[PATCH 3/3] score: Task get/set affinity
Sebastian Huber
Thu Apr 10 08:42:34 UTC 2014
On 2014-04-10 04:27, Chris Johns wrote:
>>> The short circuit logic for non-smp should be in the api level code
>>> and the
>>> score should have NO code for affinity.
>> Since the affinity support is used by the Classic and POSIX API it must
>> stay in the score.
> Conditionally removed on uniprocessor builds ?
>>> Otherwise you impact the minimum profile and this is 100% unacceptable.
>> There is no overhead in the non-SMP configurations if you don't use the
>> task set/get affinity functions. The scheduler get/set affinity
>> operations are only available in SMP configurations.
> Could you please elaborate ? If I do not use the functions the score includes
> no extra code related to this API, ie the scope is limited to the API layer ?
Lets look at rtems_task_get_affinity() for example. This function makes sense
on a uni-processor system since this can be viewed as an SMP system with only
one processor. The implementation is like this:
rtems_status_code rtems_task_get_affinity(
rtems_id id,
size_t cpusetsize,
cpu_set_t *cpuset
Thread_Control *the_thread;
Objects_Locations location;
bool ok;
if ( !cpuset )
return RTEMS_INVALID_ADDRESS;
the_thread = _Thread_Get( id, &location );
switch ( location ) {
case OBJECTS_LOCAL:
ok = _Scheduler_Get_affinity(
_Scheduler_Get( the_thread ),
the_thread,
cpusetsize,
cpuset
_Objects_Put( &the_thread->Object );
return ok ? RTEMS_SUCCESSFUL : RTEMS_INVALID_NUMBER;
#if defined(RTEMS_MULTIPROCESSING)
case OBJECTS_REMOTE:
#endif
case OBJECTS_ERROR:
break;
return RTEMS_INVALID_ID;
This leads to _Scheduler_Get_affinity():
bool _Scheduler_Get_affinity(
const Scheduler_Control *scheduler,
Thread_Control *the_thread,
size_t cpusetsize,
cpu_set_t *cpuset
bool ok;
if ( _CPU_set_Is_large_enough( cpusetsize ) ) {
#if defined(RTEMS_SMP)
ok = ( *scheduler->Operations.get_affinity )(
scheduler,
the_thread,
cpusetsize,
cpuset
#else
ok = _Scheduler_default_Get_affinity_body(
scheduler,
the_thread,
cpusetsize,
cpuset
#endif
} else {
ok = false;
return ok;
On non-SMP this leads to _Scheduler_default_Get_affinity_body(). Please note
that we have no get/set affinity operation!
RTEMS_INLINE_ROUTINE bool _Scheduler_default_Get_affinity_body(
size_t cpusetsize,
cpu_set_t *cpuset
uint32_t cpu_count = _SMP_Get_processor_count();
uint32_t cpu_index;
(void) scheduler;
(void) the_thread;
CPU_ZERO_S( cpusetsize, cpuset );
for ( cpu_index = 0 ; cpu_index < cpu_count ; ++cpu_index ) {
CPU_SET_S( (int) cpu_index, cpusetsize, cpuset );
return true;
On non-SMP _SMP_Get_processor_count() is a compile-time constant of one.
So if you use rtems_task_get_affinity() on non-SMP you have of course the
overhead for this function to return a cpuset with all bits except bit 0 set to
zero. You have no overhead in the rest of the system, e.g. not set/get
affinity operations in the scheduler, global variables, structure variables, etc.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
