[PATCH 1/2] arm: Add support for FPv4-SP floating point unit
Mon Aug 11 21:12:20 UTC 2014
Is there any tool patch missing? I may be thinking of nios and I think
I committed that.
--joel
On 8/11/2014 4:02 PM, Gedare Bloom wrote:
> On Mon, Aug 11, 2014 at 4:48 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> This floating point unit is available in Cortex-M4F processors and
>> defined by ARMv7-M.  This adds basic support for other VFP-D16 variants.
>>  c/src/lib/libbsp/arm/shared/start/start.S          | 20 ++++++++++++++
>>  cpukit/score/cpu/arm/arm-context-validate.S        | 31 +++++++++++++---------
>>  .../score/cpu/arm/arm-context-volatile-clobber.S   |  8 +++---
>>  cpukit/score/cpu/arm/arm_exc_interrupt.S           | 12 ++++++---
>>  cpukit/score/cpu/arm/armv4-exception-default.S     |  6 +++--
>>  cpukit/score/cpu/arm/armv7m-context-switch.c       | 13 +++++++--
>>  cpukit/score/cpu/arm/armv7m-isr-dispatch.c         | 30 +++++++++++++++++----
>>  cpukit/score/cpu/arm/cpu.c                         |  2 +-
>>  cpukit/score/cpu/arm/cpu_asm.S                     |  4 +--
>>  cpukit/score/cpu/arm/rtems/score/arm.h             | 17 +++++++++---
>>  cpukit/score/cpu/arm/rtems/score/armv7m.h          | 22 ++++++++++++++-
>>  cpukit/score/cpu/arm/rtems/score/cpu.h             |  8 +++---
>>  12 files changed, 133 insertions(+), 40 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/shared/start/start.S b/c/src/lib/libbsp/arm/shared/start/start.S
>> index 096e9bd..8c73b8d 100644
>> --- a/c/src/lib/libbsp/arm/shared/start/start.S
>> +++ b/c/src/lib/libbsp/arm/shared/start/start.S
>> @@ -300,6 +300,26 @@ bsp_start_vector_table_end:
>>  _start:
>> +#ifdef ARM_MULTILIB_VFP
>> +       /* CPACR is located at address 0xe000ed88 */
>> +       ldr.w   r0, =0xe000ed88
> Maybe the constant should be provided by a header file? The comments
> are nice though. And I didn't see anything else in the rest, although
> my arm asm is rusty.
>> +       /* Read CPACR */
>> +       ldr     r1, [r0]
>> +       /* Set bits 20-23 to enable CP10 and CP11 co-processors */
>> +       orr     r1, r1, #(0xf << 20)
>> +       /* Write back the modified value to the CPACR */
>> +       str     r1, [r0]
>> +       /* Wait for store to complete */
>> +       dsb
>> +       /* Reset pipeline now the FPU is enabled */
>> +       isb
>> +#endif
>>         ldr     sp, =bsp_stack_main_end
>>         ldr     lr, =bsp_start_hook_0_done + 1
>>         b       bsp_start_hook_0
>> diff --git a/cpukit/score/cpu/arm/arm-context-validate.S b/cpukit/score/cpu/arm/arm-context-validate.S
>> index f2772b4..fdfb6c1 100644
>> --- a/cpukit/score/cpu/arm/arm-context-validate.S
>> +++ b/cpukit/score/cpu/arm/arm-context-validate.S
>> @@ -1,5 +1,5 @@
>> - * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
>> + * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
>>   *  embedded brains GmbH
>>   *  Dornierstr. 4
>> @@ -29,7 +29,7 @@
>>  #define FRAME_OFFSET_R11 28
>>  #define FRAME_OFFSET_LR 32
>> -#ifdef ARM_MULTILIB_VFP_D32
>>    #define FRAME_OFFSET_D8 40
>>    #define FRAME_OFFSET_D9 48
