[PATCH] doc: Setting Affinity to a Single Processor
Thu Apr 17 06:24:45 UTC 2014
 doc/user/smp.t |   28 ++++++++++++++++++++--------
 1 files changed, 20 insertions(+), 8 deletions(-)
diff --git a/doc/user/smp.t b/doc/user/smp.t
index f710537..3d9cc29 100644
--- a/doc/user/smp.t
+++ b/doc/user/smp.t
@@ -201,20 +201,32 @@ building RTEMS in SMP configuration.
 @subsection Setting Affinity to a Single Processor
-In many embedded applications targeting SMP systems, it is common to lock individual tasks to specific cores. In this way, one can designate a core for I/O tasks, another for computation, etc.. The following illustrates the code sequence necessary to assign a task an affinity for processor zero (0).
+On some embedded applications targeting SMP systems, it may be beneficial to
+lock individual tasks to specific processors.  In this way, one can designate a
+processor for I/O tasks, another for computation, etc..  The following
+illustrates the code sequence necessary to assign a task an affinity for
+processor with index @code{processor_index}.
 @example
-rtems_status_code sc;
-cpu_set_t         set;
+ at group
+#include <rtems.h>
+#include <assert.h>
-CPU_EMPTY( &set );
-CPU_SET( 0, &set );
+void pin_to_processor(rtems_id task_id, int processor_index)
+  rtems_status_code sc;
+  cpu_set_t         cpuset;
-sc = rtems_task_set_affinity(rtems_task_self(), sizeof(set), &set);
-assert(sc == RTEMS_SUCCESSFUL);
+  CPU_ZERO(&cpuset);
+  CPU_SET(processor_index, &cpuset);
+  sc = rtems_task_set_affinity(task_id, sizeof(cpuset), &cpuset);
+  assert(sc == RTEMS_SUCCESSFUL);
+ at end group
 @end example
-It is important to note that the @code{cpu_set_t} is not validated until the
+It is important to note that the @code{cpuset} is not validated until the
 @code{@value{DIRPREFIX}task_set_affinity} call is made. At that point,
 it is validated against the current system configuration.
1.7.7
