SD card libblock bdpart linker problem
Andre Marques
andre.lousa.marques at gmail.com
Mon Apr 28 18:56:57 UTC 2014
Hello,
I am currently working on an emmc driver for the Raspberry Pi, and I am
trying to mount the SD card using libblock on RTEMS GIT HEAD.
To mount the SD card I am doing:
1. rtems_io_register_driver (by calling my driver with
CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
2. rtems_filesystem_make_dev_t to get the device file
3. rtems_disk_io_initialize
4. rtems_disk_create_phys
Up until this point everything seems good.
Next I try to read the SD card partition table with
rtems_bdpart_register_from_disk, and for that I add an include for
rtems/bdpart.h
When I hit compile, the result seems to point at a linker problem
(conflict with dummy.o):
Making all in hello
gmake[6]: Entering directory
`/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello'
arm-rtems4.11-gcc -B../../../../../raspberrypi/lib/ -specs bsp_specs
-qrtems -DHAVE_CONFIG_H -I.
-I/home/bison/RTEMS/code/c/src/../../testsuites/samples/hello -I..
-mcpu=arm1176jzf-s -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
init.o -MD -MP -MF .deps/init.Tpo -c -o init.o
/home/bison/RTEMS/code/c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
-qrtems -mcpu=arm1176jzf-s -O2 -g -Wall -Wmissing-prototypes
-mcpu=arm1176jzf-s -o hello.exe init.o
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o): In function
`_Thread_Idle_body':
/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/cpukit/libmisc/../../cpukit/../../../raspberrypi/lib/include/rtems/confdefs.h:849:
multiple definition of `_Thread_Idle_body'
init.o:/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/../../../../../raspberrypi/lib/include/rtems/confdefs.h:849:
first defined here
`_Thread_Get_executing':
/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/cpukit/libmisc/../../cpukit/../../../raspberrypi/lib/include/rtems/score/thread.h:632:
multiple definition of `__getreent'
init.o:/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/../../../../../raspberrypi/lib/include/rtems/score/thread.h:632:
first defined here
multiple definition of `_POSIX_Threads_Initialize_user_threads_p'
first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x0):
multiple definition of `_RTEMS_tasks_Initialize_user_tasks_p'
init.o:(.data+0x0): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x0):
multiple definition of `Configuration'
init.o:(.rodata+0x0): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x4):
multiple definition of `rtems_maximum_priority'
init.o:(.data+0x4): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x8):
multiple definition of `rtems_minimum_stack_size'
init.o:(.data+0x8): first defined here
multiple definition of `Configuration_POSIX_API'
init.o:/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/../../../../../raspberrypi/lib/include/rtems/test.h:73:
first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0xc):
multiple definition of `Configuration_RTEMS_API'
init.o:(.data+0xc): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x3c):
multiple definition of `Device_drivers'
init.o:(.data+0x3c): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x6c):
multiple definition of `Initialization_tasks'
init.o:(.data+0x6c): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.bss+0x38):
multiple definition of `rtems_malloc_dirty_helper'
init.o:/home/bison/RTEMS/code/c/src/../../testsuites/samples/hello/init.c:47:
first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x74):
multiple definition of `rtems_malloc_extend_handler'
init.o:(.rodata+0xc8): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.bss+0x3c):
multiple definition of `rtems_malloc_statistics_helpers'
first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x88):
multiple definition of `RTEMS_Malloc_Heap'
init.o:(.data+0x88): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x78):
multiple definition of `_Scheduler_FIXME_thread_priority_queues_are_broken'
init.o:(.rodata+0xcc): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x8c):
multiple definition of `_Scheduler'
init.o:(.data+0x8c): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x7c):
multiple definition of `rtems_filesystem_root_configuration'
init.o:(.rodata+0xd0): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x90):
multiple definition of `rtems_filesystem_table'
init.o:(.rodata+0xec): first defined here
/home/bison/RTEMS/arm/tools/rtems-4.11_arm/lib/gcc/arm-rtems4.11/4.8.2/../../../../arm-rtems4.11/bin/ld:
Warning: size of symbol `rtems_filesystem_table' changed from 24 in
init.o to 16 in ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o)
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.bss+0x40):
multiple definition of `rtems_telnetd_maximum_ptys'
init.o:(.bss+0x90): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0xd0):
multiple definition of `rtems_libio_number_iops'
init.o:(.data+0xcc): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xa0):
multiple definition of `rtems_fs_init_helper'
init.o:(.rodata+0x104): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xa4):
multiple definition of `rtems_libio_exit_helper'
init.o:(.rodata+0x108): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xa8):
multiple definition of `rtems_libio_post_driver_helper'
init.o:(.rodata+0x10c): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xac):
multiple definition of `rtems_libio_init_helper'
init.o:(.rodata+0x110): first defined here
../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x7c):
undefined reference to `main'
collect2: error: ld returned 1 exit status
Any clue of what may be the problem?
--André Marques.