>>    #define FRAME_OFFSET_D10 56
>> @@ -71,7 +71,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>>         mov     r1, lr
>>         str     r1, [sp, #FRAME_OFFSET_LR]
>>         vstr    d8, [sp, #FRAME_OFFSET_D8]
>>         vstr    d9, [sp, #FRAME_OFFSET_D9]
>>         vstr    d10, [sp, #FRAME_OFFSET_D10]
>> @@ -96,11 +96,15 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>>  .endm
>>         /* R3 contains the FPSCR */
>>         vmrs    r3, FPSCR
>>         movs    r4, #0x001f
>> +#ifdef ARM_MULTILIB_ARCH_V7M
>> +       movt    r4, #0xf000
>> +#else
>>         movt    r4, #0xf800
>> +#endif
>>         bic     r3, r3, r4
>>         and     r4, r4, r0
>>         orr     r3, r3, r4
>> @@ -120,7 +124,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>>         fill_register   r12
>>         fill_register   lr
>>  .macro fill_vfp_register reg
>>         add     r1, r1, #1
>>         vmov    \reg, r1, r1
>> @@ -142,6 +146,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>>         fill_vfp_register       d13
>>         fill_vfp_register       d14
>>         fill_vfp_register       d15
>> +#ifdef ARM_MULTILIB_VFP_D32
>>         fill_vfp_register       d16
>>         fill_vfp_register       d17
>>         fill_vfp_register       d18
>> @@ -158,7 +163,8 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_validate)
>>         fill_vfp_register       d29
>>         fill_vfp_register       d30
>>         fill_vfp_register       d31
>> -#endif
>> +#endif /* ARM_MULTILIB_VFP_D32 */
>> +#endif /* ARM_MULTILIB_VFP */
>>         /* Check */
>>  check:
>> @@ -174,7 +180,7 @@ check:
>>         mov     r1, r0
>> -#ifndef ARM_MULTILIB_VFP_D32
>> +#ifndef ARM_MULTILIB_VFP
>>         check_register  r3
>>  #endif
>> @@ -189,7 +195,7 @@ check:
>>         check_register  r12
>>         check_register  lr
>>         b       check_vfp
>>  #endif
>> @@ -217,7 +223,7 @@ restore:
>>         ldr     r1, [sp, #FRAME_OFFSET_LR]
>>         mov     lr, r1
>>         vldr    d8, [sp, #FRAME_OFFSET_D8]
>>         vldr    d9, [sp, #FRAME_OFFSET_D9]
>>         vldr    d10, [sp, #FRAME_OFFSET_D10]
>> @@ -234,7 +240,7 @@ restore:
>>  FUNCTION_END(_CPU_Context_validate)
>>  check_vfp:
>>  .macro check_vfp_register reg
>> @@ -270,6 +276,7 @@ check_vfp:
>>         check_vfp_register      d13
>>         check_vfp_register      d14
>>         check_vfp_register      d15
>>         check_vfp_register      d16
>>         check_vfp_register      d17
>>         check_vfp_register      d18
>> @@ -286,6 +293,7 @@ check_vfp:
>>         check_vfp_register      d29
>>         check_vfp_register      d30
>>         check_vfp_register      d31
>>         /* Restore r4 and r5 */
>>         mov     r1, r0
>> @@ -293,5 +301,4 @@ check_vfp:
>>         fill_register   r5
>>         b       check
>> -#endif
>> diff --git a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>> index 459acba..7970b8e 100644
>> --- a/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>> +++ b/cpukit/score/cpu/arm/arm-context-volatile-clobber.S
>> @@ -1,5 +1,5 @@
>>   *  Dornierstr. 4
