[PATCH 5/9] score: Add scheduler name
Sebastian Huber
Mon Apr 14 13:11:30 UTC 2014
cpukit/sapi/include/confdefs.h | 52 ++++++++++++++++++++++----
cpukit/sapi/include/rtems/scheduler.h | 35 ++++++++++-------
cpukit/score/include/rtems/score/scheduler.h | 5 ++
doc/user/conf.t | 37 ++++++++++++++++++
4 files changed, 107 insertions(+), 22 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index e62e917..5ec0cf2 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -666,6 +666,10 @@ const rtems_libio_helper rtems_fs_init_helper =
* If the Priority Scheduler is selected, then configure for it.
#if defined(CONFIGURE_SCHEDULER_PRIORITY)
+ #if !defined(CONFIGURE_SCHEDULER_NAME)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'D', ' ')
+ #endif
#if !defined(CONFIGURE_SCHEDULER_CONTROLS)
#define CONFIGURE_SCHEDULER_CONTEXT \
RTEMS_SCHEDULER_CONTEXT_PRIORITY( \
@@ -674,7 +678,7 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_SCHEDULER_CONTROLS \
- RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt)
+ RTEMS_SCHEDULER_CONTROL_PRIORITY(dflt, CONFIGURE_SCHEDULER_NAME)
#endif
#endif
@@ -683,6 +687,10 @@ const rtems_libio_helper rtems_fs_init_helper =
* it.
#if defined(CONFIGURE_SCHEDULER_PRIORITY_SMP)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'D', ' ')
+ #endif
RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP( \
@@ -691,7 +699,7 @@ const rtems_libio_helper rtems_fs_init_helper =
- RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt)
+ RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
#endif
#endif
@@ -700,6 +708,10 @@ const rtems_libio_helper rtems_fs_init_helper =
* it.
#if defined(CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'A', ' ')
+ #endif
RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP( \
@@ -708,7 +720,10 @@ const rtems_libio_helper rtems_fs_init_helper =
- RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP(dflt)
+ RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( \
+ dflt, \
+ CONFIGURE_SCHEDULER_NAME \
#endif
#endif
@@ -716,10 +731,15 @@ const rtems_libio_helper rtems_fs_init_helper =
* If the Simple Priority Scheduler is selected, then configure for it.
#if defined(CONFIGURE_SCHEDULER_SIMPLE)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'P', 'S', ' ')
+ #endif
#define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_SIMPLE(dflt)
- #define CONFIGURE_SCHEDULER_CONTROLS RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt)
+ #define CONFIGURE_SCHEDULER_CONTROLS \
+ RTEMS_SCHEDULER_CONTROL_SIMPLE(dflt, CONFIGURE_SCHEDULER_NAME)
#endif
#endif
@@ -727,12 +747,16 @@ const rtems_libio_helper rtems_fs_init_helper =
* If the Simple SMP Priority Scheduler is selected, then configure for it.
#if defined(CONFIGURE_SCHEDULER_SIMPLE_SMP)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('M', 'P', 'S', ' ')
+ #endif
RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP(dflt)
- RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt)
+ RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP(dflt, CONFIGURE_SCHEDULER_NAME)
#endif
#endif
@@ -740,10 +764,15 @@ const rtems_libio_helper rtems_fs_init_helper =
* If the EDF Scheduler is selected, then configure for it.
#if defined(CONFIGURE_SCHEDULER_EDF)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'E', 'D', 'F')
+ #endif
#define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_EDF(dflt)
- #define CONFIGURE_SCHEDULER_CONTROLS RTEMS_SCHEDULER_CONTROL_EDF(dflt)
+ RTEMS_SCHEDULER_CONTROL_EDF(dflt, CONFIGURE_SCHEDULER_NAME)
#endif
#endif
@@ -751,10 +780,15 @@ const rtems_libio_helper rtems_fs_init_helper =
* If the CBS Scheduler is selected, then configure for it.
#if defined(CONFIGURE_SCHEDULER_CBS)
+ #define CONFIGURE_SCHEDULER_NAME rtems_build_name('U', 'C', 'B', 'S')
+ #endif
#define CONFIGURE_SCHEDULER_CONTEXT RTEMS_SCHEDULER_CONTEXT_CBS(dflt)
- #define CONFIGURE_SCHEDULER_CONTROLS RTEMS_SCHEDULER_CONTROL_CBS(dflt)
+ RTEMS_SCHEDULER_CONTROL_CBS(dflt, CONFIGURE_SCHEDULER_NAME)
#endif
#ifndef CONFIGURE_CBS_MAXIMUM_SERVERS
@@ -775,7 +809,9 @@ const rtems_libio_helper rtems_fs_init_helper =
* this code to know which scheduler is configured by the user.
