[PATCH 1/2] arm: Add support for FPv4-SP floating point unit
Mon Aug 11 20:48:38 UTC 2014
This floating point unit is available in Cortex-M4F processors and
defined by ARMv7-M.  This adds basic support for other VFP-D16 variants.
 c/src/lib/libbsp/arm/shared/start/start.S          | 20 ++++++++++++++
 cpukit/score/cpu/arm/arm-context-validate.S        | 31 +++++++++++++---------
 .../score/cpu/arm/arm-context-volatile-clobber.S   |  8 +++---
 cpukit/score/cpu/arm/arm_exc_interrupt.S           | 12 ++++++---
 cpukit/score/cpu/arm/armv4-exception-default.S     |  6 +++--
 cpukit/score/cpu/arm/armv7m-context-switch.c       | 13 +++++++--
 cpukit/score/cpu/arm/armv7m-isr-dispatch.c         | 30 +++++++++++++++++----
 cpukit/score/cpu/arm/cpu.c                         |  2 +-
 cpukit/score/cpu/arm/cpu_asm.S                     |  4 +--
 cpukit/score/cpu/arm/rtems/score/arm.h             | 17 +++++++++---
 cpukit/score/cpu/arm/rtems/score/armv7m.h          | 22 ++++++++++++++-
 cpukit/score/cpu/arm/rtems/score/cpu.h             |  8 +++---
 12 files changed, 133 insertions(+), 40 deletions(-)
diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
index 096e9bd..8c73b8d 100644
--- a/c/src/lib/libbsp/arm/shared/start/start.S
+++ b/c/src/lib/libbsp/arm/shared/start/start.S
@@ -300,6 +300,26 @@ bsp_start_vector_table_end:
 _start:
+#ifdef ARM_MULTILIB_VFP
+	/* CPACR is located at address 0xe000ed88 */
+	ldr.w	r0, =0xe000ed88
+	/* Read CPACR */
+	ldr	r1, [r0]
+	/* Set bits 20-23 to enable CP10 and CP11 co-processors */
+	orr	r1, r1, #(0xf << 20)
+	/* Write back the modified value to the CPACR */
+	str	r1, [r0]
+	/* Wait for store to complete */
+	dsb
+	/* Reset pipeline now the FPU is enabled */
+	isb
+#endif
 	ldr	sp, =bsp_stack_main_end
 	ldr	lr, =bsp_start_hook_0_done + 1
 	b	bsp_start_hook_0
diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
index f2772b4..fdfb6c1 100644
--- a/cpukit/score/cpu/arm/arm-context-validate.S
+++ b/cpukit/score/cpu/arm/arm-context-validate.S
@@ -1,5 +1,5 @@
- * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
  *  embedded brains GmbH
  *  Dornierstr. 4
@@ -29,7 +29,7 @@
 #define FRAME_OFFSET_R11 28
 #define FRAME_OFFSET_LR 32
-#ifdef ARM_MULTILIB_VFP_D32
   #define FRAME_OFFSET_D8 40
   #define FRAME_OFFSET_D9 48
   #define FRAME_OFFSET_D10 56
@@ -71,7 +71,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
 	mov	r1, lr
 	str	r1, [sp, #FRAME_OFFSET_LR]
 	vstr	d8, [sp, #FRAME_OFFSET_D8]
 	vstr	d9, [sp, #FRAME_OFFSET_D9]
 	vstr	d10, [sp, #FRAME_OFFSET_D10]
@@ -96,11 +96,15 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
 .endm
 	/* R3 contains the FPSCR */
 	vmrs	r3, FPSCR
 	movs	r4, #0x001f
+#ifdef ARM_MULTILIB_ARCH_V7M
+	movt	r4, #0xf000
+#else
 	movt	r4, #0xf800
+#endif
 	bic	r3, r3, r4
 	and	r4, r4, r0
 	orr	r3, r3, r4
@@ -120,7 +124,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
 	fill_register	r12
 	fill_register	lr
 .macro fill_vfp_register reg
 	add	r1, r1, #1
 	vmov	\reg, r1, r1
@@ -142,6 +146,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
 	fill_vfp_register	d13
 	fill_vfp_register	d14
