Unused macro: CPU_ISR_PASSES_FRAME_POINTER
Hesham Moustafa heshamelmatary at gmail.com
Fri Aug 8 14:38:20 UTC 2014
On Fri, Aug 8, 2014 at 4:02 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 8/8/2014 8:54 AM, Gedare Bloom wrote:
>> Hi,
>> The macro CPU_ISR_PASSES_FRAME_POINTER is part of a cpu port defined
>> in cpu.h, but this macro seems to be unused. I don't know what the
>> purpose of it was intended. Anyway, it appears to be wrong for some
>> architectures (ARM and sparc64 at least, maybe others). Should we
>> remove the macro, or find a use for it and make sure it is correctly
>> defined for each arch?
> The intent is that for simple vectored, some architectures passed a vector
> number and some passed a vector number and a pointer to the interrupt
> stack frame. This predates the addition of the PIC model.
> In general terms, I don't know if all simple vectored architectures
> pass one or two parameters.
> Is this used anywhere in the tree? Sometimes drivers would use it to
> adjust the ISR handler prototype to avoid warnings.
It's used only at isr.h:62
62 #if (CPU_ISR_PASSES_FRAME_POINTER == 1)
 63 typedef ISR_Handler ( *ISR_Handler_entry )(
 64                  ISR_Vector_number,
 65                  CPU_Interrupt_frame *
 66              );
 67 #else
 68 typedef ISR_Handler ( *ISR_Handler_entry )(
 69                  ISR_Vector_number
 70              );
 71 #endif
>> Gedare
>> devel mailing list
>> devel at rtems.org
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Support Available                (256) 722-9985
> devel mailing list
> devel at rtems.org
