[PATCH 1/4] capture: Fix capture engine to handle new extensions.
Fri Apr 18 16:53:39 UTC 2014
On 04/18/2014 05:02 PM, Jennifer Averett wrote:
> The terminate method was added to rtems_extensions_table.  This
> resulted in NULL or random addresses being called at task termination.
I doubt that you saw calls of the NULL pointer.  The bug is that the
capture engine uses a rtems_extensions_table variable on the stack
without a memset() to zero.  It would be better to use a static const
variable.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
