=RTEMS_FATAL_SOURCE_EXCEPTION, is_internal=false,
the_error=33773240) at /home/sh/rtems-4.11/c/src/../../cpukit/score/src/interr.c:39
#1  0x020051c0 in rtems_fatal (source=RTEMS_FATAL_SOURCE_EXCEPTION,
error=33773240) at /home/sh/rtems-4.11/c/src/../../cpukit/sapi/src/fatal2.c:34
#2  0x02002064 in bsp_spurious_handler (trap=265, isf=0x203a6a8) at
/home/sh/rtems-4.11/c/src/lib/libbsp/sparc/erc32/startup/spurious.c:131
#3  0x02028370 in dont_fix_pil2 () at
/home/sh/rtems-4.11/c/src/lib/libbsp/sparc/erc32/../../sparc/shared/irq_asm.S:464
#4  0x02028370 in dont_fix_pil2 () at
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