#ifdef CONFIGURE_INIT
- CONFIGURE_SCHEDULER_CONTEXT;
+ #if defined(CONFIGURE_SCHEDULER_CONTEXT)
+ CONFIGURE_SCHEDULER_CONTEXT;
+ #endif
const Scheduler_Control _Scheduler_Table[] = {
diff --git a/cpukit/sapi/include/rtems/scheduler.h b/cpukit/sapi/include/rtems/scheduler.h
index 5d6b2ec..06824e9 100644
--- a/cpukit/sapi/include/rtems/scheduler.h
+++ b/cpukit/sapi/include/rtems/scheduler.h
@@ -43,10 +43,11 @@
#define RTEMS_SCHEDULER_CONTEXT_CBS( name ) \
static Scheduler_EDF_Context RTEMS_SCHEDULER_CONTEXT_CBS_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_CBS( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_CBS( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_CBS_NAME( name ).Base, \
- SCHEDULER_CBS_ENTRY_POINTS \
+ SCHEDULER_CBS_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
@@ -59,10 +60,11 @@
#define RTEMS_SCHEDULER_CONTEXT_EDF( name ) \
static Scheduler_EDF_Context RTEMS_SCHEDULER_CONTEXT_EDF_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_EDF( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_EDF( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_EDF_NAME( name ).Base, \
- SCHEDULER_EDF_ENTRY_POINTS \
+ SCHEDULER_EDF_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
@@ -78,10 +80,11 @@
Chain_Control Ready[ ( prio_count ) ]; \
} RTEMS_SCHEDULER_CONTEXT_PRIORITY_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_PRIORITY( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_PRIORITY( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_PRIORITY_NAME( name ).Base.Base, \
- SCHEDULER_PRIORITY_ENTRY_POINTS \
+ SCHEDULER_PRIORITY_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
@@ -97,10 +100,11 @@
} RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_PRIORITY_AFFINITY_SMP( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_PRIORITY_AFFINITY_SMP_NAME( name ).Base.Base, \
- SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS \
+ SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
@@ -116,10 +120,11 @@
} RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_PRIORITY_SMP( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_PRIORITY_SMP_NAME( name ).Base.Base, \
- SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
+ SCHEDULER_PRIORITY_SMP_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
@@ -133,10 +138,11 @@
static Scheduler_simple_Context \
RTEMS_SCHEDULER_CONTEXT_SIMPLE_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_SIMPLE( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_SIMPLE( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_SIMPLE_NAME( name ).Base, \
- SCHEDULER_SIMPLE_ENTRY_POINTS \
+ SCHEDULER_SIMPLE_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
@@ -150,10 +156,11 @@
static Scheduler_simple_SMP_Context \
RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP_NAME( name )
- #define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name ) \
+ #define RTEMS_SCHEDULER_CONTROL_SIMPLE_SMP( name, obj_name ) \
&RTEMS_SCHEDULER_CONTEXT_SIMPLE_SMP_NAME( name ).Base, \
- SCHEDULER_SIMPLE_SMP_ENTRY_POINTS \
+ SCHEDULER_SIMPLE_SMP_ENTRY_POINTS, \
+ ( obj_name ) \
#endif
diff --git a/cpukit/score/include/rtems/score/scheduler.h b/cpukit/score/include/rtems/score/scheduler.h
index d4e1339..3fd47c7 100644
--- a/cpukit/score/include/rtems/score/scheduler.h
+++ b/cpukit/score/include/rtems/score/scheduler.h
@@ -165,6 +165,11 @@ struct Scheduler_Control {
* @brief The scheduler operations.
Scheduler_Operations Operations;
+ * @brief The scheduler name.
+ uint32_t name;
diff --git a/doc/user/conf.t b/doc/user/conf.t
index afecef1..9b093f8 100644
--- a/doc/user/conf.t
+++ b/doc/user/conf.t
@@ -3705,6 +3705,43 @@ This scheduler is only available when RTEMS is configured with SMP
support enabled.
@c
+ at c === Configuring a Scheduler Name ===
+ at c
+ at subsection Configuring a Scheduler Name
+ at findex CONFIGURE_SCHEDULER_NAME
+ at table @b
+ at item CONSTANT:
+ at code{CONFIGURE_SCHEDULER_NAME}
+ at item DATA TYPE:
+RTEMS Name (@code{rtems_name}).
+ at item RANGE:
+Any value.
+ at item DEFAULT VALUE:
+The default name is
+ at itemize @bullet
+ at item @code{"UCBS"} for the Uni-Processor CBS scheduler,
+ at item @code{"UEDF"} for the Uni-Processor EDF scheduler,
+ at item @code{"UPD "} for the Uni-Processor Deterministic Priority scheduler,
+ at item @code{"UPS "} for the Uni-Processor Simple Priority scheduler,
+ at item @code{"MPA "} for the Multi-Processor Priority Affinity scheduler, and
+ at item @code{"MPD "} for the Multi-Processor Deterministic Priority scheduler, and
+ at item @code{"MPS "} for the Multi-Processor Simple Priority scheduler.
+ at end itemize
+ at end table
+ at subheading DESCRIPTION:
+Schedulers can be identified via @code{rtems_scheduler_ident}. The name of the scheduler is determined by the configuration.
+ at subheading NOTES:
+None.
+ at c
@c === Configuring a User Scheduler ===
@c
@subsection Configuring a User Provided Scheduler
1.7.7
