[PATCH] testsuite: Add a per BSP test check for tests not to build.
Thu Apr 24 06:50:09 UTC 2014
On 24/04/2014 4:33 pm, Sebastian Huber wrote:
> On 2014-04-24 07:44, Chris Johns wrote:
>> Provide a file per BSP to list tests that do not build for a BSP. This
>> change
>> removes the BSP_SMALL_MEMORY hack from the code. That hack was a
>> mistake.
>> Provide configuration files for each BSP with tests that cannot build.
>>   .../lm3s69xx/make/custom/lm3s3749-testsuite.cfg    | 29 +++++++
> I think with this *.cfg pattern you can now build a "lm3s3749-testsuite"
> BSP. Maybe use "lm3s3749.testcfg"?
Haha yeah that is an interesting side effect I had not considered. I
will change this.