>> @@ -27,7 +27,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>>         mov     \reg, r0
>>  .endm
>>         vmrs    r1, FPSCR
>>         movs    r2, #0x001f
>>         movt    r2, #0xf800
>> @@ -49,6 +49,7 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>>         clobber_vfp_register    d5
>>         clobber_vfp_register    d6
>>         clobber_vfp_register    d7
>>         clobber_vfp_register    d16
>>         clobber_vfp_register    d17
>>         clobber_vfp_register    d18
>> @@ -65,7 +66,8 @@ FUNCTION_THUMB_ENTRY(_CPU_Context_volatile_clobber)
>>         clobber_vfp_register    d29
>>         clobber_vfp_register    d30
>>         clobber_vfp_register    d31
>> -#endif
>>         clobber_register        r1
>>         clobber_register        r2
>> diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
>> index e8026c8..7930c32 100644
>> --- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
>> +++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
>> @@ -75,13 +75,15 @@ _ARMV4_Exception_interrupt:
>>         stmdb   sp!, CONTEXT_LIST
>>         stmdb   sp!, {SP_OF_INTERRUPTED_CONTEXT, lr}
>>         /* Save VFP context */
>>         vmrs    r0, FPSCR
>>         vstmdb  sp!, {d0-d7}
>>         vstmdb  sp!, {d16-d31}
>> -       stmdb   sp!, {r0, r1}
>>  #endif
>> +       stmdb   sp!, {r0, r1}
>>         /* Get per-CPU control of current processor */
>>         GET_SELF_CPU_CONTROL    SELF_CPU_CONTROL, r1
>> @@ -166,13 +168,15 @@ thread_dispatch_done:
>>         /* Switch to ARM instructions if necessary */
>>         SWITCH_FROM_THUMB_TO_ARM
>>         /* Restore VFP context */
>>         ldmia   sp!, {r0, r1}
>>         vldmia  sp!, {d16-d31}
>> +#endif
>>         vldmia  sp!, {d0-d7}
>>         vmsr    FPSCR, r0
>> -#endif
>>         /* Restore SP_OF_INTERRUPTED_CONTEXT register and link register */
>>         ldmia   sp!, {SP_OF_INTERRUPTED_CONTEXT, lr}
>> diff --git a/cpukit/score/cpu/arm/armv4-exception-default.S b/cpukit/score/cpu/arm/armv4-exception-default.S
>> index 950ad67..8a97320 100644
>> --- a/cpukit/score/cpu/arm/armv4-exception-default.S
>> +++ b/cpukit/score/cpu/arm/armv4-exception-default.S
>> @@ -118,7 +118,7 @@ save_more_context:
>>         /* Argument for high level handler */
>>         mov     r0, sp
>>         /* Ensure that the FPU is enabled */
>>         vmrs    r1, FPEXC
>>         tst     r1, #(1 << 30)
>> @@ -132,10 +132,12 @@ save_more_context:
>>         vmrs    r2, FPSCR
>>         stmia   r4!, {r1-r2}
>>         vstmia  r4!, {d0-d15}
>>         vstmia  r4!, {d16-d31}
>> +#endif
>>  fpu_save_done:
>> -#endif
>>         /* Call high level handler */
>>         SWITCH_FROM_ARM_TO_THUMB        r1
>> diff --git a/cpukit/score/cpu/arm/armv7m-context-switch.c b/cpukit/score/cpu/arm/armv7m-context-switch.c
>> index eabf2c8..359a1a7 100644
>> --- a/cpukit/score/cpu/arm/armv7m-context-switch.c
>> +++ b/cpukit/score/cpu/arm/armv7m-context-switch.c
>> @@ -5,7 +5,7 @@
>> - * Copyright (c) 2011 Sebastian Huber.  All rights reserved.
>> + * Copyright (c) 2011-2014 Sebastian Huber.  All rights reserved.
