[PATCH 1/3] Add and use RTEMS_CONTAINER_OF()
Mon Aug 4 13:59:19 UTC 2014
Thanks, two style comments below.
On Sun, Aug 3, 2014 at 8:45 AM, Sebastian Huber
>  cpukit/libblock/src/bdbuf.c                        |  4 +-
>  cpukit/posix/include/rtems/posix/keyimpl.h         |  3 ++
>  cpukit/posix/src/key.c                             |  4 +-
>  cpukit/posix/src/keyfreememory.c                   |  8 ++--
>  cpukit/posix/src/keygetspecific.c                  |  4 +-
>  cpukit/posix/src/keysetspecific.c                  |  5 +--
>  cpukit/sapi/include/rtems/rbheap.h                 |  2 +-
>  cpukit/sapi/include/rtems/rbtree.h                 | 10 -----
>  cpukit/score/include/rtems/score/basedefs.h        | 10 +++++
>  cpukit/score/include/rtems/score/mrspimpl.h        |  2 +-
>  cpukit/score/include/rtems/score/rbtree.h          | 14 -------
>  .../score/include/rtems/score/scheduleredfimpl.h   |  2 +-
>  cpukit/score/include/rtems/score/schedulerimpl.h   |  2 +-
>  cpukit/score/include/rtems/score/threadimpl.h      | 18 ++++-----
>  cpukit/score/src/resourceiterate.c                 |  6 +--
>  cpukit/score/src/schedulerchangeroot.c             |  2 +-
>  cpukit/score/src/scheduleredf.c                    |  4 +-
>  cpukit/score/src/threadq.c                         | 12 +++---
>  cpukit/score/src/threadqdequeue.c                  |  2 +-
>  cpukit/score/src/threadqfirst.c                    |  5 ++-
>  testsuites/sptests/sprbtree01/init.c               | 44 +++++++++++-----------
>  21 files changed, 72 insertions(+), 91 deletions(-)
> diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
> index 31dd289..f215911 100644
> --- a/cpukit/libblock/src/bdbuf.c
> +++ b/cpukit/libblock/src/bdbuf.c
> @@ -3178,8 +3178,8 @@ rtems_bdbuf_read_ahead_task (rtems_task_argument arg)
>      while ((node = rtems_chain_get_unprotected (chain)) != NULL)
> -      rtems_disk_device *dd = (rtems_disk_device *)
> -        ((char *) node - offsetof (rtems_disk_device, read_ahead.node));
> +      rtems_disk_device *dd =
> +        RTEMS_CONTAINER_OF (node, rtems_disk_device, read_ahead.node);
Delete the extra space between OF and (.
> diff --git a/cpukit/score/src/scheduleredf.c b/cpukit/score/src/scheduleredf.c
> index 01b5244..231bc04 100644
> --- a/cpukit/score/src/scheduleredf.c
> +++ b/cpukit/score/src/scheduleredf.c
> @@ -25,9 +25,9 @@ int _Scheduler_EDF_Compare(
>    const RBTree_Node* n2
> -  Priority_Control value1 = _RBTree_Container_of
> +  Priority_Control value1 = RTEMS_CONTAINER_OF
>      (n1,Scheduler_EDF_Node,Node)->thread->current_priority;
> -  Priority_Control value2 = _RBTree_Container_of
> +  Priority_Control value2 = RTEMS_CONTAINER_OF
>      (n2,Scheduler_EDF_Node,Node)->thread->current_priority;
Fix the whitespace here, by moving the opening parens to after OF?
-Gedare
