[PATCH] score: Split _Terminate and call _Terminate_CPU_Fatal_halt.
Chris Johns
chrisj at rtems.org
Sun Apr 27 12:13:41 UTC 2014
Splitting the call to _CPU_Fatal_halt out into a separate function
allows the rtems-test gdb support the ability to halt once the
_Terminate function has completed it's work.
This change allows the BeagleBoard xM BSP to pass a number of
important tests.
cpukit/score/include/rtems/score/basedefs.h | 14 +++++++++++++-
cpukit/score/include/rtems/score/interr.h | 18 ++++++++++++++++++
cpukit/score/src/interr.c | 9 ++++++++-
3 files changed, 39 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/include/rtems/score/basedefs.h b/cpukit/score/include/rtems/score/basedefs.h
index a0bebdd..bab9a33 100644
--- a/cpukit/score/include/rtems/score/basedefs.h
+++ b/cpukit/score/include/rtems/score/basedefs.h
@@ -174,6 +174,18 @@
#endif
+ * The following defines a compiler specific attribute which makes a
+ * function weak. Weak symbols can be overriden by normal symbols and
+ * provide a way for users to override symbols that are weak.
+#ifdef __GNUC__
+ #define RTEMS_COMPILER_WEAK_ATTRIBUTE \
+ __attribute__ ((weak))
+#else
+#endif
* Instructs the compiler to issue a warning whenever a variable or function
* with this attribute will be used.
@@ -189,7 +201,7 @@
* This can occur when reading volatile device memory or skipping arguments
* in a variable argument method.
-#if defined(__GNUC__)
+#if defined(__GNUC__)
#define RTEMS_COMPILER_UNUSED_ATTRIBUTE __attribute__((unused))
#else
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 2100c13..0627a1f 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -217,6 +217,24 @@ void _Terminate(
Internal_errors_t the_error
) RTEMS_COMPILER_NO_RETURN_ATTRIBUTE;
+ * @brief Invoke CPU fatal halt.
+ * The @ref _Terminate function's final step is to call this function and
+ * it invokes the CPU fatal halt code. The function's attribute is weak
+ * allowing a BSP the ability to override this function and provide a
+ * suitable reset.
+ * This function allows a test harness the ability to see the terminate
+ * function has completed.
+ * @param[in] the_error The fatal error code. This value must be interpreted
+ * with respect to the source.
+void _Terminate_CPU_Fatal_halt(
+ Internal_errors_t the_error
+) RTEMS_COMPILER_WEAK_ATTRIBUTE;
#ifdef __cplusplus
#endif
diff --git a/cpukit/score/src/interr.c b/cpukit/score/src/interr.c
index 97ca3c7..48cd26b 100644
--- a/cpukit/score/src/interr.c
+++ b/cpukit/score/src/interr.c
@@ -28,6 +28,13 @@ System_state_Codes _System_state_Current;
Internal_errors_Information _Internal_errors_What_happened;
+ _CPU_Fatal_halt( the_error );
void _Terminate(
Internal_errors_Source the_source,
bool is_internal,
@@ -49,7 +56,7 @@ void _Terminate(
_System_state_Set( SYSTEM_STATE_TERMINATED );
- _CPU_Fatal_halt( the_error );
+ _Terminate_CPU_Fatal_halt( the_error );
/* will not return from this routine */
while (true);
1.9.0
