Tests Known To Fail with Simulator Idle Clock
Fri Apr 25 18:56:51 UTC 2014
Hi
As Chris is wrapping up the work on not building the BSP/test
combinations which are known to run out of memory when
linking, I thought I would gather the information about another
large class of test failures.
Some BSPs are for simulators. Some of those simulators do not
support interrupts or a clock tick source.[1] Thus the only way to
mimic the passage of time is with the "sim clock idle" code. This
is a clock device driver which is just an idle task which calls
rtems_clock_tick() until some higher priority task is unblocked
and it is preempted.
Some tests were designed to assume a real clock tick which can
result in a preemption even from a busy loop. These tests may
or may not need to assume that but, at the moment, they do.
I am certain that sp04 and *intrcrit* do indeed require a clock
tick interrupt to work.
I have attached a list of the 24 BSPs which use the simulated
clock tick and the 47 tests which will never complete execution
without a real interrupt driven clock tick.
When running the tests, these are known to fail but this is not
accounted for by anything in the build or test framework. These
tests will run until a time limit is reached. On most of our simulator
scripts, this is 180 seconds.
For a single test execution cycle, this wastes approximately 142
minutes per BSP with this characteristic. Over 24 BSPs, that is
about 56 hours and 15 minutes wasted.
There are two possibilities of what to do:
+ not build these for these BSPs
+ build but do not execute these for these BSPs
Personally I like building them and not executing them. It is better
to build all the code we can for tool and RTEMS integrity purposes.
Whatever we decide to do, I think we should think in generic
terms that "test X requires capability Y which a BSP may or may
not provide". How can we say BSP does not have capability Y?
And thus have a master list of tests which need that capability.
My first thought was to integrate this information into
rtems-testing/sim-scripts. This would build them but not execute
them. If we take this approach, this would have to be integrated
into the rtems-test framework as it matures.
They could also be integrated into Chris' "do not build"
framework which was posted this week.
I would like some discussion on this. Addressing this in a general
way is important to getting accurate and quality test results and
being able to execute them in a reasonable length of time.
[1] Why use these simulators? We use them because they are
sufficient to test most of RTEMS, run all of the GCC tests, usually
are sufficient to debug an architecture specific problem that
is not interrupt related, and are often built into GDB.
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
qemuppc
simsh1
simsh2
simsh2e
simsh4
niagara
usiii
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
cpuuse
psx07
psx09
psx10
psx11
psxcancel01
psxgetrusage01
psxintrcritical01
psxsignal01
psxsignal02
psxspin01
psxtime
psxtimes01
sp04
sp14
sp19
sp35
sp38
sp44
sp69
spcbssched02
spcbssched03
spcontext01
spcpucounter01
spedfsched03
spintrcritical01
spintrcritical02
spintrcritical03
spintrcritical04
spintrcritical05
spintrcritical06
spintrcritical07
spintrcritical08
spintrcritical09
spintrcritical10
spintrcritical11
spintrcritical12
spintrcritical13
spintrcritical14
spintrcritical15
spintrcritical16
spintrcritical17
spintrcritical18
spintrcritical19
spintrcritical20
spnsext01
spqreslib
