[PATCH] doc: Extend documentation for unlimited objects
Tue Apr 29 15:43:02 UTC 2014
Looks good to me.
On Tue, Apr 29, 2014 at 10:57 AM, Ralf Kirchner
<ralf.kirchner at embedded-brains.de> wrote:
> Mark POSIX Keys and POSIX Key Value Pairs as supported.
> Add list of unsupported object classes.
> Add hint to unified work areas.
> Add example.
>  doc/user/conf.t |   40 ++++++++++++++++++++++++++++++++++++----
>  1 Datei geändert, 36 Zeilen hinzugefügt(+), 4 Zeilen entfernt(-)
> diff --git a/doc/user/conf.t b/doc/user/conf.t
> index f0aa022..ef40480 100644
> --- a/doc/user/conf.t
> +++ b/doc/user/conf.t
> @@ -355,6 +355,14 @@ software is unknown. In these situations users do not need to control
>  the size of the workspace very tightly because they just want to get
>  the new software to run; later they can tune the workspace size as needed.
> +The following API-independent object classes can be configured in
> +unlimited mode:
> + at itemize @bullet
> + at item POSIX Keys
> + at item POSIX Key Value Pairs
> + at end itemize
>  The following object classes in the Classic API can be configured in
>  unlimited mode:
> @@ -377,7 +385,6 @@ configured in unlimited mode:
>  @item Threads
>  @item Mutexes
>  @item Condition Variables
> - at item Keys
>  @item Timers
>  @item Message Queues
>  @item Message Queue Descriptors
> @@ -387,9 +394,34 @@ configured in unlimited mode:
>  @item Spinlocks
>  @end itemize
> -Due to how the POSIX object memory requirements are configured the
> -unlimited object support does not provide unlimited size declarations
> -for POSIX keys or queued signals.
> +The following object classes can @strong{not} be configured in unlimited mode:
> + at item Drivers
> + at item File Descriptors
> + at item User Extensions
> + at item Queued Signals
> + at end itemize
> +Due to the memory requirements of unlimited objects it is strongly recommended
> +to use them only in combination with the unified work areas. See
> + at ref{Configuring a System Separate or Unified Work Areas} for more information
> +on unified work areas.
> +The following example demonstrates how the two simple configuration defines for
> +unlimited objects and unified works areas can replace many seperate
> +configuration defines for supported object classes:
> + at example
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_UNIFIED_WORK_AREAS
> +#define CONFIGURE_UNLIMITED_OBJECTS
> +#define CONFIGURE_INIT
> +#include <rtems/confdefs.h>
> + at end example
>  Users are cautioned that using unlimited objects is not recommended for
>  production software unless the dynamic growth is absolutely required. It
> 1.7.10.4
> rtems-devel mailing list
> rtems-devel at rtems.org
