[GSOC] RPi BSP RTEMS
Alan Cudmore
alan.cudmore at gmail.com
Tue Apr 29 00:37:13 UTC 2014
I will definitely try that out. It would be great to automate all tests on
this board.
It seems less than 10 seconds to load a 1 megabyte RTEMS image to the Pi
using JTAG.
Alan
On Mon, Apr 28, 2014 at 7:20 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 29/04/2014 12:34 am, Alan Cudmore wrote:
>> The FT2232H MiniMod is working so far! I am able to use the UART and at
>> the same time load and run images over the JTAG interface using OpenOCD.
>> Next, I plan on trying GDB. I will try to document the setup soon, but
>> it just requires ~10 jumper wires to connect the MiniMod to the Pi GPIO
>> header.
> The rtems-tester works well with OpenOCD and GDB. Please take a look at
> the recent BeagleBoard xM script Ben and I are currently using ...
> http://git.rtems.org/rtems-tools/tree/tester/rtems/
> testing/bsps/beagleboardxm.mc
> It took us a while to get a stable way to force a full reset on the xM's
> ARM. It takes about 3 hours to run all 500 tests.
> If you get a working configuration please send me a patch. Hard coded
> paths are ok at this stage of the rtems-test's development. I am yet to
> figure out a way to manage the host variations.
> Chris
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140428/9b17a1ae/attachment-0001.html>
