[PATCH 5/8] rtems: Add scheduler identification
Fri Apr 11 15:11:45 UTC 2014
 cpukit/rtems/Makefile.am                         |    1 +
 cpukit/rtems/include/rtems/rtems/tasks.h         |   17 ++++++++
 cpukit/rtems/src/schedulerident.c                |   46 ++++++++++++++++++++++
 cpukit/score/include/rtems/score/object.h        |    3 +-
 cpukit/score/include/rtems/score/objectimpl.h    |    9 ++++
 cpukit/score/include/rtems/score/schedulerimpl.h |   10 +++++
 testsuites/sptests/spscheduler01/init.c          |   30 ++++++++++++++-
 7 files changed, 114 insertions(+), 2 deletions(-)
 create mode 100644 cpukit/rtems/src/schedulerident.c
diff --git a/cpukit/rtems/Makefile.am b/cpukit/rtems/Makefile.am
index b6a19c4..57b15ca 100644
--- a/cpukit/rtems/Makefile.am
+++ b/cpukit/rtems/Makefile.am
@@ -116,6 +116,7 @@ librtems_a_SOURCES += src/taskvariableget.c
 librtems_a_SOURCES += src/taskvariable_invoke_dtor.c
 endif
 librtems_a_SOURCES += src/taskdata.c
+librtems_a_SOURCES += src/schedulerident.c
 ## RATEMON_C_FILES
 librtems_a_SOURCES += src/ratemon.c
diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
index 4da32c4..cb7d1bb 100644
--- a/cpukit/rtems/include/rtems/rtems/tasks.h
+++ b/cpukit/rtems/include/rtems/rtems/tasks.h
@@ -548,6 +548,23 @@ rtems_status_code rtems_task_set_affinity(
 rtems_id rtems_task_self(void);
+ * @brief Identifies a scheduler by its name.
+ * The scheduler name is determined by the scheduler configuration.
+ * @param[in] name The scheduler name.
+ * @param[out] id The scheduler identifier associated with the name.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_INVALID_ADDRESS The @a id parameter is @c NULL.
+ * @retval RTEMS_INVALID_NAME Invalid scheduler name.
+rtems_status_code rtems_scheduler_ident(
+  rtems_name  name,
+  rtems_id   *id
diff --git a/cpukit/rtems/src/schedulerident.c b/cpukit/rtems/src/schedulerident.c
new file mode 100644
index 0000000..d9e913c
--- /dev/null
+++ b/cpukit/rtems/src/schedulerident.c
@@ -0,0 +1,46 @@
+ * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#if HAVE_CONFIG_H
+  #include "config.h"
+#endif
+#include <rtems/rtems/tasks.h>
+#include <rtems/score/schedulerimpl.h>
+  rtems_name  name,
+  rtems_id   *id
+  rtems_status_code sc;
+  if ( id != NULL ) {
+    size_t n = _Scheduler_Count;
+    size_t i;
+    sc = RTEMS_INVALID_NAME;
+    for ( i = 0 ; i < n && sc == RTEMS_INVALID_NAME ; ++i ) {
+      if ( _Scheduler_Table[ i ].name == name ) {
+        *id = _Scheduler_Build_id( i );
+        sc = RTEMS_SUCCESSFUL;
+  } else {
+    sc = RTEMS_INVALID_ADDRESS;
+  return sc;
diff --git a/cpukit/score/include/rtems/score/object.h b/cpukit/score/include/rtems/score/object.h
index 0ccafbf..4eb66ad 100644
--- a/cpukit/score/include/rtems/score/object.h
+++ b/cpukit/score/include/rtems/score/object.h
@@ -217,7 +217,8 @@ typedef enum {
   OBJECTS_NO_API       = 0,
   OBJECTS_INTERNAL_API = 1,
   OBJECTS_CLASSIC_API  = 2,
-  OBJECTS_POSIX_API    = 3
+  OBJECTS_POSIX_API    = 3,
+  OBJECTS_FAKE_OBJECTS_API = 7
 } Objects_APIs;
 /** This macro is used to generically specify the last API index. */
diff --git a/cpukit/score/include/rtems/score/objectimpl.h b/cpukit/score/include/rtems/score/objectimpl.h
index 383f0a7..4e626ae 100644
--- a/cpukit/score/include/rtems/score/objectimpl.h
+++ b/cpukit/score/include/rtems/score/objectimpl.h
@@ -100,6 +100,15 @@ typedef enum {
 #define OBJECTS_POSIX_CLASSES_LAST OBJECTS_POSIX_RWLOCKS
+ * For fake objects, which have an object identifier, but no objects
+ * information block.
