[PATCH 2/2] bsp/lpc24xx: Add LPC40XX variants
Mon Aug 11 20:48:39 UTC 2014
 c/src/lib/libbsp/arm/lpc24xx/Makefile.am           | 27 ++++++-----
 c/src/lib/libbsp/arm/lpc24xx/configure.ac          | 12 ++---
 .../lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc | 11 +++++
 .../arm/lpc24xx/make/custom/lpc40xx_ea_ram.cfg     |  5 ++
 .../arm/lpc24xx/make/custom/lpc40xx_ea_rom_int.cfg |  5 ++
 c/src/lib/libbsp/arm/lpc24xx/preinstall.am         | 56 ++++++++++++++++++++++
 .../arm/lpc24xx/startup/linkcmds.lpc40xx_ea_ram    |  1 +
 .../lpc24xx/startup/linkcmds.lpc40xx_ea_rom_int    |  1 +
 8 files changed, 99 insertions(+), 19 deletions(-)
 create mode 100644 c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc
 create mode 100644 c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_ram.cfg
 create mode 100644 c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int.cfg
 create mode 100644 c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_ram
 create mode 100644 c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_rom_int
diff --git a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
index 3b5c94f..b2fdd5f 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
+++ b/c/src/lib/libbsp/arm/lpc24xx/Makefile.am
@@ -66,19 +66,20 @@ libbspstart_a_SOURCES = ../shared/start/start.S
 project_lib_DATA = start.$(OBJEXT)
 project_lib_DATA += startup/linkcmds
-EXTRA_DIST =
-EXTRA_DIST += startup/linkcmds.lpc17xx_ea_ram
-EXTRA_DIST += startup/linkcmds.lpc17xx_ea_rom_int
-EXTRA_DIST += startup/linkcmds.lpc17xx_plx800_ram
-EXTRA_DIST += startup/linkcmds.lpc17xx_plx800_rom_int
-EXTRA_DIST += startup/linkcmds.lpc2362
-EXTRA_DIST += startup/linkcmds.lpc23xx_tli800
-EXTRA_DIST += startup/linkcmds.lpc24xx_ea
-EXTRA_DIST += startup/linkcmds.lpc24xx_ncs_ram
-EXTRA_DIST += startup/linkcmds.lpc24xx_ncs_rom_ext
-EXTRA_DIST += startup/linkcmds.lpc24xx_ncs_rom_int
-EXTRA_DIST += startup/linkcmds.lpc24xx_plx800_ram
-EXTRA_DIST += startup/linkcmds.lpc24xx_plx800_rom_int
+project_lib_DATA += startup/linkcmds.lpc17xx_ea_ram
+project_lib_DATA += startup/linkcmds.lpc17xx_ea_rom_int
+project_lib_DATA += startup/linkcmds.lpc17xx_plx800_ram
+project_lib_DATA += startup/linkcmds.lpc17xx_plx800_rom_int
+project_lib_DATA += startup/linkcmds.lpc2362
+project_lib_DATA += startup/linkcmds.lpc23xx_tli800
+project_lib_DATA += startup/linkcmds.lpc24xx_ea
+project_lib_DATA += startup/linkcmds.lpc24xx_ncs_ram
+project_lib_DATA += startup/linkcmds.lpc24xx_ncs_rom_ext
+project_lib_DATA += startup/linkcmds.lpc24xx_ncs_rom_int
+project_lib_DATA += startup/linkcmds.lpc24xx_plx800_ram
+project_lib_DATA += startup/linkcmds.lpc24xx_plx800_rom_int
+project_lib_DATA += startup/linkcmds.lpc40xx_ea_ram
+project_lib_DATA += startup/linkcmds.lpc40xx_ea_rom_int
 #                  LibBSP                                                     #
diff --git a/c/src/lib/libbsp/arm/lpc24xx/configure.ac b/c/src/lib/libbsp/arm/lpc24xx/configure.ac
index 737501f..e3747d5 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/configure.ac
+++ b/c/src/lib/libbsp/arm/lpc24xx/configure.ac
@@ -28,17 +28,17 @@ RTEMS_BSPOPTS_HELP([LPC24XX_OSCILLATOR_MAIN],[main oscillator frequency in Hz])
 RTEMS_BSPOPTS_SET([LPC24XX_OSCILLATOR_RTC],[*],[32768U])
 RTEMS_BSPOPTS_HELP([LPC24XX_OSCILLATOR_RTC],[RTC oscillator frequency in Hz])
-RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc17xx_ea*],[96000000U])
+RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc17xx_ea* | lpc40xx_ea*],[96000000U])
 RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc23*],[58982400U])
 RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[lpc24xx_plx800_*],[51612800U])
 RTEMS_BSPOPTS_SET([LPC24XX_CCLK],[*],[72000000U])
 RTEMS_BSPOPTS_HELP([LPC24XX_CCLK],[CPU clock in Hz])
-RTEMS_BSPOPTS_SET([LPC24XX_PCLKDIV],[lpc17xx_ea*],[2U])
+RTEMS_BSPOPTS_SET([LPC24XX_PCLKDIV],[lpc17xx_ea* | lpc40xx_ea*],[2U])
 RTEMS_BSPOPTS_SET([LPC24XX_PCLKDIV],[*],[1U])
 RTEMS_BSPOPTS_HELP([LPC24XX_PCLKDIV],[clock divider for default PCLK (PCLK = CCLK / PCLKDIV)])
-RTEMS_BSPOPTS_SET([LPC24XX_EMCCLKDIV],[lpc17xx_ea*],[2U])
+RTEMS_BSPOPTS_SET([LPC24XX_EMCCLKDIV],[lpc17xx_ea* | lpc40xx_ea*],[2U])
 RTEMS_BSPOPTS_SET([LPC24XX_EMCCLKDIV],[*],[1U])
 RTEMS_BSPOPTS_HELP([LPC24XX_EMCCLKDIV],[clock divider for EMCCLK (EMCCLK = CCLK / EMCCLKDIV)])
@@ -60,7 +60,7 @@ RTEMS_BSPOPTS_HELP([LPC24XX_EMC_W9825G2JB75I],[enable Winbond W9825G2JB75I confi
 RTEMS_BSPOPTS_SET([LPC24XX_EMC_IS42S32800D7],[*_plx800_rom_*],[1])
 RTEMS_BSPOPTS_HELP([LPC24XX_EMC_IS42S32800D7],[enable ISSI IS42S32800D7 configuration for EMC])
-RTEMS_BSPOPTS_SET([LPC24XX_EMC_IS42S32800B],[lpc17xx_ea_rom_*],[1])
+RTEMS_BSPOPTS_SET([LPC24XX_EMC_IS42S32800B],[lpc17xx_ea_rom_* | lpc40xx_ea_rom_*],[1])
 RTEMS_BSPOPTS_HELP([LPC24XX_EMC_IS42S32800B],[enable ISSI IS42S32800B configuration for EMC])
 RTEMS_BSPOPTS_SET([LPC24XX_EMC_M29W160E],[lpc24xx_ncs_rom_*],[1])
@@ -112,14 +112,14 @@ RTEMS_BSPOPTS_SET([LPC24XX_STOP_USB],[lpc23*],[])
 RTEMS_BSPOPTS_SET([LPC24XX_STOP_USB],[*],[1])
 RTEMS_BSPOPTS_HELP([LPC24XX_STOP_USB],[stop USB controller at start-up to avoid DMA interference])
-RTEMS_BSPOPTS_SET([LPC_DMA_CHANNEL_COUNT],[lpc17*],[8])
+RTEMS_BSPOPTS_SET([LPC_DMA_CHANNEL_COUNT],[lpc17* | lpc40*],[8])
 RTEMS_BSPOPTS_SET([LPC_DMA_CHANNEL_COUNT],[*],[2])
 RTEMS_BSPOPTS_HELP([LPC_DMA_CHANNEL_COUNT],[DMA channel count])
 RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[lpc24xx_ncs_rom_ext],[0x80000040])
 RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for BSP start])
-RTEMS_BSPOPTS_SET([BSP_USB_OTG_TRANSCEIVER_I2C_ADDR],[lpc17xx_ea*],[(0x2f << 1)])
+RTEMS_BSPOPTS_SET([BSP_USB_OTG_TRANSCEIVER_I2C_ADDR],[lpc17xx_ea* | lpc40xx_ea*],[(0x2f << 1)])
 RTEMS_BSPOPTS_HELP([BSP_USB_OTG_TRANSCEIVER_I2C_ADDR],[USB OTG transceiver I2C address used by USB stack])
 RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
diff --git a/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc b/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc
new file mode 100644
index 0000000..2c921db
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc
@@ -0,0 +1,11 @@
+# Config file for LPC40XX.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU = arm
+CPU_CFLAGS = -mthumb -march=armv7-m -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mtune=cortex-m4
+CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_ram.cfg b/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_ram.cfg
index 0000000..4c4eb4d
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_ram.cfg
@@ -0,0 +1,5 @@
+# Config file for LPC40XX OEM Board from Embedded Artists.
