[PATCH 1/2] score: Add _Per_CPU_Get_snapshot()
Sebastian Huber
Fri Apr 11 18:00:20 UTC 2014
On 04/11/2014 07:29 PM, Gedare Bloom wrote:
> On Fri, Apr 11, 2014 at 11:15 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> > cpukit/score/include/rtems/score/percpu.h | 8 +++++---
>> > 1 files changed, 5 insertions(+), 3 deletions(-)
>> >diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
>> >index 75ff3e2..92a6e8a 100644
>> >--- a/cpukit/score/include/rtems/score/percpu.h
>> >+++ b/cpukit/score/include/rtems/score/percpu.h
>> >@@ -424,11 +424,13 @@ extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
>> > _ISR_Enable( isr_cookie )
>> > #endif
>> >+#define _Per_CPU_Get_snapshot() \
>> >+ ( &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu )
> I think of a snapshot as a copy of some data that might change in the
> future. Since this gets the reference without making even a
> shallow-copy, I don't know what is being "snapshotted" or what
> guarantees if any are made about the snapshot.
If you read the processor index of the current processor in a context
which allows thread dispatching, then you may already run on another
processor right after the read instruction. There are very few cases in
which this makes sense (here we can use _Per_CPU_Get_snapshot()). All
other places must use _Per_CPU_Get() so that we can add checks for
RTEMS_DEBUG.
Do you have a better name? I will add the comment above to the source code.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
