Build failure on SH
Tue Apr 29 07:49:19 UTC 2014
Hello,
I have a linker error during the build of the SH BSPs:
sh-rtems4.11-gcc --pipe -B../../../../.././lib/ -B../../../../.././gensh4/lib/
-specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-lib-libcpu-sh\"
-DPACKAGE_TARNAME=\"rtems-c-src-lib-libcpu-sh\" -DPACKAGE_VERSION=\"4.10.99.0\"
-DPACKAGE_STRING=\"rtems-c-src-lib-libcpu-sh\ 4.10.99.0\"
-DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DPACKAGE_URL=\"\" -I.
-I/home/sh/git-rtems-upstream/c/src/lib/libcpu/sh  -isystem
../../../../.././gensh4/lib/include   -m4 -ml -O2 -g  -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT sh7750/clock/sh7750_clock_rel-ckinit.o -MD -MP -MF
sh7750/clock/.deps/sh7750_clock_rel-ckinit.Tpo -c -o
sh7750/clock/sh7750_clock_rel-ckinit.o `test -f 'sh7750/clock/ckinit.c' || echo
'/home/sh/git-rtems-upstream/c/src/lib/libcpu/sh/'`sh7750/clock/ckinit.c
/home/sh/git-rtems-upstream/c/src/lib/libcpu/sh/sh7750/clock/ckinit.c:107:1:
warning: no previous prototype for 'Install_clock' [-Wmissing-prototypes]
  Install_clock(rtems_isr_entry clock_isr)
/home/sh/git-rtems-upstream/c/src/lib/libcpu/sh/sh7750/clock/ckinit.c:267:1:
warning: no previous prototype for 'Clock_initialize' [-Wmissing-prototypes]
  Clock_initialize(rtems_device_major_number major,
mv -f sh7750/clock/.deps/sh7750_clock_rel-ckinit.Tpo
sh7750/clock/.deps/sh7750_clock_rel-ckinit.Po
-specs bsp_specs -qrtems  -m4 -ml -O2 -g  -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
-qnolinkcmds -nostdlib -r  -o sh7750/clock.rel
/opt/rtems-4.11/lib64/gcc/sh-rtems4.11/4.8.3/../../../../sh-rtems4.11/bin/ld:
sh7750/clock/sh7750_clock_rel-ckinit.o: compiled for a little endian system and
target is big endian
sh7750/clock/sh7750_clock_rel-ckinit.o: uses instructions which are
incompatible with instructions used in previous modules
failed to merge target specific data of file sh7750/clock/sh7750_clock_rel-ckinit.o
collect2: error: ld returned 1 exit status
make: *** [sh7750/clock.rel] Error 1
This looks like a tool chain bug, do you see this also?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
