SD card libblock bdpart linker problem
Andre Marques andre.lousa.marques at gmail.com
Tue Apr 29 07:19:55 UTC 2014
On 04/29/14 01:50, Alan Cudmore wrote:
> Do you have the right configuration options defined?
> I rebuilt the raspberry Pi BSP with all tests ( --enable-tests=yes ).
> This includes the testsuites/fstests/fsbdpart01 test.
> The test links and runs, but I'm not sure if it passes ( or if it
> should completely, since there is no IDE hardware on the Pi)
> I get this output:
> *** BEGIN OF TEST FSBDPART 1 ***
> ../../../../../../../rtems-git/c/src/../../testsuites/fstests/fsbdpart01/init.c:
> 143 (sc) == RTEMS_SUCCESSFUL
> After this it seems to hang.
> But , the init.c for that test may help you with the configuration in
> your code.
I have configured the base filesystem to IMFS (as used in the
fstests/fsbdpart01) instead of the devfs used on samples/hello and it
compiles now.
Thanks for the help.
> On Mon, Apr 28, 2014 at 2:56 PM, Andre Marques
> <andre.lousa.marques at gmail.com <mailto:andre.lousa.marques at gmail.com>>
> wrote:
>     Hello,
>     I am currently working on an emmc driver for the Raspberry Pi, and
>     I am trying to mount the SD card using libblock on RTEMS GIT HEAD.
>     To mount the SD card I am doing:
>     1. rtems_io_register_driver (by calling my driver with
>     CONFIGURE_APPLICATION_EXTRA_DRIVERS on hello sample)
>     2. rtems_filesystem_make_dev_t to get the device file
>     3.  rtems_disk_io_initialize
>     4. rtems_disk_create_phys
>     Up until this point everything seems good.
>     Next I try to read the SD card partition table with
>     rtems_bdpart_register_from_disk, and for that I add an include for
>     rtems/bdpart.h
>     When I hit compile, the result seems to point at a linker problem
>     (conflict with dummy.o):
>     Making all in hello
>     gmake[6]: Entering directory
>     `/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello'
>     arm-rtems4.11-gcc -B../../../../../raspberrypi/lib/ -specs
>     bsp_specs -qrtems -DHAVE_CONFIG_H -I.
>     -I/home/bison/RTEMS/code/c/src/../../testsuites/samples/hello -I..
>         -mcpu=arm1176jzf-s -O2 -g -Wall -Wmissing-prototypes
>     -Wimplicit-function-declaration -Wstrict-prototypes
>     -Wnested-externs -MT init.o -MD -MP -MF .deps/init.Tpo -c -o
>     init.o
>     /home/bison/RTEMS/code/c/src/../../testsuites/samples/hello/init.c
>     mv -f .deps/init.Tpo .deps/init.Po
>     bsp_specs -qrtems -mcpu=arm1176jzf-s -O2 -g -Wall
>     -Wmissing-prototypes -Wimplicit-function-declaration
>     -Wstrict-prototypes -Wnested-externs    -mcpu=arm1176jzf-s -o
>     hello.exe init.o
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o): In function
>     `_Thread_Idle_body':
>     /home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/cpukit/libmisc/../../cpukit/../../../raspberrypi/lib/include/rtems/confdefs.h:849:
>     multiple definition of `_Thread_Idle_body'
>     init.o:/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/../../../../../raspberrypi/lib/include/rtems/confdefs.h:849:
>     first defined here
>     `_Thread_Get_executing':
>     /home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/cpukit/libmisc/../../cpukit/../../../raspberrypi/lib/include/rtems/score/thread.h:632:
>     multiple definition of `__getreent'
>     init.o:/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/../../../../../raspberrypi/lib/include/rtems/score/thread.h:632:
>     first defined here
>     multiple definition of `_POSIX_Threads_Initialize_user_threads_p'
>     first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x0):
>     multiple definition of `_RTEMS_tasks_Initialize_user_tasks_p'
>     init.o:(.data+0x0): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x0):
>     multiple definition of `Configuration'
>     init.o:(.rodata+0x0): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x4):
>     multiple definition of `rtems_maximum_priority'
>     init.o:(.data+0x4): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x8):
>     multiple definition of `rtems_minimum_stack_size'
>     init.o:(.data+0x8): first defined here
>     multiple definition of `Configuration_POSIX_API'
>     init.o:/home/bison/RTEMS/arm/raspberry_pi/b-rtems4.11/arm-rtems4.11/c/raspberrypi/testsuites/samples/hello/../../../../../raspberrypi/lib/include/rtems/test.h:73:
>     first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0xc):
>     multiple definition of `Configuration_RTEMS_API'
>     init.o:(.data+0xc): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x3c): multiple
>     definition of `Device_drivers'
>     init.o:(.data+0x3c): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x6c): multiple
>     definition of `Initialization_tasks'
>     init.o:(.data+0x6c): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.bss+0x38):
>     multiple definition of `rtems_malloc_dirty_helper'
>     init.o:/home/bison/RTEMS/code/c/src/../../testsuites/samples/hello/init.c:47:
>     first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x74):
>     multiple definition of `rtems_malloc_extend_handler'
>     init.o:(.rodata+0xc8): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.bss+0x3c):
>     multiple definition of `rtems_malloc_statistics_helpers'
>     first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x88): multiple
>     definition of `RTEMS_Malloc_Heap'
>     init.o:(.data+0x88): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x78):
>     `_Scheduler_FIXME_thread_priority_queues_are_broken'
>     init.o:(.rodata+0xcc): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x8c): multiple
>     definition of `_Scheduler'
>     init.o:(.data+0x8c): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x7c):
>     multiple definition of `rtems_filesystem_root_configuration'
>     init.o:(.rodata+0xd0): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0x90):
>     multiple definition of `rtems_filesystem_table'
>     init.o:(.rodata+0xec): first defined here
>     /home/bison/RTEMS/arm/tools/rtems-4.11_arm/lib/gcc/arm-rtems4.11/4.8.2/../../../../arm-rtems4.11/bin/ld:
>     Warning: size of symbol `rtems_filesystem_table' changed from 24
>     in init.o to 16 in
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.bss+0x40):
>     multiple definition of `rtems_telnetd_maximum_ptys'
>     init.o:(.bss+0x90): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0xd0): multiple
>     definition of `rtems_libio_number_iops'
>     init.o:(.data+0xcc): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xa0):
>     multiple definition of `rtems_fs_init_helper'
>     init.o:(.rodata+0x104): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xa4):
>     multiple definition of `rtems_libio_exit_helper'
>     init.o:(.rodata+0x108): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xa8):
>     multiple definition of `rtems_libio_post_driver_helper'
>     init.o:(.rodata+0x10c): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.rodata+0xac):
>     multiple definition of `rtems_libio_init_helper'
>     init.o:(.rodata+0x110): first defined here
>     ../../../../../raspberrypi/lib/librtemscpu.a(dummy.o):(.data+0x7c): undefined
>     reference to `main'
>     collect2: error: ld returned 1 exit status
>     Any clue of what may be the problem?
>     --André Marques.
>     _______________________________________________
>     rtems-devel mailing list
>     rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20140429/4521a8ff/attachment-0001.html>
