[PATCH] doc: Extend documentation for unlimited objects
Tue Apr 29 17:55:05 UTC 2014
No, although the only one I see in confdefs.h is posix msq queues
On Tue, Apr 29, 2014 at 12:02 PM, Joel Sherrill
<Joel.Sherrill at oarcorp.com> wrote:
> +1
> One odd thought.. Can we detect when objects which are not unlimited are
> configured that way?
> On Apr 29, 2014 10:40 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Looks good to me.
> On Tue, Apr 29, 2014 at 10:57 AM, Ralf Kirchner
> <ralf.kirchner at embedded-brains.de> wrote:
>> Mark POSIX Keys and POSIX Key Value Pairs as supported.
>> Add list of unsupported object classes.
>> Add hint to unified work areas.
>> Add example.
>>  doc/user/conf.t |   40 ++++++++++++++++++++++++++++++++++++----
>>  1 Datei geändert, 36 Zeilen hinzugefügt(+), 4 Zeilen entfernt(-)
>> diff --git a/doc/user/conf.t b/doc/user/conf.t
>> index f0aa022..ef40480 100644
>> --- a/doc/user/conf.t
>> +++ b/doc/user/conf.t
>> @@ -355,6 +355,14 @@ software is unknown. In these situations users do not
>> need to control
>>  the size of the workspace very tightly because they just want to get
>>  the new software to run; later they can tune the workspace size as
>> needed.
>> +The following API-independent object classes can be configured in
>> +unlimited mode:
>> + at itemize @bullet
>> + at item POSIX Keys
>> + at item POSIX Key Value Pairs
>> + at end itemize
>>  The following object classes in the Classic API can be configured in
>>  unlimited mode:
>> @@ -377,7 +385,6 @@ configured in unlimited mode:
>>  @item Threads
>>  @item Mutexes
>>  @item Condition Variables
>> - at item Keys
>>  @item Timers
>>  @item Message Queues
>>  @item Message Queue Descriptors
>> @@ -387,9 +394,34 @@ configured in unlimited mode:
>>  @item Spinlocks
>>  @end itemize
>> -Due to how the POSIX object memory requirements are configured the
>> -unlimited object support does not provide unlimited size declarations
>> -for POSIX keys or queued signals.
>> +The following object classes can @strong{not} be configured in unlimited
>> mode:
>> + at item Drivers
>> + at item File Descriptors
>> + at item User Extensions
>> + at item Queued Signals
>> + at end itemize
>> +Due to the memory requirements of unlimited objects it is strongly
>> recommended
>> +to use them only in combination with the unified work areas. See
>> + at ref{Configuring a System Separate or Unified Work Areas} for more
>> information
>> +on unified work areas.
>> +The following example demonstrates how the two simple configuration
>> defines for
>> +unlimited objects and unified works areas can replace many seperate
>> +configuration defines for supported object classes:
>> + at example
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_UNIFIED_WORK_AREAS
>> +#define CONFIGURE_UNLIMITED_OBJECTS
>> +#define CONFIGURE_INIT
>> +#include <rtems/confdefs.h>
>> + at end example
>>  Users are cautioned that using unlimited objects is not recommended for
>>  production software unless the dynamic growth is absolutely required. It
>> 1.7.10.4
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
