BSP question: nested interrupts?
Ben Gras beng at shrike-systems.com
Mon Apr 28 12:43:10 UTC 2014
Ok, so the same interrupt will never nest itself then?
Good, thanks!
On Mon, Apr 28, 2014 at 2:14 PM, Sebastian Huber <
> On 2014-04-28 13:32, Ben Gras wrote:
>> Dear all,
>> I have a question about managing interrupts in a BSP that I have not been
>> able
>> to answer satisfactorily by looking at other BSP code, nor looking
>> throught the
>> documentation or googling. Or asking on the IRC channel :)
>> My question is: are BSPs expected to allow nested interrupts?
>> Specifically,
>> must bsp_interrupt_dispatch() turn interrupts on before calling
>> bsp_interrupt_handler_dispatch for everything else to work properly?
> If you want nested interrupts, then you can do it like this BSP:
> http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/
> lpc24xx/irq/irq-dispatch.c
>> Some BSPs do this, some don't. In the Beagle BSP I can do this by masking
>> the
>> currently active interrupt and then enabling them at the CPU level; but
>> enabling all interrupts before the hw-specific handler is called won't
>> deassert
>> the irq at the peripheral so I'm having trouble seeing how that should
>> work.
> This is the job of the interrupt controller.  It must block interrupts of
> lower or equal priority.
>> Example: if we are in a timer ISR and loop on polling the uptime ticks,
>> do we
>> expect the ticks to be able to increase? I'm wondering if any of the
>> remaining
>> failing tests are due to this. But also what the best shape of a BSP is.
>> Thanks!
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140428/51d1aad2/attachment-0001.html>
