[PATCH 1/4] score: Add _CPU_Get_current_per_CPU_control()
Sebastian Huber
Tue Apr 22 14:39:42 UTC 2014
On 2014-04-22 16:16, Gedare Bloom wrote:
> What is the need/use for this optimization?
The access to the thread dispatch disable level, the ISR nest level, the
dispatch necessary, the executing and heir thread is faster since you don't
have to calculate the address of the per-CPU control via the processor index.
With this optimization the context switch and interrupt support code are now
identical for non-SMP and SMP configurations on SPARC. This alone is a good
argument to use register g6 as the current per-CPU control pointer.
We work currently on a BSP for the XtratuM hypervisor on SPARC. On this
hypervisor you have to use a system call to get the current processor index.
This is very problematic in the interrupt prologue.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