+include $(RTEMS_ROOT)/make/custom/lpc40xx.inc
diff --git a/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int.cfg b/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int.cfg
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx_ea_rom_int.cfg
@@ -0,0 +1,5 @@
diff --git a/c/src/lib/libbsp/arm/lpc24xx/preinstall.am b/c/src/lib/libbsp/arm/lpc24xx/preinstall.am
index a022b02..3bf67a6 100644
--- a/c/src/lib/libbsp/arm/lpc24xx/preinstall.am
+++ b/c/src/lib/libbsp/arm/lpc24xx/preinstall.am
@@ -173,3 +173,59 @@ $(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
 TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
+$(PROJECT_LIB)/linkcmds.lpc17xx_ea_ram: startup/linkcmds.lpc17xx_ea_ram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc17xx_ea_ram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc17xx_ea_ram
+$(PROJECT_LIB)/linkcmds.lpc17xx_ea_rom_int: startup/linkcmds.lpc17xx_ea_rom_int $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc17xx_ea_rom_int
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc17xx_ea_rom_int
+$(PROJECT_LIB)/linkcmds.lpc17xx_plx800_ram: startup/linkcmds.lpc17xx_plx800_ram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc17xx_plx800_ram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc17xx_plx800_ram
+$(PROJECT_LIB)/linkcmds.lpc17xx_plx800_rom_int: startup/linkcmds.lpc17xx_plx800_rom_int $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc17xx_plx800_rom_int
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc17xx_plx800_rom_int
+$(PROJECT_LIB)/linkcmds.lpc2362: startup/linkcmds.lpc2362 $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc2362
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc2362
+$(PROJECT_LIB)/linkcmds.lpc23xx_tli800: startup/linkcmds.lpc23xx_tli800 $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc23xx_tli800
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc23xx_tli800
+$(PROJECT_LIB)/linkcmds.lpc24xx_ea: startup/linkcmds.lpc24xx_ea $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc24xx_ea
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc24xx_ea
+$(PROJECT_LIB)/linkcmds.lpc24xx_ncs_ram: startup/linkcmds.lpc24xx_ncs_ram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc24xx_ncs_ram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc24xx_ncs_ram
+$(PROJECT_LIB)/linkcmds.lpc24xx_ncs_rom_ext: startup/linkcmds.lpc24xx_ncs_rom_ext $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc24xx_ncs_rom_ext
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc24xx_ncs_rom_ext
+$(PROJECT_LIB)/linkcmds.lpc24xx_ncs_rom_int: startup/linkcmds.lpc24xx_ncs_rom_int $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc24xx_ncs_rom_int
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc24xx_ncs_rom_int
+$(PROJECT_LIB)/linkcmds.lpc24xx_plx800_ram: startup/linkcmds.lpc24xx_plx800_ram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc24xx_plx800_ram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc24xx_plx800_ram
+$(PROJECT_LIB)/linkcmds.lpc24xx_plx800_rom_int: startup/linkcmds.lpc24xx_plx800_rom_int $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc24xx_plx800_rom_int
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc24xx_plx800_rom_int
+$(PROJECT_LIB)/linkcmds.lpc40xx_ea_ram: startup/linkcmds.lpc40xx_ea_ram $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc40xx_ea_ram
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc40xx_ea_ram
+$(PROJECT_LIB)/linkcmds.lpc40xx_ea_rom_int: startup/linkcmds.lpc40xx_ea_rom_int $(PROJECT_LIB)/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.lpc40xx_ea_rom_int
+TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.lpc40xx_ea_rom_int
diff --git a/c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_ram b/c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_ram
index 0000000..d453596
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_ram
@@ -0,0 +1 @@
+INCLUDE linkcmds.lpc17xx_ea_ram
diff --git a/c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_rom_int b/c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_rom_int
index 0000000..612f491
--- /dev/null
+++ b/c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc40xx_ea_rom_int
@@ -0,0 +1 @@
+INCLUDE linkcmds.lpc17xx_ea_rom_int
1.8.1.4
