[PATCH 1/4] score: Add scheduler name
Wed Apr 9 14:51:02 UTC 2014
On Wed, Apr 9, 2014 at 7:28 AM, Sebastian Huber
>  cpukit/sapi/include/confdefs.h               |   45 ++++++++++++++++++++++----
>  cpukit/sapi/include/rtems/scheduler.h        |   35 ++++++++++++--------
>  cpukit/score/include/rtems/score/scheduler.h |    5 +++
>  doc/user/conf.t                              |   35 ++++++++++++++++++++
>  4 files changed, 99 insertions(+), 21 deletions(-)
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index 2a37474..81f9c26 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -666,6 +666,10 @@ const rtems_libio_helper rtems_fs_init_helper =
>   * If the Priority Scheduler is selected, then configure for it.
>  #if defined(CONFIGURE_SCHEDULER_PRIORITY)
> +  #if !defined(CONFIGURE_SCHEDULER_NAME)
> +    #define CONFIGURE_SCHEDULER_NAME rtems_build_name('P', 'R', 'I', 'O')
> +  #endif
>    #define CONFIGURE_SCHEDULER_CONTEXT \
>      RTEMS_SCHEDULER_CONTEXT_PRIORITY( \
>        dflt, \
> @@ -673,7 +677,7 @@ const rtems_libio_helper rtems_fs_init_helper =
>    #define CONFIGURE_SCHEDULER_CONTROL \
> -    RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt)
> +    RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt, CONFIGURE_SCHEDULER_NAME)
>  #endif
> @@ -681,6 +685,10 @@ const rtems_libio_helper rtems_fs_init_helper =
>   * it.
>  #if defined(CONFIGURE_SCHEDULER_PRIORITY_SMP)
> +  #endif
>      RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( \
>        dflt, \
> @@ -688,7 +696,7 @@ const rtems_libio_helper rtems_fs_init_helper =
> -    RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt)
> +    RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
>  #endif
> @@ -696,6 +704,10 @@ const rtems_libio_helper rtems_fs_init_helper =
>   * it.
>  #if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP)
> +    #define CONFIGURE_SCHEDULER_NAME rtems_build_name('P', 'A', 'F', 'F')
> +  #endif
>      RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( \
>        dflt, \
> @@ -703,45 +715,64 @@ const rtems_libio_helper rtems_fs_init_helper =
> -    RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP(dflt)
> +    RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
>  #endif
>   * If the Simple Priority Scheduler is selected, then configure for it.
>  #if defined(CONFIGURE_SCHEDULER_SIMPLE)
> +    #define CONFIGURE_SCHEDULER_NAME rtems_build_name('S', 'I', 'M', 'P')
> +  #endif
>    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_SIMPLE(dflt)
> -  #define CONFIGURE_SCHEDULER_CONTROL RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt)
> +  #define CONFIGURE_SCHEDULER_CONTROL \
> +    RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt, CONFIGURE_SCHEDULER_NAME)
>  #endif
>   * If the Simple SMP Priority Scheduler is selected, then configure for it.
>  #if defined(CONFIGURE_SCHEDULER_SIMPLE_SMP)
> +    #define CONFIGURE_SCHEDULER_NAME rtems_build_name('P', 'S', 'I', 'M')
> +  #endif
>      RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(dflt)
> -    RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt)
> +    RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
>  #endif
>   * If the EDF Scheduler is selected, then configure for it.
>  #if defined(CONFIGURE_SCHEDULER_EDF)
> +    #define CONFIGURE_SCHEDULER_NAME rtems_build_name(' ', 'E', 'D', 'F')
> +  #endif
>    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_EDF(dflt)
> -  #define CONFIGURE_SCHEDULER_CONTROL RTEMS_SCHEDULER_CONTROL_EDF(dflt)
> +    RTEMS_SCHEDULER_CONTROL_EDF(dflt, CONFIGURE_SCHEDULER_NAME)
>  #endif
>   * If the CBS Scheduler is selected, then configure for it.
