[PATCH 4/8] doc: rtems_task_set_affinity()
Wed Apr 16 14:15:46 UTC 2014
 doc/user/Makefile.am |    2 +-
 doc/user/smp.t       |   43 +++++++++++++------------------------------
 2 files changed, 14 insertions(+), 31 deletions(-)
diff --git a/doc/user/Makefile.am b/doc/user/Makefile.am
index 03f776d..ef91a41 100644
--- a/doc/user/Makefile.am
+++ b/doc/user/Makefile.am
@@ -169,7 +169,7 @@ smp.texi: smp.t
 	    -n "Stack Bounds Checker" < $< > $@
 stackchk.texi: stackchk.t
-	$(BMENU2) -p "Symmetric Multiprocessing Services rtems_task_set_affinity - Set Task Affinity" \
+	$(BMENU2) -p "Symmetric Multiprocessing Services TASK_SET_AFFINITY - Set task processor affinity" \
 	    -u "Top" \
 	    -n "CPU Usage Statistics" < $< > $@
diff --git a/doc/user/smp.t b/doc/user/smp.t
index 649aaf1..ced8fdf 100644
--- a/doc/user/smp.t
+++ b/doc/user/smp.t
@@ -338,18 +338,16 @@ None.
 @c rtems_task_set_affinity
 @c
 @page
- at subsection rtems_task_set_affinity - Set Task Affinity
+ at subsection TASK_SET_AFFINITY - Set task processor affinity
 @subheading CALLING SEQUENCE:
 @ifset is-C
 @example
-#include <rtems.h>
 rtems_status_code rtems_task_set_affinity(
-  rtems_id             id,
-  size_t               cpusetsize,
-  cpu_set_t           *cpuset
+  rtems_id         id,
+  size_t           cpusetsize,
+  const cpu_set_t *cpuset
 @end example
 @end ifset
@@ -357,34 +355,19 @@ rtems_status_code rtems_task_set_affinity(
 @ifset is-Ada
 @end ifset
- at subheading STATUS CODES:
- at table @b
- at item RTEMS_UNSATISFIED
-The @code{cpuset} pointer argument is invalid.
-The @code{cpusetsize} does not match the value of @code{affinitysetsize}
-field in the thread attribute object.
-The @code{cpuset} did not select a valid cpu.
-The @code{cpuset} selected a cpu that was invalid.
- at item RTEMS_INVALID_ID
-The @code{id} is invalid.
+ at subheading DIRECTIVE STATUS CODES:
- at end table
+ at code{@value{RPREFIX}SUCCESSFUL} - successful operation@*
+ at code{@value{RPREFIX}INVALID_ADDRESS} - @code{cpuset} is NULL@*
+ at code{@value{RPREFIX}INVALID_ID} - invalid task id@*
+ at code{@value{RPREFIX}INVALID_NUMBER} - invalid processor affinity set
 @subheading DESCRIPTION:
-The @code{rtems_task_set_affinity} routine is used to set the
- at code{affinity.set} field of the thread control object associated
-with @code{id}.  This value controls the @code{cpuset} that the task can
-execute on.
+Sets the processor affinity set for the task specified by @code{cpuset}.  A set
+bit in the affinity set means that the task can execute on this processor and a
+cleared bit means the opposite.
 @subheading NOTES:
-NONE
+None.
1.7.7