 	fill_vfp_register	d15
+#ifdef ARM_MULTILIB_VFP_D32
 	fill_vfp_register	d16
 	fill_vfp_register	d17
 	fill_vfp_register	d18
@@ -158,7 +163,8 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
 	fill_vfp_register	d29
 	fill_vfp_register	d30
 	fill_vfp_register	d31
-#endif
+#endif /* ARM_MULTILIB_VFP_D32 */
+#endif /* ARM_MULTILIB_VFP */
 	/* Check */
 check:
@@ -174,7 +180,7 @@ check:
 	mov	r1, r0
-#ifndef ARM_MULTILIB_VFP_D32
+#ifndef ARM_MULTILIB_VFP
 	check_register	r3
 #endif
@@ -189,7 +195,7 @@ check:
 	check_register	r12
 	check_register	lr
 	b	check_vfp
 #endif
@@ -217,7 +223,7 @@ restore:
 	ldr	r1, [sp, #FRAME_OFFSET_LR]
 	mov	lr, r1
 	vldr	d8, [sp, #FRAME_OFFSET_D8]
 	vldr	d9, [sp, #FRAME_OFFSET_D9]
 	vldr	d10, [sp, #FRAME_OFFSET_D10]
@@ -234,7 +240,7 @@ restore:
 FUNCTION_END(_CPU_Context_validate)
 check_vfp:
 .macro check_vfp_register reg
@@ -270,6 +276,7 @@ check_vfp:
 	check_vfp_register	d13
 	check_vfp_register	d14
 	check_vfp_register	d15
 	check_vfp_register	d16
 	check_vfp_register	d17
 	check_vfp_register	d18
@@ -286,6 +293,7 @@ check_vfp:
 	check_vfp_register	d29
 	check_vfp_register	d30
 	check_vfp_register	d31
 	/* Restore r4 and r5 */
 	mov	r1, r0
@@ -293,5 +301,4 @@ check_vfp:
 	fill_register	r5
 	b	check
-#endif
diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
index 459acba..7970b8e 100644
--- a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
+++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
@@ -1,5 +1,5 @@
  *  Dornierstr. 4
@@ -27,7 +27,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
 	mov	\reg, r0
 .endm
 	vmrs	r1, FPSCR
 	movs	r2, #0x001f
 	movt	r2, #0xf800
@@ -49,6 +49,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
 	clobber_vfp_register	d5
 	clobber_vfp_register	d6
 	clobber_vfp_register	d7
 	clobber_vfp_register	d16
 	clobber_vfp_register	d17
 	clobber_vfp_register	d18
@@ -65,7 +66,8 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
 	clobber_vfp_register	d29
 	clobber_vfp_register	d30
 	clobber_vfp_register	d31
-#endif
 	clobber_register	r1
 	clobber_register	r2
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index e8026c8..7930c32 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -75,13 +75,15 @@ _ARMV4_Exception_interrupt:
 	stmdb	sp!, CONTEXT_LIST
 	stmdb	sp!, {SP_OF_INTERRUPTED_CONTEXT, lr}
 	/* Save VFP context */
 	vmrs	r0, FPSCR
 	vstmdb	sp!, {d0-d7}
 	vstmdb	sp!, {d16-d31}
-	stmdb	sp!, {r0, r1}
 #endif
+	stmdb	sp!, {r0, r1}
 	/* Get per-CPU control of current processor */
 	GET_SELF_CPU_CONTROL	SELF_CPU_CONTROL, r1
@@ -166,13 +168,15 @@ thread_dispatch_done:
 	/* Switch to ARM instructions if necessary */
 	SWITCH_FROM_THUMB_TO_ARM
 	/* Restore VFP context */
 	ldmia	sp!, {r0, r1}
 	vldmia	sp!, {d16-d31}
+#endif
 	vldmia	sp!, {d0-d7}
 	vmsr	FPSCR, r0
-#endif
 	/* Restore SP_OF_INTERRUPTED_CONTEXT register and link register */
 	ldmia	sp!, {SP_OF_INTERRUPTED_CONTEXT, lr}
diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S b/cpukit/score/cpu/arm/armv4-exception-default.S
index 950ad67..8a97320 100644
--- a/cpukit/score/cpu/arm/armv4-exception-default.S
