[PATCH 2/2] score: Statically initialize _ISR_Vector_table
Sebastian Huber
Tue Apr 29 07:52:12 UTC 2014
c/src/lib/libbsp/mips/shared/irq/exception.S | 1 -
c/src/lib/libbsp/sparc/shared/irq_asm.S | 2 +-
c/src/lib/libcpu/sparc64/shared/score/interrupt.S | 1 -
cpukit/sapi/include/confdefs.h | 28 ---------------------
cpukit/score/cpu/arm/rtems/score/cpu.h | 4 ---
cpukit/score/cpu/bfin/cpu_asm.S | 5 +--
cpukit/score/cpu/h8300/cpu_asm.S | 4 +--
cpukit/score/cpu/i386/rtems/score/cpu.h | 7 -----
cpukit/score/cpu/m68k/cpu_asm.S | 9 +-----
cpukit/score/cpu/mips/cpu_asm.S | 1 -
cpukit/score/cpu/mips/rtems/score/cpu.h | 9 ------
cpukit/score/cpu/nios2/Makefile.am | 1 -
cpukit/score/cpu/nios2/nios2-initialize-vectors.c | 25 ------------------
cpukit/score/cpu/nios2/rtems/score/cpu.h | 2 +-
cpukit/score/cpu/no_cpu/rtems/score/cpu.h | 17 ++++++++----
cpukit/score/cpu/powerpc/rtems/score/cpu.h | 10 -------
cpukit/score/cpu/v850/rtems/score/cpu.h | 19 --------------
cpukit/score/include/rtems/score/isr.h | 14 +---------
cpukit/score/src/isr.c | 12 ++++++---
testsuites/sptests/spfatal07/testcase.h | 4 ---
testsuites/sptests/spintr_err01/init.c | 2 +-
21 files changed, 28 insertions(+), 149 deletions(-)
delete mode 100644 cpukit/score/cpu/nios2/nios2-initialize-vectors.c
diff --git a/c/src/lib/libbsp/mips/shared/irq/exception.S b/c/src/lib/libbsp/mips/shared/irq/exception.S
index 55fdf27..8ac1035 100644
--- a/c/src/lib/libbsp/mips/shared/irq/exception.S
+++ b/c/src/lib/libbsp/mips/shared/irq/exception.S
@@ -88,7 +88,6 @@
.extern _Thread_Dispatch
-.extern _ISR_Vector_table
/* void __ISR_Handler()
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index c0ba479..3a86ad5 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -423,7 +423,7 @@ dont_fix_pil2:
sethi %hi(SYM(_ISR_Vector_table)), %g4
- ld [%g4+%lo(SYM(_ISR_Vector_table))], %g4
+ or %g4, %lo(SYM(_ISR_Vector_table)), %g4
and %l3, 0xFF, %g5 ! remove synchronous trap indicator
sll %g5, 2, %g5 ! g5 = offset into table
ld [%g4 + %g5], %g4 ! g4 = _ISR_Vector_table[ vector ]
diff --git a/c/src/lib/libcpu/sparc64/shared/score/interrupt.S b/c/src/lib/libcpu/sparc64/shared/score/interrupt.S
index 53b634a..0a01554 100644
--- a/c/src/lib/libcpu/sparc64/shared/score/interrupt.S
+++ b/c/src/lib/libcpu/sparc64/shared/score/interrupt.S
@@ -249,7 +249,6 @@ PUBLIC(_ISR_Handler)
* we just enabled traps. It is definitely in g2.
setx SYM(_ISR_Vector_table), %o5, %g1
- ldx [%g1], %g1
and %g2, 0x1FF, %o5 ! remove synchronous trap indicator
sll %o5, 3, %o5 ! o5 = offset into table
ldx [%g1 + %o5], %g1 ! g1 = _ISR_Vector_table[ vector ]
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index c58915c4..ad432ed 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2284,31 +2284,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#endif
- * On architectures that use Simple Vectored Interrupts, it is RTEMS
- * responsibility to allocate the vector table. This avoids reserving
- * the memory on architectures that use the Programmable Interrupt
- * Controller Vectored Interrupts.
-#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
- * This is a (hopefully) temporary hack. On the mips, the number of
- * vectors is NOT statically defined. But it has to be statically
- * defined for this to work. This is an issue looking for a nice
- * solution.
- #if defined(__mips__)
- #define CONFIGURE_INTERRUPT_VECTOR_TABLE \
- _Configure_From_workspace( (sizeof(ISR_Handler_entry) * 256))
- #else
- _Configure_From_workspace( \
- (sizeof(ISR_Handler_entry) * ISR_NUMBER_OF_VECTORS))
- #endif
-#else
- #define CONFIGURE_INTERRUPT_VECTOR_TABLE 0
-#endif
* RTEMS uses two instance of an internal mutex class. This accounts
* for these mutexes.
