OpenRISC port | using shadow registers from exception context
Hesham Moustafa
heshamelmatary at gmail.com
Sat Aug 9 11:22:33 UTC 2014
Hi all,
I am trying to optimize the _ISR_Handler code. OpenRISC folks
indicated that I can use shadow registers to hold interrupted task
context. There are 512 SPRs that can be used for mapping general
purpose registers to these SPRs (I guess we can use them for nesting
interrupts, given that interrupt level can be an index/base?)
That said, if I mapped task context registers to SPRs, should I
populate CPU_Exception_frame from _ISR_Handler? Or I can just use the
values from SPRs when needed (i.e, restore interrupted task context
before returning from interrupt?) Some functions like
print_exception_frame may need the context to be saved in memory.
Also, some other C handlers may need a pointer to the frame in memory.
Thanks,
Hesham
