[PATCH 3/3] score: Task get/set affinity
Joel Sherrill Joel.Sherrill at OARcorp.com
Wed Apr 9 11:17:34 UTC 2014
On Apr 9, 2014 1:06 AM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 2014-04-08 17:09, Jennifer Averett wrote:
> > I thought the consensus was that non-smp systems would not
> > support affinity methods.
> I don't remember a discussion about this.
> I think it makes it easier for application developers if the don't have to
> plaster their code with #ifdef RTEMS_SMP.  You should also be able to write
> libraries that work with SMP and non-SMP configurations.  For this we have to
> provide the same ABI.  This should be the long term goal.
Ironically this is exactly what we have not done with disable preemption and task variables.
> I propose to add a new requirement:
> The non-SMP and SMP RTEMS Classic API should be ABI compatible.
> http://www.rtems.org/wiki/index.php?title=SMP#Requirements
So you propose to defer compile errors for task variables to run time?
> On Linux you can use the thread affinity functions also on non-SMP systems.
For this I do not mind but we did discuss this at the beginning of the implementation.
The short circuit logic for non-smp should be in the api level code and the score should have NO code for affinity.
Otherwise you impact the minimum profile and this is 100% unacceptable.
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140409/cb9904bd/attachment-0001.html>