@@ -2337,7 +2312,6 @@ const rtems_libio_helper rtems_fs_init_helper =
#define CONFIGURE_MEMORY_FOR_SYSTEM_OVERHEAD \
( CONFIGURE_MEMORY_FOR_IDLE_TASK + /* IDLE and stack */ \
- CONFIGURE_INTERRUPT_VECTOR_TABLE + /* interrupt vectors */ \
CONFIGURE_INTERRUPT_STACK_MEMORY + /* interrupt stack */ \
CONFIGURE_API_MUTEX_MEMORY /* allocation mutex */ \
@@ -2755,7 +2729,6 @@ const rtems_libio_helper rtems_fs_init_helper =
uint32_t POSIX;
/* System overhead pieces */
- uint32_t INTERRUPT_VECTOR_TABLE;
uint32_t INTERRUPT_STACK_MEMORY;
uint32_t MEMORY_FOR_IDLE_TASK;
@@ -2810,7 +2783,6 @@ const rtems_libio_helper rtems_fs_init_helper =
CONFIGURE_MEMORY_FOR_POSIX,
- CONFIGURE_INTERRUPT_VECTOR_TABLE,
CONFIGURE_INTERRUPT_STACK_MEMORY,
CONFIGURE_MEMORY_FOR_IDLE_TASK,
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index ccf8c9a..cb9dc7c 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -171,10 +171,6 @@
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
-#define CPU_INTERRUPT_NUMBER_OF_VECTORS 8
-#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
#define CPU_STACK_MINIMUM_SIZE (1024 * 4)
diff --git a/cpukit/score/cpu/bfin/cpu_asm.S b/cpukit/score/cpu/bfin/cpu_asm.S
index d594f92..015caef 100644
--- a/cpukit/score/cpu/bfin/cpu_asm.S
+++ b/cpukit/score/cpu/bfin/cpu_asm.S
@@ -359,9 +359,8 @@ vectorIDLoop:
if !cc jump vectorIDLoop;
[--sp] = r2;
- p0.h = SYM(_ISR_Vector_table);
- p0.l = SYM(_ISR_Vector_table);
- r2 = [p0];
+ r2.h = SYM(_ISR_Vector_table);
+ r2.l = SYM(_ISR_Vector_table);
r1 = r0 << 2;
r1 = r1 + r2;
p0 = r1;
diff --git a/cpukit/score/cpu/h8300/cpu_asm.S b/cpukit/score/cpu/h8300/cpu_asm.S
index 0dc79a9..9e89a83 100644
--- a/cpukit/score/cpu/h8300/cpu_asm.S
+++ b/cpukit/score/cpu/h8300/cpu_asm.S
@@ -133,12 +133,10 @@ nested:
/* Vector to ISR */
- mov.l @SYM(_ISR_Vector_table),er1
mov er0,er2 ; copy vector
shll.l er2
shll.l er2 ; vector = vector * 4 (sizeof(int))
- add.l er2,er1
- mov.l @er1,er1
+ mov.l @(SYM(_ISR_Vector_table), er2),er1
jsr @er1 ; er0 = arg1 =vector
orc #0xc0,ccr
diff --git a/cpukit/score/cpu/i386/rtems/score/cpu.h b/cpukit/score/cpu/i386/rtems/score/cpu.h
index be22d9e..a9957cb 100644
--- a/cpukit/score/cpu/i386/rtems/score/cpu.h
+++ b/cpukit/score/cpu/i386/rtems/score/cpu.h
@@ -316,13 +316,6 @@ SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 1024
- * i386 family supports 256 distinct vectors.
-#define CPU_INTERRUPT_NUMBER_OF_VECTORS 256
* This is defined if the port has a special way to report the ISR nesting
* level. Most ports maintain the variable _ISR_Nest_level.
