[PATCH] score: Split _Terminate and call _Terminate_CPU_Fatal_halt.
    Chris Johns
    chrisj at rtems.org
    Mon Apr 28 02:44:08 UTC 2014
On 28/04/2014 12:01 pm, Joel Sherrill wrote:
> I do not know if this is helpful but the sim-scripts gdb startup file
> sets breakpoints on bad places to get to like __assert. the one on
> _Terminate is conditional on there being non-zero status.
Everything should end up in _Terminate so I am currently only breaking
on it (well the CPU halt version) and consider anything other path as a
lock up and test failure. The problem with the break point on _Terminate
is tests such as the stackchk raise a fatal error shut down as it is
suppose to and the test has hooked a fatal error extension so it can
print the 'END' label. If you break on _Terminate you stop at the start
of the function and the extensions are not run and so you miss the END
tag and the test is logged as a fail. It effected somewhere between 20
to 30 tests but that is a guess.
The splitting allows the standard code to be tested and used without any
changes and I think this is important.
This is independent of the weak attribute part of the patch which I am
happy to leave out. The split is something I will argue for more strongly.
Note this is being tested on real hardware (BeagleBoard xM via JTAG)
with an interrupt driven console and currently with the sp2038 and a
recent RSB commit to remove the POSIX thread change the number of
failures is looking really good. Ben is looking at the critical
interrupt tests later in the week and that is close to the end. The
tests are running again so I do not have a complete figure but this is a
toughest environment for testing RTEMS target wise and I am happy with
the state.