>  #if defined(CONFIGURE_SCHEDULER_CBS)
> +    #define CONFIGURE_SCHEDULER_NAME rtems_build_name(' ', 'C', 'B', 'S')
> +  #endif
>    #define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_CBS(dflt)
> -  #define CONFIGURE_SCHEDULER_CONTROL RTEMS_SCHEDULER_CONTROL_CBS(dflt)
> +    RTEMS_SCHEDULER_CONTROL_CBS(dflt, CONFIGURE_SCHEDULER_NAME)
>    #ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
>      #define CONFIGURE_CBS_MAXIMUM_SERVERS CONFIGURE_MAXIMUM_TASKS
> diff --git a/cpukit/sapi/include/rtems/scheduler.h b/cpukit/sapi/include/rtems/scheduler.h
> index 5d6b2ec..06824e9 100644
> --- a/cpukit/sapi/include/rtems/scheduler.h
> +++ b/cpukit/sapi/include/rtems/scheduler.h
> @@ -43,10 +43,11 @@
>    #define RTEMS_SCHEDULER_CONTEXT_CBS( name ) \
>      static Scheduler_EDF_Context RTEMS_SCHEDULER_CONTEXT_CBS_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_CBS( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_CBS( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_CBS_NAME( name ).Base, \
> -      SCHEDULER_CBS_ENTRY_POINTS \
> +      SCHEDULER_CBS_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> @@ -59,10 +60,11 @@
>    #define RTEMS_SCHEDULER_CONTEXT_EDF( name ) \
>      static Scheduler_EDF_Context RTEMS_SCHEDULER_CONTEXT_EDF_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_EDF( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_EDF( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_EDF_NAME( name ).Base, \
> -      SCHEDULER_EDF_ENTRY_POINTS \
> +      SCHEDULER_EDF_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> @@ -78,10 +80,11 @@
>        Chain_Control              Ready[ ( prio_count ) ]; \
>      } RTEMS_SCHEDULER_CONTEXT_PRIORITY_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_PRIORITY( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_PRIORITY( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_PRIORITY_NAME( name ).Base.Base, \
> -      SCHEDULER_PRIORITY_ENTRY_POINTS \
> +      SCHEDULER_PRIORITY_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> @@ -97,10 +100,11 @@
>      } RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP_NAME( name ).Base.Base, \
> -      SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS \
> +      SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> @@ -116,10 +120,11 @@
>      } RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP_NAME( name ).Base.Base, \
> -      SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
> +      SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> @@ -133,10 +138,11 @@
>      static Scheduler_simple_Context \
>        RTEMS_SCHEDULER_CONTEXT_SIMPLE_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_SIMPLE( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_SIMPLE( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_SIMPLE_NAME( name ).Base, \
> -      SCHEDULER_SIMPLE_ENTRY_POINTS \
> +      SCHEDULER_SIMPLE_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> @@ -150,10 +156,11 @@
>      static Scheduler_simple_SMP_Context \
>        RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP_NAME( name )
> -  #define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name ) \
> +  #define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name, obj_name ) \
>        &RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP_NAME( name ).Base, \
> -      SCHEDULER_SIMPLE_SMP_ENTRY_POINTS \
> +      SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
> +      ( obj_name ) \
>  #endif
> diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
> index 003714d..846cd6271 100644
> --- a/cpukit/score/include/rtems/score/scheduler.h
> +++ b/cpukit/score/include/rtems/score/scheduler.h
> @@ -165,6 +165,11 @@ struct Scheduler_Control {
>     * @brief The scheduler operations.
>    Scheduler_Operations Operations;
> +   * @brief The scheduler name.
> +  uint32_t name;
> diff --git a/doc/user/conf.t b/doc/user/conf.t
> index 71c78b2..0796a8b 100644
> --- a/doc/user/conf.t
> +++ b/doc/user/conf.t
> @@ -3672,6 +3672,41 @@ This scheduler is only available when RTEMS is configured with SMP
>  support enabled.
>  @c
> + at c === Configuring a Scheduler Name ===
> + at c
> + at subsection Configuring a Scheduler Name
> + at findex CONFIGURE_SCHEDULER_NAME
> + at table @b
> + at item CONSTANT:
> + at code{CONFIGURE_SCHEDULER_NAME}
> + at item DATA TYPE:
> +RTEMS Name (@code{rtems_name}).
> + at item RANGE:
> +Any value.
> + at item DEFAULT VALUE:
> +The default name is
> + at itemize @bullet
> + at item @code{" CBS"} for the CBS scheduler,
> + at item @code{" EDF"} for the EDF scheduler,
> + at item @code{"PRIO"} for the Deterministic Priority scheduler,
> + at item @code{"PAFF"} for the Priority Affinity scheduler, and
> + at item @code{"PSIM"} for the Simple Priority scheduler.
PSIM with SMP, SIMP for the non-SMP.
> + at end itemize
> + at end table
> + at subheading DESCRIPTION:
> +Schedulers can be identified via @code{rtems_scheduler_ident}.  The name of the scheduler is determined by the configuration.
> + at subheading NOTES:
> +None.
> + at c
>  @c === Configuring a User Scheduler ===
>  @c
>  @subsection Configuring a User Provided Scheduler
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
