[PATCH 1/2] arm: Add support for FPv4-SP floating point unit
Mon Aug 11 21:02:55 UTC 2014
On Mon, Aug 11, 2014 at 4:48 PM, Sebastian Huber
> This floating point unit is available in Cortex-M4F processors and
> defined by ARMv7-M.  This adds basic support for other VFP-D16 variants.
>  c/src/lib/libbsp/arm/shared/start/start.S          | 20 ++++++++++++++
>  cpukit/score/cpu/arm/arm-context-validate.S        | 31 +++++++++++++---------
>  .../score/cpu/arm/arm-context-volatile-clobber.S   |  8 +++---
>  cpukit/score/cpu/arm/arm_exc_interrupt.S           | 12 ++++++---
>  cpukit/score/cpu/arm/armv4-exception-default.S     |  6 +++--
>  cpukit/score/cpu/arm/armv7m-context-switch.c       | 13 +++++++--
>  cpukit/score/cpu/arm/armv7m-isr-dispatch.c         | 30 +++++++++++++++++----
>  cpukit/score/cpu/arm/cpu.c                         |  2 +-
>  cpukit/score/cpu/arm/cpu_asm.S                     |  4 +--
>  cpukit/score/cpu/arm/rtems/score/arm.h             | 17 +++++++++---
>  cpukit/score/cpu/arm/rtems/score/armv7m.h          | 22 ++++++++++++++-
>  cpukit/score/cpu/arm/rtems/score/cpu.h             |  8 +++---
>  12 files changed, 133 insertions(+), 40 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
> index 096e9bd..8c73b8d 100644
> --- a/c/src/lib/libbsp/arm/shared/start/start.S
> +++ b/c/src/lib/libbsp/arm/shared/start/start.S
> @@ -300,6 +300,26 @@ bsp_start_vector_table_end:
>  _start:
> +#ifdef ARM_MULTILIB_VFP
> +       /* CPACR is located at address 0xe000ed88 */
> +       ldr.w   r0, =0xe000ed88
Maybe the constant should be provided by a header file? The comments
are nice though. And I didn't see anything else in the rest, although
my arm asm is rusty.
> +       /* Read CPACR */
> +       ldr     r1, [r0]
> +       /* Set bits 20-23 to enable CP10 and CP11 co-processors */
> +       orr     r1, r1, #(0xf << 20)
> +       /* Write back the modified value to the CPACR */
> +       str     r1, [r0]
> +       /* Wait for store to complete */
> +       dsb
> +       /* Reset pipeline now the FPU is enabled */
> +       isb
> +#endif
>         ldr     sp, =bsp_stack_main_end
>         ldr     lr, =bsp_start_hook_0_done + 1
>         b       bsp_start_hook_0
> diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
> index f2772b4..fdfb6c1 100644
> --- a/cpukit/score/cpu/arm/arm-context-validate.S
> +++ b/cpukit/score/cpu/arm/arm-context-validate.S
> @@ -1,5 +1,5 @@
> - * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
> + * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
>   *  embedded brains GmbH
>   *  Dornierstr. 4
> @@ -29,7 +29,7 @@
>  #define FRAME_OFFSET_R11 28
>  #define FRAME_OFFSET_LR 32
> -#ifdef ARM_MULTILIB_VFP_D32
>    #define FRAME_OFFSET_D8 40
>    #define FRAME_OFFSET_D9 48
>    #define FRAME_OFFSET_D10 56
> @@ -71,7 +71,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>         mov     r1, lr
>         str     r1, [sp, #FRAME_OFFSET_LR]
>         vstr    d8, [sp, #FRAME_OFFSET_D8]
>         vstr    d9, [sp, #FRAME_OFFSET_D9]
>         vstr    d10, [sp, #FRAME_OFFSET_D10]
> @@ -96,11 +96,15 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>  .endm
>         /* R3 contains the FPSCR */
>         vmrs    r3, FPSCR
>         movs    r4, #0x001f
> +#ifdef ARM_MULTILIB_ARCH_V7M
> +       movt    r4, #0xf000
> +#else
>         movt    r4, #0xf800
> +#endif
>         bic     r3, r3, r4
>         and     r4, r4, r0
>         orr     r3, r3, r4
> @@ -120,7 +124,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>         fill_register   r12
>         fill_register   lr
>  .macro fill_vfp_register reg
>         add     r1, r1, #1
>         vmov    \reg, r1, r1