+typedef enum {
+  OBJECTS_FAKE_OBJECTS_NO_CLASS   = 0,
+  OBJECTS_FAKE_OBJECTS_SCHEDULERS = 1
+} Objects_Fake_objects_API;
  *  This enumerated type lists the locations which may be returned
  *  by _Objects_Get.  These codes indicate the success of locating
diff --git a/cpukit/score/include/rtems/score/schedulerimpl.h b/cpukit/score/include/rtems/score/schedulerimpl.h
index abad068..1635fa8 100644
--- a/cpukit/score/include/rtems/score/schedulerimpl.h
+++ b/cpukit/score/include/rtems/score/schedulerimpl.h
@@ -441,6 +441,16 @@ RTEMS_INLINE_ROUTINE const Scheduler_Control *_Scheduler_Get(
   return &_Scheduler_Table[ 0 ];
+RTEMS_INLINE_ROUTINE Objects_Id _Scheduler_Build_id( uint32_t scheduler_index )
+  return _Objects_Build_id(
+    OBJECTS_FAKE_OBJECTS_API,
+    OBJECTS_FAKE_OBJECTS_SCHEDULERS,
+    _Objects_Local_node,
+    scheduler_index + 1
 #ifdef __cplusplus
diff --git a/testsuites/sptests/spscheduler01/init.c b/testsuites/sptests/spscheduler01/init.c
index f8c4bb2..1b1be3c 100644
--- a/testsuites/sptests/spscheduler01/init.c
+++ b/testsuites/sptests/spscheduler01/init.c
@@ -25,7 +25,11 @@
 const char rtems_test_name[] = "SPSCHEDULER 1";
-static rtems_id invalid_id = 1;
+#define BLUE rtems_build_name('b', 'l', 'u', 'e')
+#define RED rtems_build_name('r', 'e', 'd', ' ')
+static const rtems_id invalid_id = 1;
 static void test_task_get_set_affinity(void)
@@ -98,6 +102,27 @@ static void test_task_get_set_affinity(void)
 #endif /* defined(__RTEMS_HAVE_SYS_CPUSET_H__) */
+static void test_scheduler_ident(void)
+  rtems_id expected_id = rtems_build_id(2, 31, 1, 1);
+  rtems_id scheduler_id;
+  rtems_name name = BLUE;
+  rtems_name invalid_name = RED;
+  sc = rtems_scheduler_ident(name, NULL);
+  rtems_test_assert(sc == RTEMS_INVALID_ADDRESS);
+  sc = rtems_scheduler_ident(invalid_name, &scheduler_id);
+  rtems_test_assert(sc == RTEMS_INVALID_NAME);
+  scheduler_id = 0;
+  sc = rtems_scheduler_ident(name, &scheduler_id);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+  rtems_test_assert(scheduler_id == expected_id);
 static void Init(rtems_task_argument arg)
   rtems_resource_snapshot snapshot;
@@ -107,6 +132,7 @@ static void Init(rtems_task_argument arg)
   rtems_resource_snapshot_take(&snapshot);
   test_task_get_set_affinity();
+  test_scheduler_ident();
   rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
@@ -125,6 +151,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_SCHEDULER_NAME BLUE
 #define CONFIGURE_INIT
 #include <rtems/confdefs.h>
1.7.7
