Possible bug at newlib/libc/rtems/sys/crt0.c sigfillset
Joel Sherrill Joel.Sherrill at OARcorp.com
Mon Apr 28 00:26:57 UTC 2014
This is a bug in your gcc port. You need to ensure that __rtems__ is defined.
See https://github.com/heshamelmatary/or1k-rtems/blob/master/patches/gcc-4.8.2-or1k-rtems.diff
around 220 and compare it to
http://gcc.gnu.org/git/?p=gcc.git;a=blob;f=gcc/config/arm/rtems-eabi.h;h=4bdcf0d87ba68940f338f4de3b41b9bd7a47260f;hb=HEAD
That defines __rtems__. Without that, the .h files in newlib don't get the right settings.
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On Behalf Of Joel Sherrill [Joel.Sherrill at oarcorp.com]
Sent: Sunday, April 27, 2014 7:17 PM
To: Hesham Moustafa
Cc: rtems-devel at rtems.org
Subject: Re: Possible bug at newlib/libc/rtems/sys/crt0.c sigfillset
On Apr 27, 2014 6:40 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
> On Apr 27, 2014 5:12 PM, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
> > Hi all,
> > When I am trying to get newlib compiled while porting newlib to
> > rtems/or1k, I met an error that confused me. The error happens for me
> > with both: Ubuntu and Fedora. Also it arises when configuring and
> > building a standalone newlib library (with configure
> > --target=or1k-rtems4.11) or when building gcc with newlib (for the
> > same target). By commenting that line, newlib and gcc building process
> > works fine.
> > The error is:
> > "../../../../../../../gcc-4.8.2-or1k-rtems/newlib/libc/sys/rtems/crt0.c:74:37:
> > error: expected ‘)’ before ‘*’ token
> >  RTEMS_STUB(int, sigfillset(sigset_t *set), { return -1; })"
> > By expanding the macros with -E option, I got the following expansion
> > for the corresponding function:
> > int rtems_stub_sigfillset(sigset_t *set) { return -1; }; int
> > (*(sigset_t *set) = ~(0), 0) { return -1; }
> > Does that make sense?
> > I searched for anyone that happened to have the same problem and I
> > found this link [1] related to compiling rtems/newlib for microblaze
> This is a new architecture for RTEMS+newlib combination. I recall that there is a configure script near the top of newlib and it needs an entry for thus target. Or a pattern needs adjusting to distinguish or1k*-*-* from the RTEMS variant.
This can also be because the path through signal.h is skipping something based on or1k.
What source are you using as base to modify? I need to clone all your source and try it myself.
> > [1] http://sourceware.org/ml/newlib/2012/msg00529.html
> > Regards,
> > Hesham
> > rtems-devel mailing list
> > http://www.rtems.org/mailman/listinfo/rtems-devel
