[PATCH 3/3] rbtree: Simplify _RBTree_Extract()
Tue Aug 5 14:27:59 UTC 2014
 cpukit/score/src/rbtreeextract.c | 18 ++++++++++--------
 1 file changed, 10 insertions(+), 8 deletions(-)
diff --git a/cpukit/score/src/rbtreeextract.c b/cpukit/score/src/rbtreeextract.c
index f3a7328..2be6a23 100644
--- a/cpukit/score/src/rbtreeextract.c
+++ b/cpukit/score/src/rbtreeextract.c
@@ -23,7 +23,6 @@
 static void _RBTree_Extract_validate( RBTree_Node *the_node )
   RBTree_Node     *parent;
-  RBTree_Direction dir;
   parent = the_node->parent;
@@ -40,11 +39,13 @@ static void _RBTree_Extract_validate( RBTree_Node *the_node )
      * update sibling pointer.
     if ( _RBTree_Is_red( sibling ) ) {
+      RBTree_Direction dir = the_node != parent->child[ 0 ];
+      RBTree_Direction opp_dir = _RBTree_Opposite_direction( dir );
       parent->color = RBT_RED;
       sibling->color = RBT_BLACK;
-      dir = the_node != parent->child[ 0 ];
       _RBTree_Rotate( parent, dir );
-      sibling = parent->child[ _RBTree_Opposite_direction( dir ) ];
+      sibling = parent->child[ opp_dir ];
     /* sibling is black, see if both of its children are also black. */
@@ -66,20 +67,21 @@ static void _RBTree_Extract_validate( RBTree_Node *the_node )
        * and if so rotate in the proper direction and update sibling pointer.
        * Then switch the sibling and parent colors, and rotate through parent.
       if (
-        !_RBTree_Is_red( sibling->child[ _RBTree_Opposite_direction( dir ) ] )
+        !_RBTree_Is_red( sibling->child[ opp_dir ] )
         sibling->color = RBT_RED;
         sibling->child[ dir ]->color = RBT_BLACK;
-        _RBTree_Rotate( sibling, _RBTree_Opposite_direction( dir ) );
+        _RBTree_Rotate( sibling, opp_dir );
       sibling->color = parent->color;
       parent->color = RBT_BLACK;
-      sibling->child[ _RBTree_Opposite_direction( dir ) ]->color = RBT_BLACK;
+      sibling->child[ opp_dir ]->color = RBT_BLACK;
       break; /* done */
1.8.1.4