+++ b/cpukit/score/cpu/arm/armv4-exception-default.S
@@ -118,7 +118,7 @@ save_more_context:
 	/* Argument for high level handler */
 	mov	r0, sp
 	/* Ensure that the FPU is enabled */
 	vmrs	r1, FPEXC
 	tst	r1, #(1 << 30)
@@ -132,10 +132,12 @@ save_more_context:
 	vmrs	r2, FPSCR
 	stmia	r4!, {r1-r2}
 	vstmia	r4!, {d0-d15}
 	vstmia	r4!, {d16-d31}
+#endif
 fpu_save_done:
-#endif
 	/* Call high level handler */
 	SWITCH_FROM_ARM_TO_THUMB	r1
diff --git a/cpukit/score/cpu/arm/armv7m-context-switch.c b/cpukit/score/cpu/arm/armv7m-context-switch.c
index eabf2c8..359a1a7 100644
--- a/cpukit/score/cpu/arm/armv7m-context-switch.c
+++ b/cpukit/score/cpu/arm/armv7m-context-switch.c
@@ -5,7 +5,7 @@
- * Copyright (c) 2011 Sebastian Huber.  All rights reserved.
+ * Copyright (c) 2011-2014 Sebastian Huber.  All rights reserved.
  *  Obere Lagerstr. 30
@@ -37,17 +37,26 @@ void __attribute__((naked)) _CPU_Context_switch(
     "movt r2, #:upper16:_Per_CPU_Information\n"
     "ldr r3, [r2, %[isrpcpuoff]]\n"
     "stm r0, {r4-r11, lr}\n"
+    "add r4, r0, %[d8off]\n"
+    "vstm r4, {d8-d15}\n"
+#endif
     "str sp, [r0, %[spctxoff]]\n"
     "str r3, [r0, %[isrctxoff]]\n"
     "ldr r3, [r1, %[isrctxoff]]\n"
     "ldr sp, [r1, %[spctxoff]]\n"
+    "add r4, r1, %[d8off]\n"
+    "vldm r4, {d8-d15}\n"
+#endif
     "ldm r1, {r4-r11, lr}\n"
     "str r3, [r2, %[isrpcpuoff]]\n"
     "bx lr\n"
     : [spctxoff] "J" (offsetof(Context_Control, register_sp)),
       [isrctxoff] "J" (offsetof(Context_Control, isr_nest_level)),
-      [isrpcpuoff] "J" (offsetof(Per_CPU_Control, isr_nest_level))
+      [isrpcpuoff] "J" (offsetof(Per_CPU_Control, isr_nest_level)),
+      [d8off] "J" (ARM_CONTEXT_CONTROL_D8_OFFSET)
diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
index 048ffa8..e460e9c 100644
--- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
+++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
@@ -5,7 +5,7 @@
@@ -37,13 +37,27 @@ static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
+static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
+  __asm__ volatile (
+    "vmov.f32 s0, s0\n"
+#endif
 void _ARMV7M_Pendable_service_call( void )
+  ARMV7M_Exception_frame *ef;
   _ISR_Nest_level = 1;
   _ARMV7M_SCB->icsr = ARMV7M_SCB_ICSR_PENDSVCLR;
-  ARMV7M_Exception_frame *ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
+  _ARMV7M_Trigger_lazy_floating_point_context_save();
+  ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
   --ef;
-  _ARMV7M_Set_PSP((uint32_t) ef);
+  _ARMV7M_Set_PSP( (uint32_t) ef );
    * According to "ARMv7-M Architecture Reference Manual" section B1.5.6
@@ -57,11 +71,17 @@ void _ARMV7M_Pendable_service_call( void )
 void _ARMV7M_Supervisor_call( void )
   ++ef;
   _ISR_Nest_level = 0;
   RTEMS_COMPILER_MEMORY_BARRIER();
   if ( _Thread_Dispatch_necessary ) {
     _ARMV7M_Pendable_service_call();
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 089826e..9942c4a 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -35,7 +35,7 @@
 #include <rtems/score/tls.h>
 #include <rtems/score/cpu.h>
   RTEMS_STATIC_ASSERT(