>>   *  Obere Lagerstr. 30
>> @@ -37,17 +37,26 @@ void __attribute__((naked)) _CPU_Context_switch(
>>      "movt r2, #:upper16:_Per_CPU_Information\n"
>>      "ldr r3, [r2, %[isrpcpuoff]]\n"
>>      "stm r0, {r4-r11, lr}\n"
>> +    "add r4, r0, %[d8off]\n"
>> +    "vstm r4, {d8-d15}\n"
>> +#endif
>>      "str sp, [r0, %[spctxoff]]\n"
>>      "str r3, [r0, %[isrctxoff]]\n"
>>      "ldr r3, [r1, %[isrctxoff]]\n"
>>      "ldr sp, [r1, %[spctxoff]]\n"
>> +    "add r4, r1, %[d8off]\n"
>> +    "vldm r4, {d8-d15}\n"
>> +#endif
>>      "ldm r1, {r4-r11, lr}\n"
>>      "str r3, [r2, %[isrpcpuoff]]\n"
>>      "bx lr\n"
>>      : [spctxoff] "J" (offsetof(Context_Control, register_sp)),
>>        [isrctxoff] "J" (offsetof(Context_Control, isr_nest_level)),
>> -      [isrpcpuoff] "J" (offsetof(Per_CPU_Control, isr_nest_level))
>> +      [isrpcpuoff] "J" (offsetof(Per_CPU_Control, isr_nest_level)),
>> +      [d8off] "J" (ARM_CONTEXT_CONTROL_D8_OFFSET)
>> diff --git a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
>> index 048ffa8..e460e9c 100644
>> --- a/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
>> +++ b/cpukit/score/cpu/arm/armv7m-isr-dispatch.c
>> @@ -5,7 +5,7 @@
>> @@ -37,13 +37,27 @@ static void __attribute__((naked)) _ARMV7M_Thread_dispatch( void )
>> +static void _ARMV7M_Trigger_lazy_floating_point_context_save( void )
>> +  __asm__ volatile (
>> +    "vmov.f32 s0, s0\n"
>> +#endif
>>  void _ARMV7M_Pendable_service_call( void )
>> +  ARMV7M_Exception_frame *ef;
>>    _ISR_Nest_level = 1;
>>    _ARMV7M_SCB->icsr = ARMV7M_SCB_ICSR_PENDSVCLR;
>> -  ARMV7M_Exception_frame *ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
>> +  _ARMV7M_Trigger_lazy_floating_point_context_save();
>> +  ef = (ARMV7M_Exception_frame *) _ARMV7M_Get_PSP();
>>    --ef;
>> -  _ARMV7M_Set_PSP((uint32_t) ef);
>> +  _ARMV7M_Set_PSP( (uint32_t) ef );
>>     * According to "ARMv7-M Architecture Reference Manual" section B1.5.6
>> @@ -57,11 +71,17 @@ void _ARMV7M_Pendable_service_call( void )
>>  void _ARMV7M_Supervisor_call( void )
>>    ++ef;
>>    _ISR_Nest_level = 0;
>>    RTEMS_COMPILER_MEMORY_BARRIER();
>>    if ( _Thread_Dispatch_necessary ) {
>>      _ARMV7M_Pendable_service_call();
>> diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
>> index 089826e..9942c4a 100644
>> --- a/cpukit/score/cpu/arm/cpu.c
>> +++ b/cpukit/score/cpu/arm/cpu.c
>> @@ -35,7 +35,7 @@
>>  #include <rtems/score/tls.h>
>>  #include <rtems/score/cpu.h>
>>    RTEMS_STATIC_ASSERT(
>>      offsetof( Context_Control, register_d8 ) == ARM_CONTEXT_CONTROL_D8_OFFSET,
>> diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
>> index d4355b4..344512b 100644
>> --- a/cpukit/score/cpu/arm/cpu_asm.S
>> +++ b/cpukit/score/cpu/arm/cpu_asm.S
>> @@ -58,7 +58,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>>         mrs     r2, CPSR
>>         stmia   r0,  {r2, r4, r5, r6, r7, r8, r9, r10, r11, r13, r14}
>>         add     r3, r0, #ARM_CONTEXT_CONTROL_D8_OFFSET
>>         vstm    r3, {d8-d15}
>>  #endif
