MIPS Thread Local Storage Help Request
Mon Apr 28 18:47:28 UTC 2014
Hi
This is going to be interesting. MIPS TLS is broken because
we don't have a trap handler for this. From GCC:
;; Thread-Local Storage
;; The TLS base pointer is accessed via "rdhwr $3, $29".  No current
;; MIPS architecture defines this register, and no current
;; implementation provides it; instead, any OS which supports TLS is
;; expected to trap and emulate this instruction.  rdhwr is part of the
;; MIPS 32r2 specification, but we use it on any architecture because
;; we expect it to be emulated.  Use .set to force the assembler to
;; accept it.
;; We do not use a constraint to force the destination to be $3
;; because $3 can appear explicitly as a function return value.
;; If we leave the use of $3 implicit in the constraints until
;; reload, we may end up making a $3 return value live across
;; the instruction, leading to a spill failure when reloading it.
This code from NetBSD appears to be the core part of the
handler.
http://cvsweb.netbsd.org/bsdweb.cgi/src/sys/arch/mips/mips/locore_mips3.S?only_with_tag=MAIN
If someone can adapt this, then the MIPS will have working
TLS.
Thanks.
