Possible bug at newlib/libc/rtems/sys/crt0.c sigfillset
Hesham Moustafa
heshamelmatary at gmail.com
Mon Apr 28 16:25:43 UTC 2014
Thanks! These patches really help. I've already reverted back to the
original read/write prototypes after defining __rtems__ and it works.
Now newlib works normally (with the non-GPL patch you provided before
and my modifications). The only issues I have to make some workarounds
for are related to some POSIX macros. i.e,
NAME_MAX (at newlib/libc/sys/rtems/sys/dirent.h)
PATH_MAX (at newlib/libc/posix/collate.c)
_POSIX2_RE_DUP_MAX (at newlib/libc/posix/utils.h)
I got undefined macro errors for these three macros, thus, I had to
add some #ifndef XXX statements earlier at the container files, to get
over there errors.
On Mon, Apr 28, 2014 at 6:02 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> Hi
> I am not sure I got everything fixed but it should be a lot
> better now. See the attached diffs.
> + libgcc - patterns were in the wrong order and or1k*-*-rtems*
> or1k*-*-* was before rtems stanza
> + config/or1k - moved elf.h to rtemself.h. There should be
> a target OS independent config/or1k/elf.h
> Also fixed or1k/rtemself.h so it defines CPP predefines
> including __rtems__ which explains your compilation problem.
> + newlib/.../rtems/crt0 had wrong prototypes for write() and
> read().
> These are diffs against the sources with your patches applied.
> Apply on top of yours.
> It is still building here after clobbering the tree and starting
> over so there may be more problems but this should be
> a good start. :)
> --joel
> On 4/27/2014 7:26 PM, Joel Sherrill wrote:
>> This is a bug in your gcc port. You need to ensure that __rtems__ is defined.
>> See https://github.com/heshamelmatary/or1k-rtems/blob/master/patches/gcc-4.8.2-or1k-rtems.diff
>> around 220 and compare it to
>> http://gcc.gnu.org/git/?p=gcc.git;a=blob;f=gcc/config/arm/rtems-eabi.h;h=4bdcf0d87ba68940f338f4de3b41b9bd7a47260f;hb=HEAD
>> That defines __rtems__. Without that, the .h files in newlib don't get the right settings.
>> ________________________________________
>> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On Behalf Of Joel Sherrill [Joel.Sherrill at oarcorp.com]
>> Sent: Sunday, April 27, 2014 7:17 PM
>> To: Hesham Moustafa
>> Cc: rtems-devel at rtems.org
>> Subject: Re: Possible bug at newlib/libc/rtems/sys/crt0.c sigfillset
>> On Apr 27, 2014 6:40 PM, Joel Sherrill <Joel.Sherrill at oarcorp.com> wrote:
>>> On Apr 27, 2014 5:12 PM, Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>>>> Hi all,
>>>> When I am trying to get newlib compiled while porting newlib to
>>>> rtems/or1k, I met an error that confused me. The error happens for me
>>>> with both: Ubuntu and Fedora. Also it arises when configuring and
>>>> building a standalone newlib library (with configure
>>>> --target=or1k-rtems4.11) or when building gcc with newlib (for the
>>>> same target). By commenting that line, newlib and gcc building process
>>>> works fine.
>>>> The error is:
>>>> "../../../../../../../gcc-4.8.2-or1k-rtems/newlib/libc/sys/rtems/crt0.c:74:37:
>>>> error: expected ‘)’ before ‘*’ token
>>>> RTEMS_STUB(int, sigfillset(sigset_t *set), { return -1; })"
>>>> By expanding the macros with -E option, I got the following expansion
>>>> for the corresponding function:
>>>> int rtems_stub_sigfillset(sigset_t *set) { return -1; }; int
>>>> (*(sigset_t *set) = ~(0), 0) { return -1; }
>>>> Does that make sense?
>>>> I searched for anyone that happened to have the same problem and I
>>>> found this link [1] related to compiling rtems/newlib for microblaze
>>> This is a new architecture for RTEMS+newlib combination. I recall that there is a configure script near the top of newlib and it needs an entry for thus target. Or a pattern needs adjusting to distinguish or1k*-*-* from the RTEMS variant.
>> This can also be because the path through signal.h is skipping something based on or1k.
>> What source are you using as base to modify? I need to clone all your source and try it myself.
>>>> [1] http://sourceware.org/ml/newlib/2012/msg00529.html
>>>> Regards,
>>>> Hesham
>>>> _______________________________________________
>>>> rtems-devel mailing list
>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