>> @@ -101,7 +101,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
>>         mcr     p15, 0, r3, c13, c0, 3
>>  #endif
>>         add     r3, r1, #ARM_CONTEXT_CONTROL_D8_OFFSET
>>         vldm    r3, {d8-d15}
>>  #endif
>> diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
>> index a105f17..586a8cb 100644
>> --- a/cpukit/score/cpu/arm/rtems/score/arm.h
>> +++ b/cpukit/score/cpu/arm/rtems/score/arm.h
>> @@ -50,10 +50,19 @@ extern "C" {
>>    #define ARM_MULTILIB_HAS_THREAD_ID_REGISTER
>>  #endif
>> -#if defined(__ARM_NEON__)
>> -  #define ARM_MULTILIB_VFP_D32
>> -#elif !defined(__SOFTFP__)
>> -  #error "FPU support not implemented"
>> +#if !defined(__SOFTFP__)
>> +  #if defined(__ARM_NEON__)
>> +    #define ARM_MULTILIB_VFP_D32
>> +  #elif defined(__VFP_FP__)
>> +    #define ARM_MULTILIB_VFP_D16
>> +  #else
>> +    #error "FPU support not implemented"
>> +  #endif
>> +#endif
>> +#if defined(ARM_MULTILIB_VFP_D16) \
>> +  || defined(ARM_MULTILIB_VFP_D32)
>>  #endif
>> diff --git a/cpukit/score/cpu/arm/rtems/score/armv7m.h b/cpukit/score/cpu/arm/rtems/score/armv7m.h
>> index b545859..c1f820b 100644
>> --- a/cpukit/score/cpu/arm/rtems/score/armv7m.h
>> +++ b/cpukit/score/cpu/arm/rtems/score/armv7m.h
>> @@ -5,7 +5,7 @@
>> @@ -47,6 +47,26 @@ typedef struct {
>>    void *register_lr;
>>    void *register_pc;
>>    uint32_t register_xpsr;
>> +  uint32_t register_s0;
>> +  uint32_t register_s1;
>> +  uint32_t register_s2;
>> +  uint32_t register_s3;
>> +  uint32_t register_s4;
>> +  uint32_t register_s5;
>> +  uint32_t register_s6;
>> +  uint32_t register_s7;
>> +  uint32_t register_s8;
>> +  uint32_t register_s9;
>> +  uint32_t register_s10;
>> +  uint32_t register_s11;
>> +  uint32_t register_s12;
>> +  uint32_t register_s13;
>> +  uint32_t register_s14;
>> +  uint32_t register_s15;
>> +  uint32_t register_fpscr;
>> +  uint32_t reserved;
>> +#endif
>>  } ARMV7M_Exception_frame;
>>  typedef struct {
>> diff --git a/cpukit/score/cpu/arm/rtems/score/cpu.h b/cpukit/score/cpu/arm/rtems/score/cpu.h
>> index ad070df..089fc27 100644
>> --- a/cpukit/score/cpu/arm/rtems/score/cpu.h
>> +++ b/cpukit/score/cpu/arm/rtems/score/cpu.h
>> @@ -8,7 +8,7 @@
>>   *  This include file contains information pertaining to the ARM
>>   *  processor.
>> - *  Copyright (c) 2009-2013 embedded brains GmbH.
>> + *  Copyright (c) 2009-2014 embedded brains GmbH.
>>   *  Copyright (c) 2007 Ray Xu <Rayx.cn at gmail.com>
>> @@ -212,12 +212,12 @@
>>    #define ARM_CONTEXT_CONTROL_THREAD_ID_OFFSET 44
>>  #endif
>>    #define ARM_CONTEXT_CONTROL_D8_OFFSET 48
>>  #endif
>>  #ifdef RTEMS_SMP
>> -  #ifdef ARM_MULTILIB_VFP_D32
>> +  #ifdef ARM_MULTILIB_VFP
>>      #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 112
>>    #else
>>      #define ARM_CONTEXT_CONTROL_IS_EXECUTING_OFFSET 48
>> @@ -278,7 +278,7 @@ typedef struct {
>>  #ifdef ARM_MULTILIB_HAS_THREAD_ID_REGISTER
>>    uint32_t thread_id;
>>  #endif
>>    uint64_t register_d8;
>>    uint64_t register_d9;
>>    uint64_t register_d10;
>> 1.8.1.4
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