diff --git a/cpukit/score/cpu/m68k/cpu_asm.S b/cpukit/score/cpu/m68k/cpu_asm.S
index 4db6723..a31c158 100644
--- a/cpukit/score/cpu/m68k/cpu_asm.S
+++ b/cpukit/score/cpu/m68k/cpu_asm.S
@@ -276,13 +276,8 @@ SYM (_ISR_Handler):
addql #1,ISR_NEST_LEVEL | one nest level deeper
- movel SYM (_ISR_Vector_table),a0 | a0= base of RTEMS table
-#if ( M68K_HAS_PREINDEXING == 1 )
- movel (a0,d0:w:1),a0 | a0 = address of user routine
-#else
- addal d0,a0 | a0 = address of vector
- movel (a0),a0 | a0 = address of user routine
-#endif
+ lea SYM(_ISR_Vector_table),a0
+ movel (a0,d0),a0 | a0 = address of user routine
lsrl #2,d0 | d0 = vector number
movel d0,a7 at - | push vector number
diff --git a/cpukit/score/cpu/mips/cpu_asm.S b/cpukit/score/cpu/mips/cpu_asm.S
index 3450451..c58aee1 100644
--- a/cpukit/score/cpu/mips/cpu_asm.S
+++ b/cpukit/score/cpu/mips/cpu_asm.S
@@ -583,7 +583,6 @@ FRAME(_CPU_Context_restore,sp,0,ra)
ENDFRAME(_CPU_Context_restore)
/* void _DBG_Handler()
diff --git a/cpukit/score/cpu/mips/rtems/score/cpu.h b/cpukit/score/cpu/mips/rtems/score/cpu.h
index b871969..392a995 100644
--- a/cpukit/score/cpu/mips/rtems/score/cpu.h
+++ b/cpukit/score/cpu/mips/rtems/score/cpu.h
@@ -660,15 +660,6 @@ SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
- * This defines the number of entries in the ISR_Vector_table managed
- * by RTEMS.
-extern unsigned int mips_interrupt_number_of_vectors;
-#define CPU_INTERRUPT_NUMBER_OF_VECTORS (mips_interrupt_number_of_vectors)
* Should be large enough to run all RTEMS tests. This ensures
* that a "reasonable" small application should not have any problems.
diff --git a/cpukit/score/cpu/nios2/Makefile.am b/cpukit/score/cpu/nios2/Makefile.am
index 62286cd..6004467 100644
--- a/cpukit/score/cpu/nios2/Makefile.am
+++ b/cpukit/score/cpu/nios2/Makefile.am
@@ -33,7 +33,6 @@ libscorecpu_a_SOURCES += nios2-fatal-halt.c
libscorecpu_a_SOURCES += nios2-iic-low-level.S
libscorecpu_a_SOURCES += nios2-iic-irq.c
libscorecpu_a_SOURCES += nios2-initialize.c
-libscorecpu_a_SOURCES += nios2-initialize-vectors.c
libscorecpu_a_SOURCES += nios2-isr-get-level.c
libscorecpu_a_SOURCES += nios2-isr-install-raw-handler.c
libscorecpu_a_SOURCES += nios2-isr-install-vector.c
diff --git a/cpukit/score/cpu/nios2/nios2-initialize-vectors.c b/cpukit/score/cpu/nios2/nios2-initialize-vectors.c
deleted file mode 100644
index da1ee4b..0000000
--- a/cpukit/score/cpu/nios2/nios2-initialize-vectors.c
+++ /dev/null
@@ -1,25 +0,0 @@
- * Copyright (c) 2011 embedded brains GmbH
- * Copyright (c) 2006 Kolja Waschk (rtemsdev/ixo.de)
- * COPYRIGHT (c) 1989-2006
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include <rtems/score/isr.h>
-#include <string.h>
-void _CPU_Initialize_vectors( void )
- memset(_ISR_Vector_table, 0, sizeof(ISR_Handler_entry) * ISR_NUMBER_OF_VECTORS);
diff --git a/cpukit/score/cpu/nios2/rtems/score/cpu.h b/cpukit/score/cpu/nios2/rtems/score/cpu.h
index 6c62a1f..fcfef8d 100644
--- a/cpukit/score/cpu/nios2/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/rtems/score/cpu.h
@@ -192,7 +192,7 @@ typedef struct {
uint32_t ipending;
} CPU_Exception_frame;
-void _CPU_Initialize_vectors( void );
+#define _CPU_Initialize_vectors()
* @brief Macro to disable interrupts.
diff --git a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
index 959fb58..fbf207a 100644
--- a/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/rtems/score/cpu.h
@@ -686,19 +686,24 @@ SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
* @ingroup CPUInterrupt
- * This defines the number of entries in the @ref _ISR_Vector_table managed
- * by RTEMS.
+ * This defines the number of entries in the _ISR_Vector_table managed by RTEMS
+ * in case CPU_SIMPLE_VECTORED_INTERRUPTS is defined to TRUE. It must be a
+ * compile-time constant.
- * Port Specific Information:
- * XXX document implementation including references if appropriate
+ * It must be undefined in case CPU_SIMPLE_VECTORED_INTERRUPTS is defined to
+ * FALSE.
#define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
- * This defines the highest interrupt vector number for this port.
+ * This defines the highest interrupt vector number for this port in case
+ * CPU_SIMPLE_VECTORED_INTERRUPTS is defined to TRUE. It must be less than
+ * CPU_INTERRUPT_NUMBER_OF_VECTORS. It may be not a compile-time constant.
+ * FALSE.
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpu.h b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
index 3130b35..3a51b31 100644
--- a/cpukit/score/cpu/powerpc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpu.h
@@ -599,16 +599,6 @@ SCORE_EXTERN struct {
- * by RTEMS.