     offsetof( Context_Control, register_d8 ) == ARM_CONTEXT_CONTROL_D8_OFFSET,
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index d4355b4..344512b 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -58,7 +58,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
 	mrs	r2, CPSR
 	stmia	r0,  {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
 	add	r3, r0, #ARM_CONTEXT_CONTROL_D8_OFFSET
 	vstm	r3, {d8-d15}
 #endif
@@ -101,7 +101,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
 	mcr	p15, 0, r3, c13, c0, 3
 #endif
 	add	r3, r1, #ARM_CONTEXT_CONTROL_D8_OFFSET
 	vldm	r3, {d8-d15}
 #endif
diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
index a105f17..586a8cb 100644
--- a/cpukit/score/cpu/arm/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/rtems/score/arm.h
@@ -50,10 +50,19 @@ extern "C" {
   #define ARM_MULTILIB_HAS_THREAD_ID_REGISTER
 #endif
-#if defined(__ARM_NEON__)
-  #define ARM_MULTILIB_VFP_D32
-#elif !defined(__SOFTFP__)
-  #error "FPU support not implemented"
+#if !defined(__SOFTFP__)
+  #if defined(__ARM_NEON__)
+    #define ARM_MULTILIB_VFP_D32
+  #elif defined(__VFP_FP__)
+    #define ARM_MULTILIB_VFP_D16
+  #else
+    #error "FPU support not implemented"
+  #endif
+#endif
+#if defined(ARM_MULTILIB_VFP_D16) \
+  || defined(ARM_MULTILIB_VFP_D32)
 #endif
diff --git a/cpukit/score/cpu/arm/rtems/score/armv7m.h b/cpukit/score/cpu/arm/rtems/score/armv7m.h
index b545859..c1f820b 100644
--- a/cpukit/score/cpu/arm/rtems/score/armv7m.h
+++ b/cpukit/score/cpu/arm/rtems/score/armv7m.h
@@ -5,7 +5,7 @@
@@ -47,6 +47,26 @@ typedef struct {
   void *register_lr;
   void *register_pc;
   uint32_t register_xpsr;
+  uint32_t register_s0;
+  uint32_t register_s1;
+  uint32_t register_s2;
+  uint32_t register_s3;
+  uint32_t register_s4;
+  uint32_t register_s5;
+  uint32_t register_s6;
+  uint32_t register_s7;
+  uint32_t register_s8;
+  uint32_t register_s9;
+  uint32_t register_s10;
+  uint32_t register_s11;
+  uint32_t register_s12;
+  uint32_t register_s13;
+  uint32_t register_s14;
+  uint32_t register_s15;
+  uint32_t register_fpscr;
+  uint32_t reserved;
+#endif
 } ARMV7M_Exception_frame;
 typedef struct {
diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
index ad070df..089fc27 100644
--- a/cpukit/score/cpu/arm/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
@@ -8,7 +8,7 @@
  *  This include file contains information pertaining to the ARM
  *  processor.
- *  Copyright (c) 2009-2013 embedded brains GmbH.
+ *  Copyright (c) 2009-2014 embedded brains GmbH.
  *  Copyright (c) 2007 Ray Xu <Rayx.cn at gmail.com>
@@ -212,12 +212,12 @@
   #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
 #endif
   #define ARM_CONTEXT_CONTROL_D8_OFFSET 48
 #endif
 #ifdef RTEMS_SMP
-  #ifdef ARM_MULTILIB_VFP_D32
+  #ifdef ARM_MULTILIB_VFP
     #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
   #else
     #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
@@ -278,7 +278,7 @@ typedef struct {
 #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
   uint32_t thread_id;
 #endif
   uint64_t register_d8;
   uint64_t register_d9;
   uint64_t register_d10;
1.8.1.4
