[PATCH 1/2] bsps/mips: Delete unused files
Tue Apr 29 14:04:17 UTC 2014
On 4/29/2014 8:43 AM, Sebastian Huber wrote:
> On 2014-04-29 15:32, Joel Sherrill wrote:
>> Are you sure the code which reads the cause register and vectors is not used? I
>> am off today but my recollection is that without that code, no isr is going to
>> get vectored.
>> The MIPS already required BSP/CPU model specific deciding of isr source. The
>> cause decoding has to come from somewhere and I am positive we preserved it in
>> the transition from simple to PIC.
> These vectorisrs.c files in libcpu didn't show up in any Makefile.am.  It seems
> someone copied them to libbsp and worked with these copies:
> ./c/src/lib/libbsp/mips/jmr3904/irq/vectorisrs.c
> ./c/src/lib/libbsp/mips/rbtx4925/irq/vectorisrs.c
> ./c/src/lib/libbsp/mips/hurricane/irq/vectorisrs.c
> ./c/src/lib/libbsp/mips/malta/irq/vectorisrs.c
> ./c/src/lib/libbsp/mips/csb350/irq/vectorisrs.c
> ./c/src/lib/libbsp/mips/genmongoosev/irq/vectorisrs.c
> ./c/src/lib/libbsp/mips/rbtx4938/irq/vectorisrs.c
> ./c/src/lib/libcpu/mips/tx49/vectorisrs/vectorisrs.c
> ./c/src/lib/libcpu/mips/r46xx/vectorisrs/vectorisrs.c
> ./c/src/lib/libcpu/mips/tx39/vectorisrs/vectorisrs.c
> ./c/src/lib/libcpu/mips/au1x00/vectorisrs/vectorisrs.c
> ./c/src/lib/libcpu/mips/rm52xx/vectorisrs/vectorisrs.c
> ./c/src/lib/libcpu/mips/mongoosev/vectorisrs/vectorisrs.c
OK. These files were migrated to the BSPs that actually use
them. And updated as needed.
They are dead.
I have wondered about dispersing the contents of libcpu to
libbsp/shared and libbsp/. I suspect significant portions
of it are only used by a single BSP and could be part of that BSP.
Others would just move to libbsp/shared or libbsp/CPU/shared.
At least the portions that are in a single BSP would make a nice
dent in it.