> @@ -142,6 +146,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>         fill_vfp_register       d13
>         fill_vfp_register       d14
>         fill_vfp_register       d15
> +#ifdef ARM_MULTILIB_VFP_D32
>         fill_vfp_register       d16
>         fill_vfp_register       d17
>         fill_vfp_register       d18
> @@ -158,7 +163,8 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>         fill_vfp_register       d29
>         fill_vfp_register       d30
>         fill_vfp_register       d31
> -#endif
> +#endif /* ARM_MULTILIB_VFP_D32 */
> +#endif /* ARM_MULTILIB_VFP */
>         /* Check */
>  check:
> @@ -174,7 +180,7 @@ check:
>         mov     r1, r0
> -#ifndef ARM_MULTILIB_VFP_D32
> +#ifndef ARM_MULTILIB_VFP
>         check_register  r3
>  #endif
> @@ -189,7 +195,7 @@ check:
>         check_register  r12
>         check_register  lr
>         b       check_vfp
>  #endif
> @@ -217,7 +223,7 @@ restore:
>         ldr     r1, [sp, #FRAME_OFFSET_LR]
>         mov     lr, r1
>         vldr    d8, [sp, #FRAME_OFFSET_D8]
>         vldr    d9, [sp, #FRAME_OFFSET_D9]
>         vldr    d10, [sp, #FRAME_OFFSET_D10]
> @@ -234,7 +240,7 @@ restore:
>  FUNCTION_END(_CPU_Context_validate)
>  check_vfp:
>  .macro check_vfp_register reg
> @@ -270,6 +276,7 @@ check_vfp:
>         check_vfp_register      d13
>         check_vfp_register      d14
>         check_vfp_register      d15
>         check_vfp_register      d16
>         check_vfp_register      d17
>         check_vfp_register      d18
> @@ -286,6 +293,7 @@ check_vfp:
>         check_vfp_register      d29
>         check_vfp_register      d30
>         check_vfp_register      d31
>         /* Restore r4 and r5 */
>         mov     r1, r0
> @@ -293,5 +301,4 @@ check_vfp:
>         fill_register   r5
>         b       check
> -#endif
> diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
> index 459acba..7970b8e 100644
> --- a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
> +++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
> @@ -1,5 +1,5 @@
>   *  Dornierstr. 4
> @@ -27,7 +27,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>         mov     \reg, r0
>  .endm
>         vmrs    r1, FPSCR
>         movs    r2, #0x001f
>         movt    r2, #0xf800
> @@ -49,6 +49,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>         clobber_vfp_register    d5
>         clobber_vfp_register    d6
>         clobber_vfp_register    d7
>         clobber_vfp_register    d16
>         clobber_vfp_register    d17
>         clobber_vfp_register    d18
> @@ -65,7 +66,8 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>         clobber_vfp_register    d29
>         clobber_vfp_register    d30
>         clobber_vfp_register    d31
> -#endif
>         clobber_register        r1
>         clobber_register        r2
> diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
> index e8026c8..7930c32 100644
> --- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
> +++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
> @@ -75,13 +75,15 @@ _ARMV4_Exception_interrupt:
>         stmdb   sp!, CONTEXT_LIST
>         stmdb   sp!, {SP_OF_INTERRUPTED_CONTEXT, lr}
>         /* Save VFP context */
>         vmrs    r0, FPSCR
>         vstmdb  sp!, {d0-d7}
>         vstmdb  sp!, {d16-d31}
> -       stmdb   sp!, {r0, r1}
>  #endif
> +       stmdb   sp!, {r0, r1}
>         /* Get per-CPU control of current processor */
>         GET_SELF_CPU_CONTROL    SELF_CPU_CONTROL, r1
> @@ -166,13 +168,15 @@ thread_dispatch_done:
>         /* Switch to ARM instructions if necessary */
>         SWITCH_FROM_THUMB_TO_ARM
>         /* Restore VFP context */
