[PATCH] testsuite: Add a per BSP test check for tests not to build.
Thu Apr 24 06:33:28 UTC 2014
On 2014-04-24 07:44, Chris Johns wrote:
> Provide a file per BSP to list tests that do not build for a BSP. This change
> removes the BSP_SMALL_MEMORY hack from the code. That hack was a
> mistake.
> Provide configuration files for each BSP with tests that cannot build.
>   .../lm3s69xx/make/custom/lm3s3749-testsuite.cfg    | 29 +++++++
I think with this *.cfg pattern you can now build a "lm3s3749-testsuite" BSP.
Maybe use "lm3s3749.testcfg"?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
