[PATCH 01/10] score: Add get/set affinity to Scheduler Framework.
Jennifer Averett
Jennifer.Averett at OARcorp.com
Tue Apr 1 13:50:10 UTC 2014
> -----Original Message-----
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On
> Behalf Of Gedare Bloom
> Sent: Tuesday, March 25, 2014 7:08 AM
> To: Sebastian Huber
> Cc: Jennifer Averett; RTEMS Devel
> Subject: Re: [PATCH 01/10] score: Add get/set affinity to Scheduler
> Framework.
> On Tue, Mar 25, 2014 at 3:20 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 2014-03-24 19:39, Jennifer wrote:
> >> @@ -184,6 +205,43 @@ void _Scheduler_default_Start_idle(
> >> Per_CPU_Control *processor
> >> +#if defined(__RTEMS_HAVE_SYS_CPUSET_H__) &&
> defined(RTEMS_SMP)
> >> + * @brief Get affinity for the default scheduler.
> >> + * @param[in] thread The associated thread.
> >> + * @param[in] cpusetsize The size of the cpuset.
> >> + * @param[out] cpuset Affinity set containing all CPUs.
> >> + * @retval 0 Successfully got cpuset
> >> + * @retval -1 The cpusetsize is invalid for the system
> >> + int _Scheduler_default_Get_affinity(
> >> + Thread_Control *thread,
> >> + size_t cpusetsize,
> >> + cpu_set_t *cpuset
> >> + * @brief Set affinity for the default scheduler.
> >> + * @param[in] cpuset Affinity new affinity set.
> >> + * This method always returns successful and does not save
> >> + * the cpuset.
> >> + int _Scheduler_default_Set_affinity(
> >> + cpu_set_t *cpuset
> >> +#endif
> > I would rather use bool or an enum for the return status instead of
> > this int.
> > The default set affinity operation should accept only CPU sets that
> > specify the complete set of available processors, e.g. for a three
> > processor system it should be bits 0, 1, and 2 set, all other bits
> > cleared (e.g. (1 << CPU
> > count) - 1).
> > The default get affinity operation should return the CPU sets
> > reflecting all available processors.
> I agree with the logic for the defaults Sebastian suggests.
Actually no scheduler should be allowed to set the affinity to
A cpu that the system doesn't support. Currently those checks
are called from the API methods.
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone : +49 89 189 47 41-16
> > Fax : +49 89 189 47 41-09
> > E-Mail : sebastian.huber at embedded-brains.de
> > PGP : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