>         ldmia   sp!, {r0, r1}
>         vldmia  sp!, {d16-d31}
> +#endif
>         vldmia  sp!, {d0-d7}
>         vmsr    FPSCR, r0
> -#endif
>         /* Restore SP_OF_INTERRUPTED_CONTEXT register and link register */
>         ldmia   sp!, {SP_OF_INTERRUPTED_CONTEXT, lr}
> diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S b/cpukit/score/cpu/arm/armv4-exception-default.S
> index 950ad67..8a97320 100644
> --- a/cpukit/score/cpu/arm/armv4-exception-default.S
> +++ b/cpukit/score/cpu/arm/armv4-exception-default.S
> @@ -118,7 +118,7 @@ save_more_context:
>         /* Argument for high level handler */
>         mov     r0, sp
>         /* Ensure that the FPU is enabled */
>         vmrs    r1, FPEXC
>         tst     r1, #(1 << 30)
> @@ -132,10 +132,12 @@ save_more_context:
>         vmrs    r2, FPSCR
>         stmia   r4!, {r1-r2}
>         vstmia  r4!, {d0-d15}
>         vstmia  r4!, {d16-d31}
> +#endif
>  fpu_save_done:
> -#endif
>         /* Call high level handler */
>         SWITCH_FROM_ARM_TO_THUMB        r1
> diff --git a/cpukit/score/cpu/arm/armv7m-context-switch.c b/cpukit/score/cpu/arm/armv7m-context-switch.c
> index eabf2c8..359a1a7 100644
> --- a/cpukit/score/cpu/arm/armv7m-context-switch.c
> +++ b/cpukit/score/cpu/arm/armv7m-context-switch.c
> @@ -5,7 +5,7 @@
> - * Copyright (c) 2011 Sebastian Huber.  All rights reserved.
> + * Copyright (c) 2011-2014 Sebastian Huber.  All rights reserved.
>   *  Obere Lagerstr. 30
> @@ -37,17 +37,26 @@ void __attribute__((naked)) _CPU_Context_switch(
>      "movt r2, #:upper16:_Per_CPU_Information\n"
>      "ldr r3, [r2, %[isrpcpuoff]]\n"
>      "stm r0, {r4-r11, lr}\n"
> +    "add r4, r0, %[d8off]\n"
> +    "vstm r4, {d8-d15}\n"
> +#endif
>      "str sp, [r0, %[spctxoff]]\n"
>      "str r3, [r0, %[isrctxoff]]\n"
>      "ldr r3, [r1, %[isrctxoff]]\n"
>      "ldr sp, [r1, %[spctxoff]]\n"
> +    "add r4, r1, %[d8off]\n"
> +    "vldm r4, {d8-d15}\n"
> +#endif
>      "ldm r1, {r4-r11, lr}\n"
>      "str r3, [r2, %[isrpcpuoff]]\n"
>      "bx lr\n"
>      : [spctxoff] "J" (offsetof(Context_Control, register_sp)),
>        [isrctxoff] "J" (offsetof(Context_Control, isr_nest_level)),
> -      [isrpcpuoff] "J" (offsetof(Per_CPU_Control, isr_nest_level))
> +      [isrpcpuoff] "J" (offsetof(Per_CPU_Control, isr_nest_level)),
> +      [d8off] "J" (ARM_CONTEXT_CONTROL_D8_OFFSET)
> diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> index 048ffa8..e460e9c 100644
> --- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> +++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
> @@ -5,7 +5,7 @@
> @@ -37,13 +37,27 @@ static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
> +static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
> +  __asm__ volatile (
> +    "vmov.f32 s0, s0\n"
> +#endif
>  void _ARMV7M_Pendable_service_call( void )
> +  ARMV7M_Exception_frame *ef;
>    _ISR_Nest_level = 1;
>    _ARMV7M_SCB->icsr = ARMV7M_SCB_ICSR_PENDSVCLR;
> -  ARMV7M_Exception_frame *ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
> +  _ARMV7M_Trigger_lazy_floating_point_context_save();
> +  ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
>    --ef;
> -  _ARMV7M_Set_PSP((uint32_t) ef);
> +  _ARMV7M_Set_PSP( (uint32_t) ef );
>     * According to "ARMv7-M Architecture Reference Manual" section B1.5.6
> @@ -57,11 +71,17 @@ void _ARMV7M_Pendable_service_call( void )
>  void _ARMV7M_Supervisor_call( void )
>    ++ef;
>    _ISR_Nest_level = 0;
>    RTEMS_COMPILER_MEMORY_BARRIER();
>    if ( _Thread_Dispatch_necessary ) {
>      _ARMV7M_Pendable_service_call();
> diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
