[GSOC] Paravirtualization Layer in RTEMS.
Cláudio Silva
claudiodcsilva at gmail.com
Sun Apr 27 13:56:03 UTC 2014
Hello Youren,
Welcome to the RTEMS community.
I hope you have a successful RTEMS summer of code :)
Virtualization of RTEMS on POK is a complex mid-term project with
several people involved, therefore, lets make an effort to keep the
RTEMS wiki updated with new developments and design decisions.
Regarding the interrupt virtualization, lets keep the design simple as
possible. I think we should mimic the behaviour of the underlying
hardware interrupt management as it makes the paravirtualization
easier.
To summarize, the interrupt virtualization layer shall:
- forward interrupts to the current executing partition in user mode;
- allow a partition to disable/enable virtual interrupts;
- allow a partition to mask/unmask virtual interrupts;
- track pending interrupts;
- forward pending interrupts as soon as the partition enables or
unmasks interrupts ;
I doubt you will be able to find an POK mechanism that can be adapted
to achieve this. It needs to be developed departing from Phillip's
work last year.
Could you try to summarize the design you have in mind in a blog post
or wiki page? Maybe with some simple diagrams explaining the behavior
(how to register a virtual interrupt, how do you keep interrupts
pending, where and how to store the interrupt context, etc).
Thanks,
Best Regards,
Cláudio
On Sun, Apr 27, 2014 at 9:44 AM, Youren Shen <shenyouren at gmail.com> wrote:
> Hi, Gedare, Philipp and Cláudio Silva:
> I'm very glad to be accepted by GSoC, and that's not only an honor but also
> an opportunity to change our idea and design to become code.
> Hi, Cláudio , I'm a junior student from china, and my major in college is
> embedded system. Nice to meet you.
> OK, Cliché should not be long, Let's focus on the project.
> I have discussed with the Philipp about the jobs should be done in this
> summer. Thanks to Phillpp's strict adherence, we have already get a clear
> design. I have put a brief outline on my blog[1]. But if you don't mind,
> please let me introduced it now:
> Thanks to Phillpp's contributions last year about the paravirtualization
> layer, we could run RTEMS application successfully on POK already, which
> means we can focus on CPU virtualization this year. And I'd like continue
> the work based on the Paravirtualization Layer implement by Phillpp last
> year. By the way, the job last year was really creative and great. Because
> of lacking time and complicated task, The job was not get the purpose
> eventually, I hope this year, I can make it with the guide of Philpp and
> other mentors.
> This year, the jobs includeing two aspect, one is implement a Hypercall
> system, the other is develop a interrupt handling system in POK with the
> function we design in Hypercall system.
> The implementation of Hypercall system will not be difficult, but we should
> take heed about the reusability and flexibility of the code, since we
> certainly will reuse the job and extend the functionality of Hypercall
> system.
> In the other hand, we need to design a interrupt dandling system to delivery
> the interrupt. As we discussed, the following should be the workflow of
> interruption:
> 1. When the RTEMS startup, It should register the interrupt by hypercall,
> then we will bond the corresponding interruption to this partition that the
> RTEMS locals in.
> 2. When an interrupt(or events including traps like a floating point error),
> the POK will intercept the interrupt, do some common handler and decide to
> whether delivery it or not by the type of this interrupt.For example, if the
> time interrupt occurs, the POK will deal it in kernel, but then send a dummy
> clock interrupt to every RTEMS.
> 3. If a interrupt should be delivery to Partitions(RTEMS), then the POK
> kernel compact the context of the interruption, and send the package of
> interrupt to corresponding Partitions, then mask a bit in some mechanism, to
> notify the Partitions that there happens a interrupt when you are suspended.
> 4. When the Partitions being evoked, it should check the mask bit, if the
> mask bit is settled, then using the native interrupt handler in RTEMS(but
> should change some sensitive function by Hypercall in VIrtualization Layer).
> So, as we can see, in this section, we need to design a system to save and
> delivery the interruptions.This system is called event channel in XEN, and
> Phillpp named it notify, which is more accurate(because there are no
> necessary to implement a complicated system like event channel). About this
> part, I have upload a blog to describe, and I have conclude the to-dos as
> following:
> 1. Build a structure to store the context of interrupt.
> 2. Build a structure to mark that there is an event pending.
> 3. When the partition(RTEMS) resume, check the value of the bit.
> 4. Design a callback function mechanism. Including the operation of register
> an event and callback function. The register of events should bind the
> corresponding partitions.
> 5. In the callback function, we should invoke the normal interrupt handler
> in RTEMS, let the RTEMS deal with this interrupt.
> 6. Adapt the interrupt structure in POK, make it able to bond a Partitions.
> The POK, which is obey to ARINC-653, already supplied series mechanism to
> communicate between partitions or threads in a single process. I want to
> find some mechanism could use to communicate between POK kernel and
> Partitions, so we can adapt it directly. I have read the examples in POK and
> DO NOT find any example about it. If the POK did not support such mechanism,
> the mostly worse, we have to write a notify system from nothing.
> Thank you very much for your patience to read this e-mail, I'm not a
> connoisseur in virtualization, so I have to design it as earlier as I can to
> prevent potential mistakes, So I really appreciate to Philipp that he insist
> on the outline. The purpose of this email is make a summary of the design,
> and hope to propaganda it to my mentors to review it and find any mistake or
> negligence that not be considered yet.
> There are something for my private reason, I have register a GRE in 18 May,
> and before the date, I can devote myself in this project, both of GRE and
> the project for RTEMS is really important for me.
> Thank you very much. It will be a exciting summer.
> [1].
> http://huaiyusched.github.io/rtems/2014/04/07/the-brief-design-and-outline/
> Best Regards.
> Youren Shen.