- * NOTE: CPU_INTERRUPT_NUMBER_OF_VECTORS and
- * CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER are only used on
- * Simple Vectored Architectures and thus are not defined
- * for this architecture.
* level. Most ports maintain the variable _ISR_Nest_level. Note that
* this is not an option - RTEMS/score _relies_ on _ISR_Nest_level
diff --git a/cpukit/score/cpu/v850/rtems/score/cpu.h b/cpukit/score/cpu/v850/rtems/score/cpu.h
index 35ed6e6..7234d67 100644
--- a/cpukit/score/cpu/v850/rtems/score/cpu.h
+++ b/cpukit/score/cpu/v850/rtems/score/cpu.h
@@ -549,25 +549,6 @@ typedef struct {
-/* XXX this should not be needed on PIC architectures */
-/* XXX evaluate removing it */
-#if 0
- * by RTEMS.
-#define CPU_INTERRUPT_NUMBER_OF_VECTORS 32
-#endif
* level. Most ports maintain the variable @a _ISR_Nest_level.
diff --git a/cpukit/score/include/rtems/score/isr.h b/cpukit/score/include/rtems/score/isr.h
index f1ac5ae..dcb25e1 100644
--- a/cpukit/score/include/rtems/score/isr.h
+++ b/cpukit/score/include/rtems/score/isr.h
@@ -71,22 +71,10 @@ typedef ISR_Handler ( *ISR_Handler_entry )(
#endif
- * This constant promotes out the number of vectors truly supported by
- * the current CPU being used. This is usually the number of distinct vectors
- * the cpu can vector.
-#define ISR_NUMBER_OF_VECTORS CPU_INTERRUPT_NUMBER_OF_VECTORS
- * This constant promotes out the highest valid interrupt vector number.
-#define ISR_INTERRUPT_MAXIMUM_VECTOR_NUMBER CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER
* The following declares the Vector Table. Application
* interrupt service routines are vectored by the ISR Handler via this table.
-SCORE_EXTERN ISR_Handler_entry *_ISR_Vector_table;
+extern ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
#endif
diff --git a/cpukit/score/src/isr.c b/cpukit/score/src/isr.c
index 07f3e61..1ae6e59 100644
--- a/cpukit/score/src/isr.c
+++ b/cpukit/score/src/isr.c
@@ -26,15 +26,19 @@
#include <rtems/config.h>
+#if (CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE)
+ ISR_Handler_entry _ISR_Vector_table[ CPU_INTERRUPT_NUMBER_OF_VECTORS ];
+#elif defined(CPU_INTERRUPT_NUMBER_OF_VECTORS)
+ #error "CPU_INTERRUPT_NUMBER_OF_VECTORS is defined for non-simple vectored interrupts"
+#elif defined(CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER)
+ #error "CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER is defined for non-simple vectored interrupts"
+#endif
void _ISR_Handler_initialization( void )
_ISR_Nest_level = 0;
- _ISR_Vector_table = _Workspace_Allocate_or_fatal_error(
- sizeof(ISR_Handler_entry) * ISR_NUMBER_OF_VECTORS
_CPU_Initialize_vectors();
#endif
diff --git a/testsuites/sptests/spfatal07/testcase.h b/testsuites/sptests/spfatal07/testcase.h
index 25fc8f2..e18563c 100644
--- a/testsuites/sptests/spfatal07/testcase.h
+++ b/testsuites/sptests/spfatal07/testcase.h
@@ -37,10 +37,6 @@ rtems_initialization_tasks_table Initialization_tasks[] = {
#define FATAL_ERROR_EXPECTED_ERROR \
INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
-#if CPU_SIMPLE_VECTORED_INTERRUPTS == TRUE
- #define CONFIGURE_MEMORY_OVERHEAD (sizeof(ISR_Handler_entry) * ISR_NUMBER_OF_VECTORS)
-#endif
#if CPU_ALLOCATE_INTERRUPT_STACK == TRUE
#define CONFIGURE_INTERRUPT_STACK_SIZE (STACK_MINIMUM_SIZE - 1)
#endif
diff --git a/testsuites/sptests/spintr_err01/init.c b/testsuites/sptests/spintr_err01/init.c
index c2c39ae..84ebfdb 100644
--- a/testsuites/sptests/spintr_err01/init.c
+++ b/testsuites/sptests/spintr_err01/init.c
@@ -36,7 +36,7 @@ rtems_task Init(
rtems_isr_entry old_service_routine;
status = rtems_interrupt_catch(
Service_routine,
- ISR_INTERRUPT_MAXIMUM_VECTOR_NUMBER + 10,
+ CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER + 1,
&old_service_routine
fatal_directive_status(
1.7.7