> index 089826e..9942c4a 100644
> --- a/cpukit/score/cpu/arm/cpu.c
> +++ b/cpukit/score/cpu/arm/cpu.c
> @@ -35,7 +35,7 @@
>  #include <rtems/score/tls.h>
>  #include <rtems/score/cpu.h>
>    RTEMS_STATIC_ASSERT(
>      offsetof( Context_Control, register_d8 ) == ARM_CONTEXT_CONTROL_D8_OFFSET,
> diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
> index d4355b4..344512b 100644
> --- a/cpukit/score/cpu/arm/cpu_asm.S
> +++ b/cpukit/score/cpu/arm/cpu_asm.S
> @@ -58,7 +58,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>         mrs     r2, CPSR
>         stmia   r0,  {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
>         add     r3, r0, #ARM_CONTEXT_CONTROL_D8_OFFSET
>         vstm    r3, {d8-d15}
>  #endif
> @@ -101,7 +101,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>         mcr     p15, 0, r3, c13, c0, 3
>  #endif
>         add     r3, r1, #ARM_CONTEXT_CONTROL_D8_OFFSET
>         vldm    r3, {d8-d15}
>  #endif
> diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
> index a105f17..586a8cb 100644
> --- a/cpukit/score/cpu/arm/rtems/score/arm.h
> +++ b/cpukit/score/cpu/arm/rtems/score/arm.h
> @@ -50,10 +50,19 @@ extern "C" {
>    #define ARM_MULTILIB_HAS_THREAD_ID_REGISTER
>  #endif
> -#if defined(__ARM_NEON__)
> -  #define ARM_MULTILIB_VFP_D32
> -#elif !defined(__SOFTFP__)
> -  #error "FPU support not implemented"
> +#if !defined(__SOFTFP__)
> +  #if defined(__ARM_NEON__)
> +    #define ARM_MULTILIB_VFP_D32
> +  #elif defined(__VFP_FP__)
> +    #define ARM_MULTILIB_VFP_D16
> +  #else
> +    #error "FPU support not implemented"
> +  #endif
> +#endif
> +#if defined(ARM_MULTILIB_VFP_D16) \
> +  || defined(ARM_MULTILIB_VFP_D32)
>  #endif
> diff --git a/cpukit/score/cpu/arm/rtems/score/armv7m.h b/cpukit/score/cpu/arm/rtems/score/armv7m.h
> index b545859..c1f820b 100644
> --- a/cpukit/score/cpu/arm/rtems/score/armv7m.h
> +++ b/cpukit/score/cpu/arm/rtems/score/armv7m.h
> @@ -5,7 +5,7 @@
> @@ -47,6 +47,26 @@ typedef struct {
>    void *register_lr;
>    void *register_pc;
>    uint32_t register_xpsr;
> +  uint32_t register_s0;
> +  uint32_t register_s1;
> +  uint32_t register_s2;
> +  uint32_t register_s3;
> +  uint32_t register_s4;
> +  uint32_t register_s5;
> +  uint32_t register_s6;
> +  uint32_t register_s7;
> +  uint32_t register_s8;
> +  uint32_t register_s9;
> +  uint32_t register_s10;
> +  uint32_t register_s11;
> +  uint32_t register_s12;
> +  uint32_t register_s13;
> +  uint32_t register_s14;
> +  uint32_t register_s15;
> +  uint32_t register_fpscr;
> +  uint32_t reserved;
> +#endif
>  } ARMV7M_Exception_frame;
>  typedef struct {
> diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
> index ad070df..089fc27 100644
> --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
> @@ -8,7 +8,7 @@
>   *  This include file contains information pertaining to the ARM
>   *  processor.
> - *  Copyright (c) 2009-2013 embedded brains GmbH.
> + *  Copyright (c) 2009-2014 embedded brains GmbH.
>   *  Copyright (c) 2007 Ray Xu <Rayx.cn at gmail.com>
> @@ -212,12 +212,12 @@
>    #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
>  #endif
>    #define ARM_CONTEXT_CONTROL_D8_OFFSET 48
>  #endif
>  #ifdef RTEMS_SMP
> -  #ifdef ARM_MULTILIB_VFP_D32
> +  #ifdef ARM_MULTILIB_VFP
>      #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
>    #else
>      #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
> @@ -278,7 +278,7 @@ typedef struct {
>  #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
>    uint32_t thread_id;
>  #endif
>    uint64_t register_d8;
>    uint64_t register_d9;
>    uint64_t register_d10;
> 1.8.1.4
> devel mailing list
> devel at rtems.org
